10-10-2023, 09:58 PM | #1 |
Drives: 2016 2SS White w/blk whls, MRC, 6sp Join Date: Mar 2017
Water Temp Goes to zero, radiator fans on
I have had this intermittent problem happen twice now. The water temp gage goes all the way down but the radiator fans are on. My 2016 2SS gives no other indication it is running hot. Coolant levels are fine. Seems like a coolant temp sensor malfunction where gage gets no signal and fans think the engine is overheated. Also not throwing a diagnostic code. Any ideas?
10-11-2023, 07:50 AM | #2 | |
10-11-2023, 07:56 AM | #3 |
17’ Hyper Blue 2SS
Common issue, 9 times out of 10 it’s either a stuck thermostat or the sensor.
10-11-2023, 08:52 AM | #4 |
10-11-2023, 01:35 PM | #5 |
Drives: 2017 NGM 1SS MRC NPP Join Date: Feb 2017
Katech sells a stock thermostat so you don’t have to buy the whole housing.
Mamo PTB /Borla ATAK NPP /Carbon Fiber lip/ZL1 side skirts/ Black Bow ties/Husky Mats/ Mishimoto CC /BMR strut tower brace/ZL-1 License relocation/Rock guards
10-11-2023, 02:14 PM | #6 | |
Long hauler
If you’re lazy like I was you can keep doing this
10-11-2023, 04:15 PM | #7 |
Drives: 2016 Camaro 2SS A8 Join Date: Oct 2016
As others have stated it's most likely the thermostat is stuck open or temp sensor is bad. They're cheap on Amazon and very easy to change. Might have to disconnect negative battery terminal briefly to reset the computer after changing.
10-15-2023, 01:11 PM | #8 |
Thanks for the replies. I'll check into the sensor first to make sure it is plugged in properly. Then I might just change it with and AC Delco as they are priced rather competitively.
10-15-2023, 01:24 PM | #9 |
Somewhere in the Kalahari
Drives: 2021/18 (de-fresh) 3LT RS Join Date: Dec 2017
10-15-2023, 04:48 PM | #10 |
This just happened to me. Replaced thermostat...problem has not returned.
