Old 03-25-2020, 05:12 PM   #1
swisstyphoon
Former GM Technician
swisstyphoon's Avatar
Drives: 2018 ZL1 A10, 06 Silverado Duramax
DRL wiring diagram needed
Can someone please help me out with a copy of the drl wiring diagram?
2018 Camaro ZL1 A10
Rotofab Big Gulp, Nick Williams 103, Magnuson 2650, 9.17" (14%) lower, 90mm upper, Vengeance Racing Heads (LME) Cam Package (Cammotion Stage 1), Johnson Lifters, JMS Voltage Booster, Lingenfelter high flow check valve, BBK shorty headers, Custom 2.75" down pipes, Gesi Gen2 high flow cats, MM catch can 791whp, 772ft-lbs SAE
Just added 30% XDI Injectors, LPE big bore hpfp, Flex fuel.
Elite tuning, results coming soon.
2006 Silverado Duramax Diesel
MPI Compound Turbo
40% over Injectors
Efi Live DSP5 Tuning
Follow me on Instagram: Swisstyphoon1980
swisstyphoon is offline   Reply With Quote
Old 03-25-2020, 08:12 PM   #2
Doing a retrofit project, eh?
Old 03-26-2020, 01:00 AM   #3
swisstyphoon
Colored drl led's...
Thanks alot!
Looks like those are pwm modulated signals straight from the BCM..
2018 Camaro ZL1 A10
MPI Compound Turbo
40% over Injectors
Old 03-26-2020, 07:49 AM   #4
Thanks alot!
Aha, I missed that you had a ZL1. Sure, no problem, and good luck with the build
Old 03-26-2020, 01:16 PM   #5
swisstyphoon
Thanks.
Is there a difference in the ZL1 diagram?
The led driver modules are not shown in this diagram..
2018 Camaro ZL1 A10
MPI Compound Turbo
40% over Injectors
Old 03-26-2020, 09:27 PM   #6
Thanks.
It applies to all cars with the T4F RPO (ie the HID headlight package). Let me check if there's another page that shows those driver modules.
EDIT: no, that's it. Headlamp schematics show nothing either, just a plain diode symbol and wiring for the built-in (high) DRL's.
Old 03-27-2020, 02:30 AM   #7
swisstyphoon
Ok, thanks alot for checking.
2018 Camaro ZL1 A10
MPI Compound Turbo
40% over Injectors
