Old 06-26-2022, 09:55 AM   #1
nicserrentino
Drives: 18 camaro zl1
Catch can question
Okay so I’ve got a Mighty Mouse wild catch can on my zl1, I didn’t install it, that was done by a shop. My concern is its location. Every other car that I’ve seen with the catch can has it located up front in front of the engine yet mine is to the side. It also is connected straight to the valve cover where you’d add more oil to the engine. Is this correct/okay?
nicserrentino is offline   Reply With Quote
Old 06-26-2022, 10:21 AM   #2
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
Yes it has mounts for either spot. It’s mostly up front because people add reservoirs in the spot where yours is. Also, since you have stock valve covers they just used the adapter that goes on the oil fill.
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90
catch can, mighty mouse
