03-12-2018, 10:23 PM | #1 |
Drives: 2016 camaro 2ss Join Date: Apr 2017
Need Some Help after Headers
just installed some LT Headers just have one issue when my steering wheel in a straight up position, and i try to wiggle it its almost like theres something holding against it but i checked and its not touching the headers. what did i miss up? anything is appreciated, thanks
03-12-2018, 10:33 PM | #2 |
I believe there is other threads about this and some people had to change a bolt on the steering column because it was causing issues similar to that. Could be wrong but try and check out some other header discussions.
03-12-2018, 10:35 PM | #3 |
Drives: 2017 1SS camaro ,2SS a 68 + 08 C6 Join Date: Dec 2017
Lets hope you didnt whack the steering shaft upon install , they are a close fit on the primary right around that area . Theres also a bolt around the area also .
