12-14-2018, 10:35 AM | #1 |
Drives: LSx Powered Join Date: Oct 2009
ZL1 Whipple Supercharged: 820+WHP. HPA Build
2018 ZL1 A10 has the Whipple installed... going even further with a few other mods, this setup is beyond excellent!
Build Overview: HPA LT Camshaft & Heads HPA Low-side fuel system ALKY Control Meth. Injection ARH 2" headers Rotofab Intake 103mm TB ATI Overdrive Pulley Whipple Package |
12-14-2018, 02:58 PM | #2 |
Very nice! Looks great
12-14-2018, 10:17 PM | #3 |
Nice build.
2017 ZL1 A10: 8.84 @ 156 PB
2017 ZL1 A10: Previously FBO 756/761 (9.6 @ 143 1/4) SOLD-2013 ZL1 M6:BTR,LTs,IDs,ATI,RotoFab10.84@129 SOLD-2011 SS M6: Blower, Cam, Alky, LTs. |
12-17-2018, 08:50 AM | #4 |
Thanks for looking... more builds coming up!
01-09-2019, 09:18 AM | #5 |
Drives: The Zs Join Date: Dec 2017
Nice build. This ZL1 should be E85 capable just in case. So much more power.
02-14-2019, 02:22 PM | #6 |
A lot of gains in the E... Owner did not want E though. Solid setup with or without being flex fuel capable.
02-14-2019, 08:37 PM | #7 |
Drives: ZL1 1LE Join Date: Oct 2018
Has anyone installed a whipple and their tune only - no other mods? What were the gains?
02-15-2019, 11:19 AM | #8 |
Drives: 2017 Camaro ZL1 Join Date: Aug 2018
The Whipple as a standalone can max out the stock fuel system and cause lean issues in cold temperatures, which is why you see most people running an upgraded cam with it.
02-15-2019, 11:27 AM | #9 |
You'd need other mods to support it, namely fueling and likely Headers. Furthermore, the Whipple's efficiency range is at a significantly "turned up" level in supercharger RPM. Run at levels where the stock fuel system/setup could support it will lead to little to no gain in power. Spinning it into serious gain territory is going to require injectors and something like Katech's Xtreme DI belt driven pump or similar. Plus, you'll smoke the cats really fast running any kind of power through them which can be catastrophic for many reasons, long story short, you'll at a minimum need Intake/Fueling/Whipple/Headers in which case, I'd expect maybe a 100 HP gain over stock or less. I don't think it's worth it for the money spent on the Whipple vs pulley/porting the stock blower in similar fashion. The old design of the Whipple isn't very efficient, I'd keep waiting until 2650 results come in.
02-15-2019, 12:22 PM | #10 | |
Drives: 16' Camaro 2SS Join Date: Sep 2015
Interesting take.
Unless extreme budget is an issue I would recommend a Whipple/Maggie over a lt4 all day both for longterm HP capacity and better cooling/IAT’s right off the bat. The LT4 fuel system with a modified low side has proven capable of 1000+ whp on gasoline.... no need for a fancy belt driven fueling. Quote:
@DeathWatchCamaro on Insta
993whp Magnuson 2.3R 9.5 @ 145, Magnuson 2300, Full Weight 2SS, 17’s (810whp) |
02-15-2019, 01:07 PM | #11 | |
What you say is exactly what everybody that I saw thought would happen by running the Whipple, and that is less heat and better temps whilst making 100+ more HP but that wasn't the case. Turned out they made minimal more power whilst maintaining similar temps and once it was spun to the point of adding that 100+ more HP and the fueling mods were done, you were right back where you started on cooling with possibly a minimal advantage here again. As for the fueling, I'm pretty sure you'll need more than just a low-side to support that kind of power, for sure at least an overdrive fuel lobe, but that is an aspect of the LT4 I've yet to study thoroughly... My post was a bit vague on some of the language, hopefully some others can read through it. I maybe can better summarize it with a HP scale: 650 RWHP - Bolt on LT4. 700 RWHP - Bolt on/ported and/or cam LT4. 750 RWHP bolt on/cam/ported. 800 RWHP - Whipple/Cam. 850 - Whipple Cam/Heads. 900 RWHP - Whipple Cam/Heads/Meth/E. 950 RWHP - Maxed Whipple/Cam/Heads/E/Meth. 1000+ RWHP - ProCharger. I think if you are planning on bolting on an Intake/Whipple/Headers/Fuel setup, you might as well just stick with the stock blower and get it ported. I don't think the advantages are there for the Whipple at those levels. |
02-15-2019, 04:21 PM | #12 | |
One thing thats confusing is air is air and fuel is fuel....an LT4 blower is going to need the same "fuel" as you refer to it as a Whipple/Maggie etc. The difference is the LT4 will have to be spun harder to achieve it.
Most tuners would definitely give you the data that the average IAT's are much lower with a Whipple/Magnuson especially as you spin things higher. I don't want to see single pull dyno runs either. Talking about real life driving, running through the gears in real world conditions, etc. R.P.M. made 770whp on a Whipple, stock heads, stock cam, and meth. I guess at the end of the day if you are staying 650whp or under just keep the LT4 blower. The biggest decision for anyone with a Gen 6 Camaro is do I want to commit to the point of doing a cam or not. To me that's the ultimate pivot point. Quote:
02-15-2019, 06:21 PM | #13 | |
02-15-2019, 06:47 PM | #14 |
Thank you all for the insight...apologies to HPA for the hijack...my questions are not so much budget related as they are CARB concerned. Headers, fuel, custom tune, ported heads are not an option for me...hence the whipple and their canned tune question.
Thread Tools | |
