05-22-2022, 05:09 PM | #1 |
Drives: 2014 2SS/RS 6SP Ashen Grey Join Date: Aug 2021
Best Braided Brake line kit for a 14 2SS Manual.
I am looking for Braided Brake lines front and rear, what is the best fitting kit out there? Thanks
GM 3.91/TrueTrac OEM ZL1 Rims, Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,Remote Clutch reservoir
GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, Moroso Catch Can GC Aluminum DS Stainless Works Ceramic LTH/HiFlo Cats SCT X4 Dynosteve, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights AeroForce Dual gauge/Autometer pillar mount. |
05-22-2022, 07:10 PM | #2 |
not afraid of the wall
Drives: Camaros Join Date: Apr 2010
My stop tech have been fine.
2023 1LE 1SS BCD GCF JF5 MN6 SIA SLN UQT
10/13/22: 1100 Past Camaros: 13 1LE|02 SS|01 Z28|00 SS|91 1LE|91 Z28|89 IROC-Z |
05-23-2022, 12:26 AM | #3 |
Spiegler brakes lines.
05-23-2022, 11:51 AM | #4 |
i have stoptech too!
05-23-2022, 02:12 PM | #5 |
Drives: 2010 Turbo LS3 Join Date: Dec 2009
Goodridge went in easy when I did the ZL1 upgrade.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes. |
05-23-2022, 05:48 PM | #6 |
Drives: 02 Camaro B4C Join Date: Nov 2016
A man's garage is his castle
1969 Camaro SS 1970 Camaro SS 2002 Camaro B4C 2014 Camaro SS Dedicated Track Car 2015 Camaro 1SS 1LE 2008 HHR SS 1996 Silverado Crew Cab Long Bed Dual Rear Wheel |
05-23-2022, 08:12 PM | #7 |
What about these?
https://www.phastekperformance.com/R...ines-5blbl.htm I read I can order ones for ZL1 and use them on SS or ZL1 Calipers? But not the other way around?
05-24-2022, 07:04 AM | #8 |
I’ve not looked into the specs that deeply, but if that’s correct, then just get the ZL1 kit because then you’ll be prepared if you decide to upgrade to ZL1/Z06 six pistons.
05-24-2022, 08:20 AM | #9 |
Drives: 2015 Z/28, 2015 1LE Join Date: Feb 2017
05-24-2022, 08:05 PM | #10 | |
Drives: 2011 2SS/RS M6 VR Join Date: Aug 2011
05-24-2022, 09:15 PM | #11 |
So the only difference in the kits is the Front ZL1 are longer?
05-25-2022, 09:28 AM | #12 |
Yes, on the SS caliper the connection is made near the top of the caliper. The ZL1 front caliper the connection is toward the bottom of the caliper. The flexible part of the brake line starts from the frame and connects to the support on the strut, then from there goes down to the connection port on the caliper. So the brake line sort of flows down from the frame to the caliper. Since the ZL1 connection port is lower, the line has to be slightly longer. The banjo connections are pretty much the same size. The stock ones on a '11 are square and Goodridge are round on my ZL1 and SS lines, but it's the inside diameter that matters.
05-25-2022, 06:58 PM | #13 |
Do the Goodrich lines have a sleeve/Coating over the braided part
05-25-2022, 07:12 PM | #14 |
That’s pretty standard on any braided lines I’ve ever seen for any car.
