05-10-2016, 12:03 PM | #15 |
Drives: 2015 ZL1 Join Date: Jan 2015
No problem with the AFM, we just determined from our past experience that the main focus of the V6 community is on axleback systems. We are not developing a catback at this time, but wouldn't say the possibility is off the table!
05-10-2016, 04:46 PM | #16 | |
Big Samoan ina little car
Drives: 2016 camaro Join Date: May 2014
ive seen some pics on phasteks site, but you may know a bit more indepth, but I take it theres not a lot of crushed/crimped sections like on the 5th gens???
When I see posts asking "whats the best intake, exhaust, etc" .... the answer to that is like a grandfather telling his grandkids "if you put salt on a birds tail, it'll let you catch it" #ThinkAboutIt "Winning Tip: Don't take my (or anyone else's) word for it. GO TEST IT!" - Dennis Grant |
05-10-2016, 05:04 PM | #17 |
Retired from Car mfrs....
Somebody will still have to show me where the AFM valves are on a V-6… I can't find them and I've had my entire car installed with an axle back and they are not there on the V6 automatic. AFM valves are only on the V8 as far as I can tell
05-10-2016, 06:16 PM | #18 |
Drives: 2016 camaro lt2 rs Join Date: Feb 2016
ill talk some pics of the underside of my car so you can compare to a m6 this weekend. if you would like
05-11-2016, 07:49 AM | #19 | |
Look towards the bottom. Entire underside of car, but look near the diff. It says adaptive valve on it. Chances are when they removed yours they took it out. The mrt axlebacks seem to remove em altogether. Prob what many will do. Granted it may be an automatic/manual difference.
05-11-2016, 01:19 PM | #20 |
Right! All of the systems will be mandrel-bent (as opposed to crush bent) stainless steel tubing, with smoother bends than stock, and 1/4" wider for increased flow!
05-11-2016, 04:18 PM | #21 | |
was referring to the 5th gen stock exhaust though, there were a lot of flat crimped spots. went with the 15090 to get pipes that were uniform in diameter
05-11-2016, 04:22 PM | #22 |
Nobody took my valves out. I stood there and watched all the work done on my car. Granted I do have the V6 automatic. But it does not have any adaptive valves on it all the way up to the main cats. I discussed this with Ricardo and he couldn't come up with them either.
05-11-2016, 06:03 PM | #23 | |
Drives: 2016 Camaro 1LT Join Date: Jan 2016
05-11-2016, 08:56 PM | #24 | |
By no means am I a newbie to exhaust, Intakes, performance and tuning. What worked when I started in cars almost 2 decades ago, still works. Things may have gotten more fancy and hi tech, but the basics will always work. I ran a Dashlogic to monitor quite a few things on the 5th gen. Sadly I couldn't use my diablosport trinity to datalog and adjust tunes as I did in the charger, but the Palmer product was good enough for occasional track use and daily driving. Sound I wasn't worried about with the 15090 setup from magnaflow. I knew it was gonna be loud, so I added the resonators in the rear. Started with just mrtv2s, then the x pipe, then upgraded to a catback. Not many have experience with a full catback, which I'm used to, and gains are to be had. Every bit helps when you go n/a. Most on the forums aren't into performance...just looks and sound. There's still a few of us that tinker...not many, but a few. But as with performance and efficiency goes... a pipe only flows as well as its smallest diameter. Which is part ofor the reason we port things on the intake side. The exhaust side benefits from being open just the same. With that being said, crimped and clamped pipes, decrease efficiency. exhaust flow and velocity are both direct factors for performance. The more efficient something is the more power it makes per say since more can be sent to the wheels rather than lost from the engine doin work. Going from stock exhaust, to an aftermarket with less restrictions, 32mpg easy on the lfx. That was up from a previous best of 29-30 on a good day. Took less to break the tires loose as well in cornering and acceleration. Currently I'm getting 35-37mpg on the lgx. If I can do a bit better, I'm willing to try.
When I see posts asking "whats the best intake, exhaust, etc" .... the answer to that is like a grandfather telling his grandkids "if you put salt on a birds tail, it'll let you catch it" #ThinkAboutIt "Winning Tip: Don't take my (or anyone else's) word for it. GO TEST IT!" - Dennis Grant Last edited by PolynesianPowerhouse; 05-11-2016 at 09:09 PM. |
05-12-2016, 02:34 PM | #25 | |
Drives: 2x 94:Z28s - 2x95:Z28s - 1x16:1LT Join Date: Nov 2015
05-12-2016, 06:20 PM | #26 | |
That's some shading on the render to help show the contour of the pipe, but we can understand why it could look like a crease. We'll have to look into that... Heres a real-life picture of that same section of pipe: http://www.camaro5.com/forums/attach...1&d=1380192997 |
05-13-2016, 10:14 AM | #27 | |
But to add to that, not sure if you knew, but tuning an exhaust is no different than an intake. Longer runners on the intake have a different effect than shorter ones. Same with exhaust, for cars that actually have headers, short tubes function different than long tubes, and that's not even discussing a tri-y setup. This is all a determinant of where the power gained will be at in the rpm range.
When I see posts asking "whats the best intake, exhaust, etc" .... the answer to that is like a grandfather telling his grandkids "if you put salt on a birds tail, it'll let you catch it" #ThinkAboutIt "Winning Tip: Don't take my (or anyone else's) word for it. GO TEST IT!" - Dennis Grant Last edited by PolynesianPowerhouse; 05-13-2016 at 10:25 AM. |
05-13-2016, 10:18 AM | #28 | |
Here's a pic of how the stock v6 lfx pipes were Which is why I upgraded.
