Old 12-21-2023, 05:53 PM   #1
FlukeSS
FlukeSS's Avatar
Drives: 2020 Camaro 2SS A10
Update for my car
So just got the dyno numbers back.
Rebuilt Engine: Spun rear rod bearing+ cracked crankshaft
Modifications:
2" SE LT Headers
3" SE X-Pipe
K&N Typhoon CAI
LT2 ported intake - NEW
95mm ZR1 TB - NEW
DIY E85
3" MBRP Axle back (finally) - NEW
BTR Stage 1 220 cam - NEW
DOD Delete - NEW
TCM Tune - (unsure have to find out if they were able to do this)
On a heartbreaker dyno:
2020 Camaro 2SS A10 | Rebuilt by: CBI Street Cars | 2" SE LT Headers | 3" SE X-Pipe | 3" MBRP Axle-Back | Pri & Sec Cat Deletes | K&N Typhoon CAI | LT2 Ported | 95mm ZR1 TB | DOD Delete | BTR Stage I Cam | ECM, TCM & E85 |Tuned by: Shane Hinds | Dyno: 510 rwhp 472 rwtq
Old 12-21-2023, 05:58 PM   #2
grampa_ss
grampa_ss's Avatar
And....................
Old 12-21-2023, 06:02 PM   #3
FlukeSS
FlukeSS's Avatar
And I should be able to pick it up next week?
I guess what you might be looking for is: Assuming a 10% difference from a dynojet
Before LT2 Intake + TB + Cam on the Mustang dyno:
413.1 rwhp
429.3 rwtq
After mods on the Mustang dyno:
510 = 96.9 rwhp gained
472 = 42.7 rwtq gained
Old 12-21-2023, 06:22 PM   #4
Christian1LE
Drives: 2004 BMW 330CI, 2022 1SS 1LE
pretty good bump over stock + 100 HP.
Christian1LE is offline   Reply With Quote
Old 12-21-2023, 06:45 PM   #5
FlukeSS
FlukeSS's Avatar
Does that seem about right then?
I am not on the same dyno as before, My car dyno'd on a dynojet at 459 rwhp and 477 ft/lbs
I was assuming a 10% difference between this mustang dyno and that dynojet.
But, I'm having a hard time believing I gained almost 100 rwhp with just the LT2 + TB + Cam?
Old 12-21-2023, 08:58 PM   #6
Christian1LE
Well most cars dyno around 415, not sure how you got 459, seems insane.
Old 12-21-2023, 09:26 PM   #7
FlukeSS
FlukeSS's Avatar
459 on a dynojet, without the LT2 + TB + Cam.
The base pull was never done before I got the first set of mods. So don't know what the dynojet would say but given the gains shown at 85 hp at the crank, it would have base dyno'd on a dynojet for about 395 rwhp.
On a mustang dyno assuming 10% difference it would have base dyno'd for about... 355.5 rwhp. Note: The difference between a mustang dyno and dynojet can range from about 5-15%. I assumed the average of 10%.
So all the mods together on that mustang dyno would have given me a gain of about 145rwhp give or take a few from stock.
I am asking if those numbers sound about right on average?
Old 12-21-2023, 09:50 PM   #8
Christian1LE
Yeah sorry, no idea I don't know or have any experience with those mods to give you an answer.
Old 12-22-2023, 07:43 AM   #9
Smokin19
Drives: 19' ZL1 A10, w/pdr
Yes the Mustang dyno can be a heart breaker but, then it just a tool for tuning and with a good tuner very capable. Many variables are used in making that tune and some say the Mustang dyno may be better. I know my numbers really don't match up with others with a similar build but, the seat of the pants performance I get says otherwise. Good luck and happy running on your new build.
BTR Stg II cam w/ 38% fuel lobe, ARH 2" headers into 3" w/cats, AWE Touring, Kong X port, Weapon X triple ht exchangers, NW 103, Rotofab big gulp, DSX lowside, TCM tune, BMR Lockout, Mustang dyno 720 rwhp, 634 rwtq on 93 pump.
Smokin19 is offline   Reply With Quote
Old 12-22-2023, 07:49 AM   #10
FlukeSS
FlukeSS's Avatar
I'm excited either way, be glad to get the car back finally.
Old 12-22-2023, 09:13 AM   #11
Junction65
Junction65's Avatar
Drives: 2011 GMC Sierra 1500
^THIS. Glad to hear you got everything sorted.
2023 LT1 Coupe M6 - Black (GBA) on Black (H1T)
Blade spoiler (5ZU), Recaro seats (AQJ), Technology pack (Y3W)
LT1 PBC engine built by Shane Parker
Current mileage: 310
Junction65 is offline   Reply With Quote
Old 12-22-2023, 09:52 AM   #12
laynlo15
laynlo15's Avatar
Drives: 2022 Lt1 A10
Good numbers in my opinion and not all Dynjets read higher than Mustangs. There are a whole lot of factors that go into to it. Temps, DA, SAE, Standard on the day of the pulls. I actually talked to Chad this morning and he was telling me that his Zr1 made lots of pulls on a Dynojet before he got his own Mustang Dyno and the numbers were very close to each other so it's not always accurate that the Mustang is stingy in every case. He did drive it on the street also to make sure it was all good and was going to get it on the street again before you pick it up. He was very happy with the results so I know you will be also.
Old 12-22-2023, 10:34 AM   #13
s346k
s346k's Avatar
Drives: like an old lady
meh take it back to the track. it trapped 120 before? id look for 128+ now.
Old 12-22-2023, 01:21 PM   #14
FlukeSS
FlukeSS's Avatar
Noted: I was trying to be more modest and say 125 and be happy with it, but if I get higher great.
Will find out when the weather turns some time next year.
