10-31-2021, 06:22 PM | #29 |
Drives: 2016 1SS A8 Camaro with MRC and NPP Join Date: Oct 2016
Right now the setup is just a JMS for the low side and then an AEM Watermeth system but I have the LT4 parts ready to go in.
Also the Baro breakout is a must for proper tuning. -Jon
2016 HB Camaro 1SS A8 with MRC and NPP 398rwhp/389tq stock #s(11.84 @ 117 DR only, ECS boost 550rwhp/510tq (dynapack #s) , same boost + AEM water/meth + ARH Headers/mids 600 rwhp+ (dynojet #s) TTP)10.8 @ 129.
2020 Ford Explorer 2003 SVT Cobra Coupe (just your average KB Terminator Cobra). 2013 Focus ST (e30 Tuned). 2004 Dodge 3500 Cummins Dually 6 spd manual (tow rig). 1997 Jeep Cherokee (Lifted and Locked XJ off-road rig). |
10-31-2021, 07:04 PM | #30 | |
-Jon
11-01-2021, 06:10 AM | #31 |
I had this same kit, and I cannot see how you'd expect to run 1.4 short times with the stock torque converter and your existing setup. You did 1.60 on a nice cool day, correct? That was Paxton with base pullies, headers, water/methanol injection, and drag pack (referring to way it is)? Mine had Paxton with base pullies and a drag pack and did 1.63 on a warm day for reference.
11-01-2021, 06:28 AM | #32 | |
Drives: 2019 Camaro 1LE Shock Candy Join Date: Mar 2016
https://www.camaro6.com/forums/showthread.php?t=531002 DIFF THREAD BUT MORE INFO AND DYNO SHEET
103 Katech TB, KATECH Custom Heads, DSX In-line fuel TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM Diamond Piston & Manley Rods, Roto Fab Big Gulp BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane. 2014 Mini Cooper countryman S All4 M6 daily driver |
11-01-2021, 10:10 AM | #33 | |
I was just saying I think it could be possible but not likely and not trying to break something anyway. -Jon
11-06-2021, 05:26 AM | #34 |
Drives: 2020 LT1 Join Date: Dec 2019
I've got a flex sensor. Previously when tuned on E, they dump ignite E90 in the tank. Could they be weary of tuning on that, and then sending me on my way and I potentially get a shit tank of pump E? Isn't that what the sensor is for? I'd like a mix of E at a minimum to keep the stock pistons alive for a bit.
Its great to hear more positive reviews on this kit, im pumped. |
11-06-2021, 07:22 AM | #35 | |
11-13-2021, 12:27 PM | #36 |
Drives: 2017 camaro ss 1le Join Date: Oct 2021
Here is my invoice for the 10 rib 2200hd kit from ECS. Around 8500.
I’ll order closer to Black Friday to try and get a deal. This should suport 1000-1100 whp. I will be on a meth tune as well once it all goes in. Edit: I will be running 93, smg aux kit and meth lt4 injectors and high side. |
11-13-2021, 01:47 PM | #37 | |
Drives: 2016 Camaro 2SS Join Date: Apr 2018
11-13-2021, 05:33 PM | #38 |
That’s great question I’ll ask them Monday, is there a distinct advantage one way or the other, other than a couple hundred less on oil lines? Engine that’s going in already has a bung in the oil pan.
11-13-2021, 09:07 PM | #39 |
It's just less tedious and slightly cheaper. The HD does have a better bearing so it can be spun a little harder. Since you already have a bung in your pan might as well stick to the HD version.
11-14-2021, 08:28 AM | #40 |
Nice will do. I’ll post the dyno when it’s all wrapped up.
11-22-2021, 06:47 PM | #41 |
Drives: '18 SS 1LE Join Date: Jun 2021
Any feedback from anybody in here on how this kit drives on the street, with minimal supplemental mods and low boost?
01-23-2022, 07:46 AM | #42 |
Drives: red Join Date: Jun 2016
I just finished installing my ECS kit. Install is not hard at all. I bought my kit through GPI with my military discount and only paid $5,200 out the door. At a glance the kit looks so good on the car. The intercooler is massive. The filter for the head unit looks like it belongs there with how it’s shaped it also has the heat shield underneath the blower to help with temps. My friend with a 416Ci F1A blower was geeking over the little things the ECS kit has. Issues I had: the blower kit took nearly 4 months when i was told only 8 weeks, the kit was missing a bolt and washer for the pulleys, the brackets for the intercooler needed bending to get on to crash support studs. I’m looking to make around 600 on the dyno. It will have headers, intake and a bunch of meth. I also did LT4 injectors and hpfp. IMO it’s a good buy.
