04-08-2022, 07:36 PM | #15 |
Drives: 2016 2SS White w/blk whls, MRC, 6sp Join Date: Mar 2017
Since I already have a set of black wheels for winter, I am looking for something different for the other seasons, like this from OE Creations PR126 Z28 (Phasetek). Opinions are welcome:
04-09-2022, 09:04 AM | #16 |
Drives: 2021 LT1 6spd Join Date: Nov 2020
Those are beautiful rims, I went for the MRR version of those,but in black. I don’t think you can go wrong.
Current: 2021 LT1 Camaro, 6spd, Crush, Corsa NPP, GMPP CAI, Soler Performance Throttle controller
Previous: 1997 V6 Camaro, 5spd, Black |
04-09-2022, 11:10 AM | #17 |
Drives: Chevrolet SS 1LE Join Date: Oct 2019
Same as 1LE offsets: 20mm front and 43mm rear. Some wheel sets come with 23mm offset up front, which seems to fit fine, especially if you don't have MRC dampers. I actually run 5mm spacers on my 23mm front 19x10 MRRs, but I also put extended studs in my front hubs to accommodate that. You can just get away with the stock studs if you use spacers no thicker than 5mm, but again you shouldn't need spacers at all to run 23mm offset up front.
Matt Miller
2020 SS 1LE |
04-09-2022, 05:43 PM | #18 | |
Drives: 2020 Camaro 2SS A10 Join Date: Jun 2018
When it comes to offsets generally I believe within 4mm difference is ok, much over 5+mm and it becomes a problem. But it also depends on the car/year/trim/features as others have mentioned. 1LE's have the 6-pack front brake system which is bigger than our standard 4 piston brakes. That in itself can cause some concern where offsets are involved. But as you don't have the 1LE like me, You should be fine with the 23 offset, it might be a problem if you had the 1LE 6 piston brake system on the front in addition to what Msquared mentioned regarding the Magnetic Ride which only comes on 1LE's or as an option. The important thing when it comes to tires, do your research. Some people swear by certain brands, others like myself. I'm experienced with Eagle F series tires, so I trust them, and I know their performance level. The Eagle SC3R (Another tire you don't use in rain) actually has a better rating on track use than most other brands with notable exception to the Michelin tires I believe, but that performance margin is negligible at best.
2020 Camaro 2SS A10 | Rebuilt by: CBI Street Cars | 2" SE LT Headers | 3" SE X-Pipe | 3" MBRP Axle-Back | Pri & Sec Cat Deletes | K&N Typhoon CAI | LT2 Ported | 95mm ZR1 TB | DOD Delete | BTR Stage I Cam | ECM, TCM & E85 |Tuned by: Shane Hinds | Dyno: 510 rwhp 472 rwtq
04-10-2022, 07:47 AM | #19 |
@Whiterocket
This video gives you a pretty good idea of where the top tire choices are in terms of performance. With exception to Michelin which I haven't found a video for yet with the horsepower range these are being tested at. Note: These tires are probably more suited for straight runs and not so much turn races. Again these tires you probably do not want to use in rain, and they don't last long and wear out fairly quickly within 6000 miles I believe. As I mentioned before I chose SC3's because I'm used to them. They have a 180-220 tread wear, and at my hp level, it is easy to spin them, but if you ease into it like they say in this video, they work at 305 width. The SC3's are also better in rain/wet roads similar to the Michelins but I think Michelins have a slightly higher rating in wet performance. Probably better if I went to 315's and since I'm interested in drag racing and not turn racing, I would probably throw on the R888R's when I go to the strip.
04-10-2022, 08:22 AM | #20 | |
By the way, those Toyos sound like a vacuum cleaner attached to an already loud monster truck, you won't want to drive on those on the street. Not sure about the MTs, I never had them.
04-11-2022, 08:04 AM | #21 | |
Matt Miller
2020 SS 1LE |
Tags |
summer tires, wheels |
