11-22-2019, 05:49 AM | #1 |
Drives: 2018 ZL1 Camaro 6M Red Hot Join Date: Aug 2013
Battery Question
I have read quite a few threads both in the ZL1 forum and the general Camaro forum about bad batteries.
I am wondering if anyone has tried the Optima Yellowtop H6 in their Camaro? I have a little over a year left on my warranty and am thinking about just getting one of these at the 3 year mark for my car as a piece of mind upgrade. Anyone try one? How is the fitment?
People are a lot like slinky's: not very helpful most of the time, but they bring a smile to your face when pushed down the stairs...
11-22-2019, 06:03 AM | #2 |
Drives: 2019 ZL1 / LE , 2014 CTS V Join Date: Nov 2015
Ive had luck with the red tops. I cant speak for the yellows. Judging by there spec, the yellows always seem overkill for what I need them for.
11-22-2019, 06:10 AM | #3 |
Problem is, according to the Optima Battery website, they do not offer a redtop battery for the 6th Gen, V8 camaro.
The yellowtop H6 is their only offering... So, overkill or not, it is the only choice for Optima.
11-22-2019, 07:59 AM | #4 |
Drives: 2024 Riverside Blue 2SS 1LE Join Date: Mar 2016
The only advantage of the Optima is you can install them in various positions. I thought I would purchase one for my wife's car and they don't last any longer than a normal battery. So unless you have a special install need my opinion is you are wasting money.
11-22-2019, 09:27 AM | #5 |
Have had a lot of friends say the same. Overpriced in my opinion. I won't fork out the money for one and never will.
11-22-2019, 09:43 AM | #6 | |
Maybe Optima load tests every battery while it's in a paint can shaker and their products have better reliability. I bought a brand new AGM battery last summer that topped out at 12.4 V after it was charged on my spiffy NOCO charger (should be over 12.8 for a new AGM). Manufacture date was the same as the month I bought it. I returned if for a good one. Get your battery tested for peace of mind, but don't think a new battery guarantees no problems. |
11-22-2019, 09:44 AM | #7 | |
Drives: gas powered Join Date: Jan 2019
Counter point im on my 5th yellow top all of them have gone more than 9 years. The last one I have is at 10 and still in use in a vehicle that has headers so typical lead acid would last 3 at most. The heat would boil the water out. it also sits 3 months at a time and Im not much on charging. Its easily been discharged 10 times. When my battery in the Camaro needs replacing Ill probably use Optima.
11-22-2019, 09:56 AM | #8 |
Drives: Chevy Camaro Join Date: Jul 2019
I've always used interstate batteries, they are quality made and normally have a good warranty, especially if you buy them from Costco, they are a great replacement choice.
11-22-2019, 11:00 AM | #9 | |
Good info,,,Havent had the need to spec one out yet, hopefully I wont. |
11-22-2019, 05:20 PM | #10 | |
Drives: '17 2SS convertible'20 Yukon Denali Join Date: Nov 2011
Costco has the H6 batteries but they're not AGM, only regular lead acid. They told me that they should be carrying the AGM within a few months.
Richard
2017 2SS SIM convertible, A8, NPP, MRC, 56R wheels, GM CAI, Diode Dynamics Side Markers Delivered: 08/15/2016 #TeamBeckyD |
11-22-2019, 05:45 PM | #11 |
Retired from Car mfrs....
I also like the interstate batteries. I usually swap one out at the first time the Honda battery goes bad. If you’re regularly using your car and it’s not sitting for long periods, and you’re not in extreme heat or other things, a standard lead acid is fine. AGM’s are great for not discharging very much when in storage, but their reserves and longevity is about the same as A good lead acid battery. They are better when a battery is being constantly recycled, and in storage. Also they are essentially maintenance free..
https://www.solar-electric.com/learn...at%20Batteries Regarding optima, they went through a period 5 to 10 years ago where they really dropped in quality. I believe it was when they were shifting ownership, I haven’t heard any recent problems with them. I still would prefer an odyssey over an Optima. |
11-22-2019, 05:56 PM | #12 | |
11-23-2019, 02:34 AM | #13 | |
its mounted in the engine compartment. And just to correct myself there a gel mat battery not a flooded battery
11-23-2019, 09:02 AM | #14 |
While this is true, the yellowtop is an AGM battery. The acid is absorbed into the glass mat. So, it is far less likely to boil out than a traditional lead acid battery.
