08-07-2016, 11:47 AM | #1 |
Drives: 2001 Audi TT, 2016 Camaro Join Date: May 2016
Lessons Learned about the Hood Vents
Just thought I would pass along my self inflected issue with washing the car and the SS hood vents.
I washed the SS last weekend with my power washer like I've done a hundred times before with other vehicles. Opened the hood this weekend to see a large white stain in the hood insulation. The stain was dried soap flakes from soapy water traveling down the hood vents and soaking through the hood insulation. It's a mess! I've popped the insulation piece off and I'm now carefully rinsing the piece out with a hose to get the soap out. This is a problem in itself in that the piece is basically cardboard and too much water will destroy the piece. So its rinse a little bit, let air dry, rinse again. It does seem to dry out OK, but at some point I think I'll wash out enough binding glue that the piece could delaminate. In the future, I will be taping up the vent openings before I wash the car. |
08-07-2016, 11:59 AM | #2 |
Retired from Car mfrs....
No need to tape up, just hand wash the hood and sheet the water off with open hose - no nozzle.....
08-08-2016, 08:16 AM | #3 |
Well, once burned, twice shy.
Just a warning to others that it can happen with a power washer. A minute to tape up is worth it to keep this from happening again. Last edited by Atomic Ed; 08-08-2016 at 09:29 AM. |
08-08-2016, 10:46 AM | #4 |
Owning SSes for 50 Years
just curious why you would ever want to power wash your car? I might do that in the wheel wells and wheels but never the painted surfaces. Just my opinion, of course.
The new ride: 2023 Camaro, LT1, Sharkskin Grey
Previous Performance Cars: 1966 Chevelle SS 4M, 2010 Corvette 6M 1968 Dodge Charger R/T Auto 2012 1SS 6M 1982 Corvette Auto 2010 1SS 6A 1984 Corvette Auto 2016 2SS 8A 1999 Camaro Auto 2017 HBM 1SS 1le 2002 C5 Corvette 6M 2018 2SS 2006 Corvette Auto 2023 Camaro LT1 |
08-08-2016, 11:28 AM | #5 | |
Drippin' Wet Auto Detail
Pressure washers use less water than hoses and can get to heard to reach places. They also give you the ability to attach a foam cannon which greatly increases the amount of suds and lubricity while hand washing. But to each their own. |
08-08-2016, 02:25 PM | #6 | |
It's quick. (Maybe not so quick now that I'll tape up the vents.) I can wash and rinse my car in less time than you can fill up a bucket. I'm set up with a quick disconnect on the water outside my shop and can be up and running in short order. I also find that a quick wash after the sliming of 10,000 bugs is best, considering we hit over 100 degrees during the summer. Baked on bug juice is tough to get off. The point is just be careful not to get a lot of soap down the vents, regardless of how you wash your SS. |
08-14-2016, 07:18 PM | #7 |
I don't think it would hurt the paint since, it did, there would be an awful lot of law suits against the touchless car washes, but surely pressure washing removes wax and polish you might have applied. I used a sealer on my finish back in March and haven't waxed it since then and it still looks like I just polished it yesterday.
