04-21-2022, 02:40 PM | #1 |
Drives: HBM ZLE Join Date: Aug 2017
Dyno results
Posted up in the member journal section but thought I'd put it in here as well. Upgrades are,
2" csp headers Big gulp 103 tb Ported blower Ati balancer w/ 8.6 lower Flex fuel sensor Jms booster Ported heads w/ new valvetrain including CHE trunnion upgrade Custom LT4.R Camshaft w/ 38% fuel lobe PLM heat exchanger Upgraded intercooler pump Katech oil pump LME timing chain guide ARP hardware E60 Blue line E20 Red |
04-21-2022, 03:26 PM | #2 |
Oh Oh it's Friday Night!
Drives: 2018 ZL1 1LE Nightfall Gray Join Date: Jan 2018
Wow! Really impressive HP and torque curves. Not peaky at all. Great build of power at usable RPMs. That torque curve is nice and flat. A beast!
Four that wanna own me Two that wanna stone me One says she's a friend of mine... |
04-21-2022, 05:27 PM | #3 |
Drives: 2019 Chevy Camaro ZL1 M6 Join Date: Jul 2019
Congrats! That’s an awesome build. You’re gonna love that torque curve!
And done just in time for summer.
Kong Stage X Port, NW103, LPE HPFP, XDI +30 Injectors, ARH Headers, Flex Fuel, JMS Booster, AWE Touring, Elite E2-X CC. Stock heads, stock cam, stock pulleys: Tuned by KingLT1. 740whp Uncorrected on e50
04-21-2022, 06:01 PM | #4 |
Wait, you can't drive that in Ca!
'20 ZL1 1LE A10,
04-21-2022, 06:20 PM | #5 |
I sure can't
04-21-2022, 06:45 PM | #6 |
Drives: 2017 Camaro ZL1 A10 Join Date: May 2012
Those are some really good numbers. Did they pull in 6th or 7th? If it was 6th then your reading is probably about 20 RWHP lower than it would be in 7th.
Also which port job was that? X or comparable to X? You could probably gain a bit more if not!! |
04-21-2022, 07:55 PM | #7 |
Ran in 4th gear as it's an m6. Porting done by modern airflow dynamics, which from the pictures I've seen is comparable to Kong X port.
This was also the last pull i believe and was starting to get pretty warm. Better air or cooler MAT temps and it should make even more but the tuner says its running great with the log to back it up. Can't wait to go pick her up |
04-21-2022, 08:01 PM | #8 |
Also to note, at e60 both low and high side held strong with no drop at all. 13.5 psi of boost I believe it was. The jms with the 38% fuel lobe are working great
04-22-2022, 07:52 AM | #9 | |
Dyno Show Queen LOL
04-22-2022, 09:46 AM | #10 |
Drives: 2019 ZL1 Riverside Join Date: Apr 2020
Amazing numbers, just needs an aftermarket blower (the primary weak point on this motor, aside from the crappy oil pump) and it would be perfect
04-22-2022, 01:01 PM | #11 | |
Zx10, I'm ok with the factory blower right now. We'll see how temps are with the cooling mods but I think it'll be ok with an occasional track day and back road driving |
04-22-2022, 02:02 PM | #12 |
The bigger blower was a lot more necessary a couple of years ago. Like everything else, aftermarket technologies have evolved. With technology advances in porting and cooling systems staying with the 1.7L is a much more viable option. You can make plenty of repeatable power with it and it still hits harder than the bigger blower. Some people want that (me included).
04-22-2022, 02:44 PM | #13 |
Thank you Al Oppenheiser!
Nice build and result, OP!
04-22-2022, 03:51 PM | #14 |
Drives: 2017 zl1 Join Date: Apr 2021
No Aux pump? Just cam for high side?
KOOKS LONG TUBES AWE EXHAUST ROTOFAB FLEX FUEL 55% E TUNE PORTED THROTTLE BODY |
