Old 10-30-2023, 03:26 PM   #155
JSH
JSH's Avatar
Drives: '20 ZLE
Originally Posted by CamOnlyJabroni View Post
When I get my car back this week I will see how this fits. Turned out way nicer than I thought with this nice short radius 5 to 6 coupler. Maybe I need to come out with my own intake? Lol
I ordered their regular oiled filter too which is pictured. Itís big enough with that 6Ē inlet you most likely donít need a race filter at sub 1kwhp.
When are you going to install it?
'20 ZL1 1LE A10,
OEM short block, LME heads/valve train, E2650,
100+ octanes, no eth, no meth, no N2O,
2/23 - 1031/1004 wheel, tuned by KingLT1,
4/23 - 1.41/9.61/145 at DA 7000 ft. (only made five passes).
2/24 - LME 390, E2650, FBO, race gas.
Old 10-30-2023, 07:13 PM   #156
CamOnlyJabroni
CamOnlyJabroni's Avatar
Drives: 19í ZL1 A10 / 16í C7Z M7
Iím going to test fit it when I get my car back this week.
CamOnlyJabroni is offline   Reply With Quote
Old 10-31-2023, 08:01 AM   #157
hawk02
Coupe Newbie
hawk02's Avatar
Drives: 2017 ZL1, 2021 Corvette Convertible
Where did you order the coupler?
Old 10-31-2023, 08:12 AM   #158
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
WOW!!! That's slick!!! Did they just shorten the housing? Probably WAY overkill for me, but PDs don't like any restriction on the front, so... I wonder what tuning's like...
SUPER cool though, especially for you built guys. This looks very promising.
'20 ZL1 Black "Fury"
Magnuson Magnum DI TVS2650R // TooHighPSI Port Injection // FF // Katech Low Side // Soler 103 // PLM Heat Exchanger // ZLE Cradle bushings // BMR Chassis-Suspension Stuff // aFe Bars // Diode Dynamics LEDs // ACS Composites Guards // CF Dash // Aeroforce // tint // other stuffs
Old 10-31-2023, 08:24 AM   #159
CamOnlyJabroni
https://www.intakehoses.com/reducing...rt-radius.html
Old 10-31-2023, 08:59 AM   #160
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
They only issue I see is when you open up the MAF housing that much you start to deal with other issues such as low speed drivability from low MAF resolution. Think about how low in the MAF range idle/tip in will be with a 6" housing? Especially something with a mild cam or stock cam that idles 600-700rpm. Not saying it "can't" be tuned, but chances are it will take some work.
2016 NFG 1SS A8
Options-2SS Leather/NPP
Old 10-31-2023, 09:06 AM   #161
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
That's what I was thinking... Setting DYNAMIC AIRFLOW - HIGH RPM DISABLE higher doesn't account for too much, though, right, because the ECM's always looking at the MAF for AIRFLOW?
Old 10-31-2023, 09:22 AM   #162
CamOnlyJabroni
I was just doing it more to play around with and help the community out with a different option. My car is already eating the tires up in 4th more power isnít going to help matters on the street. If the length of the maf housing puts it in the right spot I will then be tempted to measure and notch the Big Gulp heat shield. I would first see if you were willing to see how much work the tune would take by just hooking the intake up with no heat shield first. I think the Cordes intake on the C7Zís works well on high HP because the entire intake tube including the MAF portion is 5Ē. I donít think the filter is the problem on the Big Gulp intake as much as the ID of the MAF housing. The filter on my C7Z is smaller than the Big Gulp on the ZL1.
Old 10-31-2023, 09:31 AM   #163
hawk02
Coupe Newbie
hawk02's Avatar
Thank you!
