07-04-2017, 04:41 PM | #1 |
Drives: Camaro 2SS Join Date: Jan 2017
USB stick requirements
Are there any size and file system requirements for a USB stick to work with the MyLink system? I just bought a 128GB USB3.0 SanDisk drive, copied about 25 GB of music on it, but the car doesn't see it, I can't see any folders if I try to browse.
Does NTFS work on this thing or does it have to be a FAT32 file system? Are there any size limitations? 128 GB is a bit large, but it should still work.
2017 2SS stock
07-04-2017, 04:43 PM | #2 |
Drives: Traded in 2016 BLUE VELVET 2LT RS Join Date: Aug 2016
FAT32, that is how my 64 gb sandisk is configured. Good Luck
07-04-2017, 09:58 PM | #3 |
Still not working in the car but it works perfectly on the PC. The stick came FAT32 from the factory and I copied all my music into a folder called Music. There are some other files that came with USB stick, but it shouldn't change things much.
THIS is the USB stick. What am I doing wrong ?
2017 2SS stock
07-04-2017, 10:04 PM | #4 |
Drives: 2016 SS M6, NPP Join Date: Apr 2016
Should be able to see the USB. Have you tried another USB stick to test to see if it reads it?
07-04-2017, 10:34 PM | #5 |
Yeah, nothing shows up under media. I tried in both USB slots.
I don't have another usb stick to try, but I tried a microSD card in an USB adapter )sort of like a memory stick) and that one didn't work either. Until now I had assumed it didn't work because the microSD with an adapter is not really a true USB stick. The USB ports on the car seem to work. Both charge and both could connect my phone with Android Auto.
2017 2SS stock
07-05-2017, 07:48 AM | #6 |
Drives: 2016 2SS Convertible Join Date: May 2012
The USB compatibility seems to be a little bit "hit or miss". I formatted two different 64GB USB drives identically and then loaded them both with the same music but only one of them works in my Camaro. If you search through the other threads you will find some that discuss compatibility issues and how other people solved problems.
07-05-2017, 08:14 AM | #7 |
Try reformatting it to FAT32 again with Windows. Then try it. Could be how the factory formatted the stick.
Past: '99 SS Camaro A4, '73 Camaro 383 A3 "Voices in your head are not considered insider information." 3800 Status - 6/16/16 (Built!) 6000 status - 6/29/16 (Delivered!) |
07-05-2017, 08:19 AM | #8 |
Has anyone figured out if there is a limitation to size? I had a radio that I bought recently that had a 32 GB restriction. Newer radios might have restrictions as well. Just a thought.
07-05-2017, 08:31 AM | #9 |
Drives: 2LT, Blue Velvet, Kalahari, Convert Join Date: Feb 2016
I've formatted a couple of Sandisk 16gb drives to FAT32 and they play consistently.
However, I noticed that only a small portion of the tunes play when in shuffle mode. There are repeated plays of the same small selection of tunes.
2LT, RS, V6, A8, Vert, Blue Velvet, Kalahari, Split Silver rims, Convenience & Technology pkgs
07-05-2017, 08:35 AM | #10 | |
Sent from my SM-G950U using Tapatalk
07-05-2017, 08:38 AM | #11 | |
How do you save a shuffled file? Are you using iTunes to create the playlist?
07-05-2017, 08:45 AM | #12 |
I use Windows Media Player, but bet iTunes will do similar. Essentially just add all your songs to a playlist in WMP, then there is an option to "shuffle the list" (instead of turning shuffle on for playback). Then save the playlist (m3u) to the Playlist folder on the stick.
07-05-2017, 08:53 AM | #13 |
Thanks.
07-05-2017, 06:35 PM | #14 |
Drives: 17 Camaro SS 1LE & 16 Sierra AT CC Join Date: Nov 2016
