01-17-2015, 03:32 PM | #1 |
Drives: 2011 Camaro 2SS Join Date: Sep 2014
Installing headers
Install instructions says to remove 11mm bolt from steering shaft and mark shaft and rack for realignment when reassembled and disconnect from steering rack is this the bolt on the picture I took it off but don't know what else to do
01-17-2015, 03:36 PM | #2 |
Drives: 2011ss/rs camaro Join Date: Sep 2011
You may not need to disconnect the steering shaft..on mine,the header slid right in without unhooking the shaft.....also look in the DIY section for header install
. OBX LTH,Rotofab,Magnuson Heartbeat.AEM wideband, HP Tuners
01-17-2015, 03:42 PM | #3 |
Drives: 2011 Camaro SS/M6 Join Date: Dec 2013
Yeah mine slid right in place as well. If you don't have to touch it let it be.
2011 Ls3. Slp TSV2300. 8PSI. 3.4 Pulley. Livernois Twin Fuel Pump. Id850 Injectors. Slp 1 3/4 headers. CAI Cold Air Intake. 3inch exhaust. V-Maxx portted throttle body. Night Fury cam. Lpe 391 gears. Fj performence tune. 643rwhp 574rwtq
01-17-2015, 03:44 PM | #4 |
Drives: 2010 Camaro 1SS LS3 Join Date: Jan 2015
I was able to slide the driver's side shorties in from above. The passenger side had to be done from below, and that too was done without issue.
Keep trying different angles... |
01-17-2015, 03:48 PM | #5 |
Moderator
I did not remove any steering equipment for my install.
RDP Motorsport//GEN5DIY//Cultrag Performance//JPSS//Rodgets Chevrolet//
Operation Demon//Buy at Invoice//RACECARWEAR RESPECT ALL CARS. LOVE YOUR OWN. warn 145:159 ban |
01-17-2015, 03:49 PM | #6 |
01-17-2015, 03:51 PM | #7 |
Ok I'm gonna give it a go.
01-17-2015, 03:59 PM | #8 |
Drives: 2010 Camaro 2SS/RS LS3 IOM Join Date: Aug 2012
For my ARH long tubes, we did disconnect the steering shaft to install from below.
01-17-2015, 04:41 PM | #9 |
Drives: 2010 Turbo LS3 Join Date: Dec 2009
Not to be a dick, but did you mark the shaft along the bolt?
You need to mark both sides of the shaft lengthwise so you can put it back the way it was and your steering wheel will be centered when you put it back together. I disconnected mine according to the instructions too. Might have been able to do it without that, but I was working alone and did not want to have to wrestle the header.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes. |
01-17-2015, 05:02 PM | #10 |
I installed 2" headers and had to remove mine....but if my car was like 6" higher I wouldn't have to....BUT if you do remove it make sure the steering wheel isn't locked or else it will be a bitch to take off...otherwise it should slide right up
2013 VR Camaro 2SS/RS LS3
Small, but effective mod list: Roto-Fab Intake, TSP 2" Long tubes, TSP catless mids, MSD spark plug wires, stock catback, Elite Catch Can, APEX washer relocation and scoop, VMAX throttle body, Diablo InTune-Tuned by Matt@FSP, and a JacFab license plate bracket. |
01-17-2015, 05:07 PM | #11 |
Drives: 2011 camaro ss Join Date: Aug 2014
I installed mine Thursday night after work..got off work at 5, had them done with car running and off my lift by 6. These are by far the easiest headers I've ever put on in my mechanical career so far. You don't need to undo the shaft man, they practical fall in and out. You'll love the outcome man
01-17-2015, 05:18 PM | #12 |
Driver side done I took out the bolt but did not remove anything. I did have to raise it up quite a bit buy also am doing it by myself. IF I had a helper I would probably have gone all of it already but it does seem pretty easy
01-17-2015, 05:31 PM | #13 | |
Cai Intake, Pacesetter Ceramic Coated 1 7/8 Long Tube Headers and Legato axel back exhaust.
01-17-2015, 06:24 PM | #14 |
Drives: 2014 1SS/RS, 2018 Silverado CC Join Date: Apr 2014
What headers did u go with? Are u using a jack and stands?
