Old 10-12-2022, 05:36 PM   #1
buckwam
Drives: 2021 camaro 1ls
GM lowering suspension upgrade kit
https://accessories.chevrolet.com/pr...tegoryId=12009
Any one install this kit on their 2.0 camaro? How did it affect the ride and handling?
buckwam is offline   Reply With Quote
Old 10-12-2022, 06:29 PM   #2
Davescamaro
Drives: Chevy camaro
I think I actually have this. They labeled it as a fe3 sport sypension package and I maybe wrong but it is 24mm lower than stock and handles a bit smoother on cornering. I don't know for sure since I've done all the multi rear links to BMR and made a HUGE difference.
2019 Camaro 1 LT 2.0 Riverside Blue Metallic, ZZP strut bar, K&N intake, ZZP catted DP, MRT axle back, Injen IC piping, Trifecta Elite tune, zzp heat shield, turbosmart diverter valve.
Knockoff zl1 sideskirts, gm front chin spoiler, 1le blade spoiler, diode sides, 20" staggered Asanti black labels, azenis 510 245/40/20 fronts, nitto 555 g2s 275/35/20 rears.
Davescamaro is offline   Reply With Quote
Old 10-12-2022, 07:22 PM   #3
buckwam
It came installed from the factory when the car was built?
Old 10-13-2022, 08:07 AM   #4
Davescamaro
I believe so. It stated sport suspension package. 24mm lowering springs, sway bars, and sport strut mounts. Dunno if thats it or not, but mine was a 1LT with bose speakers, sport suspension, sunroof, and optional 18" wheels. I think it was a custom order from the dealer. MSRP was 29,900. I got it for 24,800 for having a GM supplier discount and was an employee through their network at the time.
Old 10-16-2022, 02:56 PM   #5
SomeGeoffGuy
SomeGeoffGuy's Avatar
Drives: 2023 2SS Convertible
I think when you get that it is a dealer installed option, but it can be ordered with the vehicle.
-Geoff
'16 2SS Convertible - White on white, mag-ride, NPP, nav. Sold!
'23 2SS Convertible -Same as above except orange.
SomeGeoffGuy is offline   Reply With Quote
Old 10-18-2022, 02:01 PM   #6
Start The Machine
Start The Machine's Avatar
Drives: 2016 M6 2.0T
Yes, that is upgraded GM suspension from the factory or done by the dealer on site.
I got my 2.0 for $24,000 on a GM discount as well with 6 piston front brakes, HD cooling package, RS package, 8" touch screen, Bose system, sunroof, battery tender ect... Score! Wish it had the suspension upgrade though. I want to do that mod next.
How much better does it handle you think? Have you driven other 2.0's to compare it?
RS Package, HD Cooling Package, Brembo 6 Piston Front Brakes, SRP Racing Pedals, Soler Performance Throttle Controller, Dyno Tuned by Trifecta, Velossa Tech Ram Air, Mishimoto Intake, aFe Air Filter, Mishimoto Charge Pipes, ZZP 67mm Throttle Body, Trifecta T40 Stage 2 Turbo, JacFab Recirculation Valve, PTP Turbo Blanket, ZZP Catted Downpipe, Mishimoto Pro Cat-Back Quad Tip Exhaust, Mishimoto Catch Cans, Mishimoto Coolant Reservoir Tank, GM SEMA Grill, Ikon Motorsports Front Fascia Extension, Ikon Motorsports 1LE Spoiler, American Authority ZL1 Side Skirts, AMPP Quad Tip Rear Valance
Start The Machine is offline   Reply With Quote
Old 10-18-2022, 03:06 PM   #7
buckwam
I ordered the lowering kit last week when they were on sale at GM. The dealer emailed me, saying it is on 2-3 week back order.
Old 10-20-2022, 11:30 AM   #8
Davescamaro
Far as handling, I could not tell you between a regular and mine. It does hold good on turns, but didn't really test it til after I did a bunch of BMR stuff to it. Just need to go about .5" lower and those bilstein shocks then it will ride on rails.
Old 10-20-2022, 02:35 PM   #9
DriftNDraft
Drives: 2020 1SS 1LE M6 was 2018 V6 RS A8
The GM Lowering Kits for the LS/LT are to be used only if the car has 20-inch tires. The lowering kit specifically excludes cars with 18-inch tires. I can only guess it's because there may be suboptimal response due to sidewall flex using 18-inch tires with the lowered suspension.
From the Chevrolet Performance website:
PART NO. 84225252 /Camaro LT Coupe without 18” Wheels for 1LT/2LT
PART NO. 84225256 /Camaro LT Convertible without 18” wheels for 1LT/2LT
DriftNDraft is offline   Reply With Quote
