Old 04-26-2015, 12:39 AM   #1
Eddie2SS
Eddie2SS's Avatar
Drives: 2011 Camaro 2SS
Hurst Roll Control Kit (Line Lock)
Can I just install this plane switch or whatever its called instead of the two supplied switches. I would like to flick the switch and go straight to engage rather than activating, then depressing the second witch to engage. I think it would be difficult to accidentally engage this type of switch . Any ideas or recommendations.
Eddie2SS is offline   Reply With Quote
Old 04-26-2015, 12:47 AM   #2
Merc
In The Circle
Merc's Avatar
You could but it's pretty ugly, and a push button momentary switch is much better for a line lock.
Old 04-26-2015, 09:30 AM   #3
dcarlos55
dcarlos55's Avatar
Drives: 2017 HBM A10 ZL1
Get a switchlink box and use the cruise control cancel button for a momentary switch. I put the power switch and light in the AC vent.
It makes for a nice clean stealth install.
http://www.camaro5.com/forums/showthread.php?t=107286
My build thread http://www.camaro5.com/forums/showthread.php?t=224342
Go is good. Stop is better.
dcarlos55 is offline   Reply With Quote
Old 04-26-2015, 12:07 PM   #4
rgreene1971
rgreene1971's Avatar
Drives: 2010 Camaro SS
I did not use the momentary button with mine. I installed only a single rocker switch. Works perfectly and has no issues. I will take some pictures of the setup
My 2010 Camaro SS
COMP Cams XFI Street/Strip, Lingenfelter LS3 Heads, AHR Long tube headers + X pipe, FAST LSXR 102mm Intake manifold, LMR Cold air intake, Flowmaster 3" stainless steel exhaust, NoWeeds Exhaust cutouts, Platinum Valve spring kit, ZEX NOS system 175hp shot, Eibach Pro-Kit performance lowering springs (1" drop all around), Custom grills, bumper ports, etc....
rgreene1971 is offline   Reply With Quote
Old 04-27-2015, 09:16 AM   #5
Eddie2SS
Eddie2SS's Avatar
So just power and ground to one single switch should work correct.
Old 04-27-2015, 09:25 AM   #6
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
It will work, just might be a bit more difficult to use. The idea of the momentary switch is to be able to come off switch to complete the burnout, plus some people use a light with the arming switch to let them know the system is armed. I used a remote control switch with a gauge light because I don't want a bunch of additional switches and lights in the cabin.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes.
CamaroCracka is offline   Reply With Quote
Old 04-29-2015, 09:44 AM   #7
Merc
In The Circle
Merc's Avatar
I kept mine super simple no holes drilled. Keep in mine I only use the line lock for track use only. To activate system I just put a fuse in, plug the switch in and tape it to the park brake handle. When I'm done I do the reverse and throw it in my helmet bag. Works mint.
Old 04-29-2015, 09:45 AM   #8
CamaroCracka
That's pretty cool, never thought about using a fuse as an arming switch.
Old 04-29-2015, 09:51 AM   #9
Merc
In The Circle
Merc's Avatar
Yep I just used a piggy back plug on an existing fuse. Don't remember what I piggy backed on off the top of my head. Just know it works with no issue. I also pull the fuse and mini relay to disable the ABS system as well. ABS does not like line lock.
Old 04-29-2015, 11:08 AM   #10
CamaroCracka
Can you enlighten me on what fuses those are?
Old 04-29-2015, 10:30 PM   #11
Eddie2SS
Eddie2SS's Avatar
OK, so I'm still having a rough time installing this line lock I'm trying to plug into a spare one of the side fuse panel. It just burns the fuse. Is this because i do not have an inline 4A fuse ?
The solenoid is grabbing this same 12V form where the switch is getting it by using this splice.
Any thoughts, am I only missing the inline Fuse?
Old 04-29-2015, 10:41 PM   #12
Merc
In The Circle
Merc's Avatar
Yes I can. I look tomorrow and post a pic. I also jump my fan relay so I can run fan without ignition turned on for cooling.
Old 04-29-2015, 10:46 PM   #13
Merc
In The Circle
Merc's Avatar
Attachment 712728
Attachment 712729
Attachment 712730
Attachment 712731
Attachment 712732
Not sure what your issue is other then a short if your popping fuses.? I used the same piece your using at the fuse box. That's only fuse in the system. Have another look at the wiring diagram.
Old 04-29-2015, 10:53 PM   #14
Merc
In The Circle
Merc's Avatar
BTW the on connector on your switch is really flackley.
