03-21-2015, 12:56 AM | #1 |
Drives: 2011 Camaro 2SS Join Date: Sep 2014
Header and exhaust ?
We are trying to install a BBK 1-3/4" Full Length Header Systems @ Phastek Performance and a flowmaster 3" - Cat-Back Exhaust #817609 - Outlaw American outlaw, as you can see these two do not match up where you could just place a clamp and that would be the end of it. Can I just cut the pipe where it is welded on and insert the other 2.5 pipe and weld the two together. Would this affect sound and/or performance? the opening for the o2 sensor have to point slightly up correct? Any help would be greatly appreciated as we would try and install tomorrow morning.
03-21-2015, 07:55 AM | #2 |
Drives: 2010 Turbo LS3 Join Date: Dec 2009
Wouldn't you just use the stock clamps that come behind the cats for that joint?
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes. |
03-21-2015, 09:40 AM | #3 |
Lurking in my SS
Drives: '14 2SS/RS L99 Join Date: Jul 2014
I think you are supposed to use stock clamps for that. that should be right
03-21-2015, 09:41 AM | #4 |
Drives: 2014 chevy camaro 1ss rs auto Join Date: Oct 2013
The stock connection on the car right now works perfectly in that connection.
03-21-2015, 09:41 AM | #5 |
Lurking in my SS
03-21-2015, 10:05 AM | #6 |
Awesome, thank you guys for the input. This certainly makes it much easier.
