08-19-2021, 04:01 PM | #57 | |
Drives: 2SS 1LE Join Date: Oct 2011
But, for these reasons, I didn't get 19"s for my stinger, I went with some nice 18s from tire-rack and some 255 tires, keep ride quality, possibly give up a little in sidewall stiffness, but much bigger contact patch than OEM and should be better wet handling (I might wet-autoX it). No reason really to go to 19s on that car. Yes, some people love how they look...but when your brakes aren't that big, IMO it just amplifies your small brakes with a bigger wheel. People have a hard-on for big wheels though, that and lowering cars to the point where they are non-functional as far a suspension. I don't see these things reversing. The trend with auto-makers is to cram the biggest damn wheels and tires you can in there for aesthetics. The RS6 Avant has something like 22"s...wth? The 19" winter wheels on my Camaro make a difference for acceleration that I can feel.
2018 2SS 1LE 2023 Colorado ZR2 2022 Stinger GT-line AWD |
08-19-2021, 04:55 PM | #58 |
my buddy has a set of 18s and 19s with same tires for his 1le next auto x he does he is going to do some tests to see which hes faster on but he doesnt think there will be much difference if any...
08-19-2021, 05:23 PM | #59 |
Yeah, I'd look for a lot more difference between say 18 and 20.
08-19-2021, 05:57 PM | #60 |
Drives: Buick, Toyota Join Date: Aug 2021
I certainly went with the black 20's on my recent 2022 Camaro order mostly for looks. If I could have got black rims in 18" I would have though. But, a little extra contact patch in cornering has to help, right?
08-19-2021, 06:10 PM | #61 | |
Drives: 2022 Kia Stinger GT2 Join Date: Oct 2019
The 18s and the 20s have the exact same tire width on the V6 model. So unfortunately you aren't getting much handling advantage (if any) out of the 20s, besides them having a stiffer sidewall. The disadvantages of the 20s is that they are heavier, the tires are more expensive and a harsher ride. They do look better than the 18s, though. |
08-19-2021, 07:36 PM | #62 |
376 cubic inches of fun
Bigger wheels=more weight.
For handling, more unsprung weight=less traction when cornering on bumpy roads. At the strip, wheel weight=2 to 3 times the inertia of non-rotating parts. Unless you need the bigger wheels to clear large brakes, don't switch. |
08-20-2021, 09:33 AM | #63 |
Drives: 21 Camaro RS manual v6.Tyota Tacoma Join Date: Feb 2021
The run flats on 18" wheel weigh 36 lbs.Run flats on 20" weigh 31lbs.Boh good year all season.After 13k miles my rs tires are handling much better.My replacement will be non run flat,26-28lbs or 18"×8.5" wheel 21.4 lbs ,18" tire weight same as 20".
08-21-2021, 07:25 AM | #64 | |
corner barstool sitter
Drives: 08 Mustang GT, 19 WRX Join Date: Jul 2012
Makes today a good day. Thanks Norm
'19 WRX 6M (the family sedan . . . seriously) |
08-21-2021, 09:36 AM | #65 | |
Ahhh. Damn. Now I wonder if I should have just went with the stock silver 18's(and saved $800 bucks too)and got my own wheel and tire package later on? Love the look of the black rims though. Oh well. Too late now, Im pretty sure. |
08-21-2021, 12:31 PM | #66 | |
Whoah wait, the stock 18s are run flats now? I don't think they were run flats in the past? That's crazy. I'd still contend the stock 18s are a better wheel choice versus the stock 20s, especially when it comes to buying a new set of tires. |
08-21-2021, 12:37 PM | #67 | |
You could always ask the dealer if its truly too late. I'm sure you won't be the first person to request a change on your order. I know I mentioned it in the other thread, but I'd totally go for the NPP exhaust, especially if you cancel the black 20s. You could always get the silver wheels painted or powder coated if you want. Ultimately do what makes you happy! |
08-21-2021, 01:58 PM | #68 |
I think a gen 6 has never had a spare tire.I looked on tire rack,a245-50-18 good year run flat weighs 36 lbs.That makes a 20" make sense if you want run flat tires.They cost around $300 each. You can get a 18-8.5 ,21.4 lb. wheel and a tire 26-28 lbs. to fit gen6 for about $1500-$1800 with sensors ,set of 4.Stock 20" wheel 31 lbs.Non run flat 20" tire 26-28 lbs. The only place I would have for spare is back seat ,since trunk I use most of trunk.
08-23-2021, 02:07 PM | #69 | |
Drives: '18 LT Join Date: Jul 2021
Decided to stick with the stock 18s, dip them black in the mean time and get new tires. Swap for wheels come spring. Now its a matter of finding the right tires. Resolved to the possibility I may need a few mm in spacers given for a few months, from what I can tell the stock offset is 32mm. 255/40 for front is where I am but thinking about going wider in the rear slightly. |
08-31-2021, 10:53 AM | #70 | |
Drives: 2021 Camaro ZL1, 1970 BOSS 302 Join Date: Dec 2020
Gary |
Tags |
ride quality, traction, wheels |
