Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6)
Old 09-20-2019, 06:12 AM   #1
Hazem alnamat
Drives: Camaro 2012
6l50 transmission problem help help help
Hi guys i have a problem with my camaro in the automatic transmission 6speed since two months
The problem is when i put D and start driving the car, it move like 1 meter then the transmission slipping until its stops again the when try again to move it the same thing happens all over again
But when i put on tiptronic i can drive it normally the only thing that happens its a small slip between the first and the second gear
I change two whole transmissions including the tcm and i did a software update for all ecu's
And when i scan it on computer the is no trouble code every thing is good
And the problem never change
Any thoughts???!!!
Hazem alnamat is offline   Reply With Quote
Old 12-28-2021, 05:39 PM   #2
CCrowder
Drives: 2010 RS Camaro
I am having the same issue - HELP
Did you figure out what this was? I am having the same issue.
Please Help!
And Thank you!
CCrowder is offline   Reply With Quote
