01-13-2020, 11:27 PM | #1 |
weSS1LEy
Drives: 2015 camaro 2ss/rs/1le Join Date: Sep 2015
Start or don’t start in winter? Pros cons
Pros,
Lubes seals Circulates fuel Charges battery Shifts spring pressure to different springs Cons, Air fuel at idle is bad for cylinder heads? Dry start, but what time frame is considered a dry start? Weekly? Monthly? Sorry guys if this is done to death but it’s nice to always revisit for fresh ideas!
Rotofab, arh no cats, atak, elite cc, 94 octane tune, Mobil 1, phastek scoop, custom cam 230/243 .621 .604 114+4, related cam kit stuff. 470/435 rwhp/rwtq
01-13-2020, 11:33 PM | #2 |
Drives: 2014 2SS/RS Join Date: Jan 2018
I say it hurts to let it sit. Moisture builds up in the crank case and around components. I would always start it every week or two and let it come up to temp.
2014 2SS/RS LS3/M6
01-14-2020, 12:59 AM | #3 |
Take it from someone w/multiple classic cars.......never let them sit! If you can't put it on the road at least warm it up weekly if not more often. Machines don't do well when left idle for extended periods. A dry start does more damage than a 100 mile drive.
01-14-2020, 02:31 AM | #4 | |
weSS1LEy
01-14-2020, 03:46 AM | #5 |
Drives: Camaro 1LE Join Date: May 2018
Start it once a month and bring up to temp then shut her down. Weekly is excessive in my opinion.
01-14-2020, 06:01 AM | #6 |
376 cubic inches of fun
There are no pros to starting the car in Winter. You will never bring everything up to temperature idling in the garage. As a result, water will collect in the exhaust and build up in the oil.
Moisture will not build up from just sitting there. Apparently many people don't realize that the two main products of combustion are CO2 and H2O. The H2O will condense before it gets out of the tailpipe until the whole exhaust system is hot. Also your battery will not maintain charge from idling once a month. That's what battery tenders are for. Seals? My car sits for 6 months minimum every winter, now on its tenth one. No seal problems. Fuel? Before storage, put in a bottle of Sta-Bil, fill the tank, and go for a ride to get the fresh gas through the fuel system. Park the car and see you in the Spring. Speaking of springs, the springs operate well below the elastic limit of the steel and will not "take a set". |
01-14-2020, 06:47 AM | #7 |
weSS1LEy
Aha , see good info. I know I have read your posts on this before 👍
01-14-2020, 06:51 AM | #8 |
Drives: 2017 Mosaic Bk ZL1 M6 Join Date: Jul 2009
I'm with Rock-It Man. Never had an issue with any of my Camaros sitting out the 5 month winter in frozen upstate NY. Stabil, tender, air up the tires. Luckily though, I don't have to deal with that anymore.
01-14-2020, 06:52 AM | #9 |
Drives: 2018 1SS M6 Join Date: Nov 2014
Seems like there are two ways to do it. But do it right.
Fuel stabilizer and battery tender and let it sit. If you go with running it, bi-weely or monthly, don't just start it up and let it run. Pick a clear day, where the roads are clear and dry and take it out for about an hour so. Really depends an how your winters go, and if you are the type that can actually leave it alone for that long. Long hard winters, roads are never completely clear or dry? Park it Relatively mild winters with occasional snow, avg temps 32-40, enjoy it on occasion, so long as the tires can take it. (If you have a DOT track tire, park it) |
01-14-2020, 06:53 AM | #10 |
Drives: 2011 Camaro SS Join Date: Dec 2016
I don't start it unless I can drive it. Like Rock-it Man said, that just builds moisture. I never started my motorcycles during the winter, either. Just a battery tender, topped off tank of gas, and an oil change in the spring kept them going with no problem.
01-14-2020, 07:02 AM | #11 |
weSS1LEy
So ideally drive it. It seems like people have been ok on either side of this debate though. Starting vs not starting. Say if mine is in a heated garage then the condensation wouldn’t be as much of an issue if started?
01-14-2020, 07:23 AM | #12 |
Drives: 2015 Camaro 2SS RS 1LE AGM Join Date: Oct 2013
I always turn the engine over a few times before I start it to get the oil moving. Press gas pedal to the floor then turn the key, it will turn over but will not start. This is do avoid a dry start.
Sent from my SM-G960U using Tapatalk
2015 2SS RS 1LE NPP/w Kooks headers, Procharged, ID1050X injectors, Katech belt tensioner, Mighty Mouse Catch Can, BMR subframe connectors, Matco driveshaft loop, AEM Wideband/Boost/Fuel gauges , Z/28 Splitter and Spoiler/w Wicker bill, Power Stop rotors and brake pads, MRR Z/28 Rep Wheels 20" w/p zeros 285 fronts and 305 rears, ZL1 addons Rock guards and Tow hook, Rear window louvers, Flags on the quarter windows and the moonroof, Billet aluminum door handles.
01-14-2020, 07:24 AM | #13 | |
Drives: 2011 1SS/RS IBM Camaro Join Date: Jan 2011
01-14-2020, 07:26 AM | #14 |
Drives: 2011 Camaro 2SS LS3 Whipple Join Date: May 2019
I'm on the let it sit team. I can't drive mine for about 4 months while there is magnesium chloride on the road. It was 68 degrees here Sunday, I saw nice cars and bikes out. I cringed every time thinking about how much magnesium chloride they are collecting on their beautiful rides. That shit EATS metal at an incredible rate.
Whipple 2.9 CAI ID1050x injectors ZL1 Pump JRE FPCM JMS Voltage booster JRE Rough Idle blower cam BTR .660 springs CHE trunnion kit 1 7/8 Speed Engineering Borla Atak JRE scoop 1.5" lowering springs BMR trailing arms and toe links Cradle inserts 704WHP 603WTQ 93 octane
