10-25-2016, 08:11 PM | #169 |
Drives: A10 LT4 Join Date: Aug 2016
10-25-2016, 08:25 PM | #170 | |
I used to be Dragoneye...
...That session lasted for about 3 hours straight. They burned through over a tank of fuel. Neither the manual, or automatic car experienced any cooling issues. The business circled in blue is a water-shield - or drip tray - for the enormous extractor-style hood vent. It stifles a little bit of airflow as a result. It is designed to be removed for track days to promote....."proper breathing". The new ZL1's hood vent is the most functional, efficient vent they've designed on a Camaro to-date. |
10-25-2016, 08:26 PM | #171 | |
Drives: '17 ZL1 Join Date: Dec 2015
However, if the M6 is geared anything close to how the manual is geared on the z06, most of the benefits of the A10 will only be seen on the drag strip. On most road courses, you'll only be in 2nd and 3rd gear, so that's a single shift. For daily driving, I would hope there aren't people routinely gunning it to 95+mph to their neighborhood bakery, which would require 2 shifts. So, for those who really want a M6, I don't think there's a whole bunch being given up vs the A10, especially if the fun factor of personally rowing cogs and/or adding aftermarket power with no reliability issues is of importance to them. Just my opinion though. |
10-25-2016, 08:33 PM | #172 | |
But gears and performance? There is a high level of power under the curve that the A10 is providing the car by keeping the engine up in it's peak power all the time with those short gears. The A10 car will be noticeably quicker around any track because of it. Consider exiting a corner in a M6 at 3500 rpms in 2nd...accelerate to 6200, shift to third...4800....accelerate to 6200..... Versus...exiting a corner in the A10 at 5500 rpms in 3rd...accelerate to 6200, shift to 4th, 5400, accelerate to 6200....shift to 5th, 5400...And each shift is so quick, it may as well not even be measured. |
10-25-2016, 09:39 PM | #173 |
Drives: 2011 2SS/RS LS3 Join Date: Nov 2011
The "new" manual trans should be excellent for the track as well:....I think the manual is worth waiting for a review on the track if you're not sure which way to go.....Info below is from previous thread..
http://www.camaro6.com/forums/showthread.php?t=444455 EQUIPMENT Let’s start with the facts. The engineers and designers working on the new ZL1 have revisited the successful formula from Gen 5 that we have come to know and love; just on an entirely different level. Power is provided by the new supercharged 6.2L V8, the LT4. We’re used to seeing this robust power plant serve in the C7 Z06, and the good news is that the Camaro team has said the power output in the ZL1 is “estimated at 640hp/640tq”…history would suggest that we can expect more when the final numbers are released. This nuclear amount of power is sent to the gorgeous new lightweight, 20” forged aluminum wheels by either a standard 6-speed manual transmission, or an available all-new 10-speed automatic. The 10-speed auto features TAPshift, and represents General Motors’ first use of the new transmission. Shifts are described as “lightning” fast, and there will be more information about this transmission coming soon. The six speed manual transmission benefits from active rev match and revised, track-oriented gear ratios that means there’s only one overdrive gear. Magnetic Ride Control makes a return appearance in the suspension system, and we’re told the calibration is further revised in this application. Also new is a custom launch control feature within the Performance Traction Management system. An electronic differential, Goodyear Eagle F1: Supercar tires (285 f, 305 r), and gargantuan 15.35” 6-piston Brembo front brakes round out the performance hardware featured on this car. And all of that equipment is bolted to the most recent version of the world-beating Alpha chassis, which translates into a ZL1 that is more than 200 lbs lighter, with at least 60 more horsepower and 80 more lbs. ft. of torque than its predecessor. No pricing or ordering details have been released. But we’re expecting that past ZL1 customers should be able to afford this new car. There’s a lot of expensive equipment on this car, but they have no intentions of price gouging just because they can. |
10-25-2016, 09:51 PM | #174 | |
10-25-2016, 11:27 PM | #175 |
Drives: ZL1 Join Date: Dec 2014
Good post.
10-25-2016, 11:32 PM | #176 |
The driver is one cool customer. Ran the tach to redline numerous times and didn't even look like he was sweating. That transmission performed magnificently. One great car is forthcoming from GM with their new ZL1. Can't wait for the Z28. Great video.
10-26-2016, 01:07 AM | #177 |
B.O.D. 02/16/10
Drives: 2010 SGM Sp. Edition 2017 RS Conver Join Date: Jun 2010
Yes I do. I am limited to 70 mph and handles like it is on rails!!! It is the most boring ride you will ever have lol!! The driver in the vid looks like he is driving a train. To cool, I don't ever see a wide eye moment.
10-26-2016, 01:13 AM | #178 | |
B.O.D. 02/16/10
10-26-2016, 06:25 AM | #179 | |
As for shifting on the road track, it's not how fast you shift like it is on the drag strip but more how much shifting the auto can do. Instead of 2nd 3rd only it's running through 4 or 5 gears and watching the video you'll see it rarely even dips out of the 5k rpm range. Now fun factor is a whole different story. |
10-26-2016, 07:06 AM | #180 |
Drives: Impala Join Date: May 2015
Went from 6 to midnight watching that video.
10-26-2016, 07:10 AM | #181 | |
Thanks,
Is there any viable reason to leave it on other than possibly getting caught in the rain / car wash?? Quote:
10-26-2016, 08:12 AM | #182 | |||
However - I agree with you on the manual transmission's prowess... The clutch pedal is about as light as the SS model...WAY lighter than last generation ZL1. It features rev-matching, a beautiful technology. And, first gear will run out to 60 mph. Should be fun! Quote:
But that media event in Nevada opened my eyes WIDE to the A10's capabilities. This video has pressed the point deeper into my head. I'm 95% certain at this point I'll be ordering an A10 version...but there's no doubt I'll miss rowing through the gears going around town. Quote:
The drip tray is part of a system designed to keep flowing water away from sensitive components in the engine compartment...easy to just keep it on. During daily driving, there's no reason to have a ton of extra airflow....on the track: There is. |
