03-21-2022, 07:26 PM | #1 |
Drives: 2011 2LT RS Join Date: Oct 2018
How to Identify Blend Door Issue?
So recently my AC does not want to blow cold air at all. Its not heat but its not cold, if that makes sense. Heater also works fine. And yes, I made sure the AC was on max, with circulation on and the snowflake.
Over the past couple of month at random times I would hear a weird noise coming from what sounded like the middle of the dashboard. It sound like "WHOOOOP" (best way I can describe it) and it would sometimes last a split second or a few seconds. I haven't heard it in about a week or so but my AC was still working fine while this was happening. I really do not want to pay $2k+ to get this blend door fixed and I would much rather do it myself. Before I start taking out the front seat, is there any way to specifically diagnose the issue as the broken blend door? I would hate to get in there and see it perfectly intact. Edit: I should mention too that I only have 83k miles on my 2011, if that makes any difference. |
03-21-2022, 08:58 PM | #2 |
It don’t come easy.
03-21-2022, 10:09 PM | #3 | |
I ordered an endoscope camera and just going to put that through the vents and see if I can see the blend door that way. Last edited by choffhous; 03-21-2022 at 10:25 PM. |
03-22-2022, 06:04 AM | #4 |
You say the heater works fine, so does the temp get warmer when you turn the dial to max heat and get less warm when you turn it back? If so then the blend door is moving/working.
A way to test if a/c is good is when the windshield is foggy set it to defrost with snowflake on and circulation off, temp at any warm setting, if windshield clears then a/c is working. |
03-22-2022, 08:36 AM | #5 | |
Drives: 2015 Z/28, 2015 1LE Join Date: Feb 2017
03-22-2022, 10:10 AM | #6 | |
03-22-2022, 10:13 AM | #7 | |
