02-25-2015, 02:47 PM | #1 |
Drives: 2011 Camaro 2SS Join Date: Sep 2014
Will this tire fit
2010 2SS/RS LS3, will 315/35/20 fit on the rear without affecting performance/fitment. In case this is too wide what other sizes do you guys recommend. Just looking into making rear tires wider. (posting this for a friend)
02-25-2015, 03:36 PM | #2 |
All About That Speed
Drives: 2010 Camaro 2SS/RS Join Date: Mar 2013
If you haven't changed the wheels, then I would recommend the stock size for the 20x9 rear wheel - 275/40-20. Any wider and you would really be paying more for a tire and not really increasing the contact patch. Just my .02.
2010 SS M6 | 416 CI | H/C/I | GPI TUNED | SNSSTR |
02-25-2015, 07:36 PM | #3 |
2010 transformer
Drives: 2010 ss camaro Join Date: Nov 2014
Square tire it fits nice
2010 transformer, vertical doors, 315nt05 rears, pedders supercar coilovers, hotchkis sway bars, links, adjustable, toe bars, bmr poly cradle bushings, 1le control arms, bmr tunnel brace, bmr subframe connectors. Cam 227/239-623-620@114 Mast medium bore heads, sw 1 7/8 headers, cat delete, x pipe, 3" dynomax true duals, fuel rails, fast 102 intake and NW 102 throttle body, catch can, rotofab cai, shifter, raptor custom shift light. Dss drive shaft, 3.91 gears. 492 rwhp
