01-31-2020, 09:16 AM | #15 |
ITCRNRS
Drives: 2018 ZL1 1LE Join Date: Jun 2012
Stock 19's, rear camber is at about -2.2 and the wiring harness is relocated in the left wheel well.
2018 ZL1 1LE Ordered 6/29/17 Built 11/6/17 Delivered 12/7/17, Summit White, PDR, NAV, https://www.youtube.com/c/tylerpotter
SOLD: 2014 Summit White 1LE 2SS/RS, Recaros, NPP, NAV, KONI Yellow's SOLD: 2012 Black 2LT/RS, Fully 1LE swapped, Brembo swap |
01-31-2020, 10:09 AM | #16 | |
Drives: 2013 C6Z06 Join Date: Nov 2016
Kumho probably isn't making the other tire sizes in the ACR compound because it clearly isn't a 200TW. That's the real reason most competition groups are excluding them. They are the ultimate 200TW cheater tires. The tread depth/size availability is just the politically correct way of excluding them. |
01-31-2020, 10:38 AM | #17 |
ITCRNRS
355's ACR's on stock 19's with -2.2 rear camber
01-31-2020, 11:06 AM | #18 |
Dyno Show Queen LOL
Nice!
01-31-2020, 11:50 AM | #19 |
ITCRNRS
They do just hit the inside lip of the fender during really hard compression though, I just put a few layers of xpel tracwrap on the edge of the fender.
01-31-2020, 12:02 PM | #20 |
Drives: 1LEs Join Date: May 2009
01-31-2020, 12:13 PM | #21 |
ITCRNRS
01-31-2020, 02:15 PM | #22 |
02-04-2020, 10:24 AM | #23 | |
Drives: 2017 SS 1LE, 2016 1SS (previous) Join Date: Apr 2016
You think tires like the RE71R and A052 are really any different in the mentality you state? This is and has been the big topic with these tires* for the past few years in the autox scene... The A052 basically went through the near-exact exercise: Yokohama took one of their "streetable track tires" that could meet the 200tw "rating", making a little adjustment to the compound, increasing tread depth and keeping essentially the same tread pattern. Pre-2019 A052 "Streetable Track Tire" TW: 200 TD: 6/32" TP: 2019+ A052 "Extreme Performance Tire" TW: 200 TD: 7/32" TP: ACR V720 "Streetable Track Tire" TW: 200 TD: 6/32" TP: Mainstreme (post ARC) V720 "Extreme Performance Tire" TW: 200 TD: 8/32" TP: ACR V720 version + 7/32" + more sizes... why not? Kumho essentially dug themselves into a very specific corner (regional-level autox) with their mainstream V720. *"these tires" = the recent top "extreme performance tires" |
02-04-2020, 03:12 PM | #24 |
ITCRNRS
I would like to think you could move them inboard 1 or 2mm but when I pulled the wheels off before winter I thought I remembered very slight rubbing on the fabric liner that must happen during compression, I will hopefully uncover the car next month and try to take a picture of this.
02-04-2020, 05:14 PM | #25 | |
Isn't the Yokohama under review for being legal? |
02-05-2020, 12:06 PM | #26 | |
The Yokohamas were under some review, but last I read (end of last month), the case has been dropped. |
02-05-2020, 12:55 PM | #27 |
Dyno Show Queen LOL
I also saw the pirelli corsa pcz4 305 19a for dirt cheap
03-16-2020, 02:09 PM | #28 | |
Dyno Show Queen LOL
