Homepage Garage Wiki Register Members List Social Groups Calendar Search Today's Posts Mark Forums Read
Old 02-24-2020, 05:35 PM   #1
MackSteelPrivateEye
Drives: pontiac
The Tremec 6060 stackup
Just wondering how our Tremec 6060 stacks up against a Muncie 4 spd Rock Crusher trans. Can you beat it a slam it and have it keep on ticking? The Muncie has a rep of taking a real beating and keep on going. Who's familiar with the comparison or is there a comparison?
Old 02-24-2020, 06:08 PM   #2
Abubaca
Abubaca's Avatar
Drives: 2016 SS
There's no real comparison. Even the T56 is better. ...except for weight of course. The M22 took a beating, but from cars with half our horsepower putting even less down through the tires. You know what they say about meeting your heroes...
Edit* I did a lot of research on the subject when I was picking a transmission for my Iroc. Wasn't considering an M22 but it came up quite a bit during research. Ended up with a Tremec TKO. There's countless pieces of info worth dissecting, but just like the infamous Borg Warner T5's, the smaller cases would flex. The low grind angle of the gears (hence the rock crusher noise) help redirect flexing forces, as well as different metallurgy in the gears compared to the M20 and 21 it helped, but they still would fail. There's a great article I read about how modern computer R&D allows for testing for all the flexing forces a transmission experiences. They talk about how ALL the old school transmission would flex and ultimately fail. Nowadays you plug in a few parameters and poof - bomb proof case specs courtesy of less computing power than you have in your watch. Modern tech is truly amazing. Modern transmissions fail because of cheap production parts used to keep costs down, but the inherent designs are pretty rock solid.
Abubaca is offline   Reply With Quote
Old 02-24-2020, 06:18 PM   #3
L78toLT1
L78toLT1's Avatar
Back in the day, the Ford toploader had the reputation as the toughest 4 speed box. You have to give it to Ford where driveline components are concerned. The toploader and 9 inch diff were the toughest of the tough. As far as autos go, the C6 wasn't bad, but it was no th400.
Baby Blue
2016 Hyper Blue 2SS/6m/MRC/NPP/Silver Rally stripes/ZL1 wheels/6 piston Brembo's/GForce DS and axles/ZLE Cradle Bushings/FE4 ARB front & rear/SEMA Grill/Rotofab dry/Pray ported TB/Magnuson Heartbeat with 85mm pulley/Full LT4 fuel system/JMS boost-a-pump/Skidmark Garage E85 Sensor/JRE Smooth Idle Cam/GPI piston/rod kit /APR main, head, balancer bolts/Kooks 1 7/8 headers with high flow cats/JRE remote tuned
Old 02-24-2020, 06:23 PM   #4
Petrol Head
Drives: Fast if no one's looking
The M22 was a great transmission in its day but by today’s standards it’s a toy. The gears were not precision engineered by any means compared to the modern Tremec, so while you could slam it hard there was a mile of play in the gear shift. Also our Tremecs are built to handle about 560-600 hp and the same ft/lbs torque. That would destroy a Muncie. Even the beefiest SS396 or 454s in the day were actually only putting out about 360 hp in SAE Net measurement. Those 400+ hp ratings used in the day really were SAE gross. They say those engines were underrated but they weren’t measuring in modern SAE net. The 6th gen Camaro 6.2 LT1 is rated at 455 hp NET - that’s real horsepower.
2019 2SS 6 speed
Shadow Gray Metallic/Light Gray interior; Mag Ride; Moonroof; Dual Mode Exhaust; Straight spoke wheels
Mods so far: illuminated footwell lighting, Homelink, Gen5 DIY radar detector direct wire harness, painted calipers red, installed CAGS override harness
Petrol Head is online now   Reply With Quote
Old 02-24-2020, 06:27 PM   #5
oldman
Drives: SS 6 speed of course
The Mopar 833 was a heck of a strong trans and easy to rebuild the only problem was it was a truck trans that shifted like a truck trans. The Muncie is a geat easy to shift trans, with proper upgrades it can take say 500 ft - lbs 600+ for quite a long time.
http://www.superchevy.com/how-to/tra...-transmissions
https://www.chevydiy.com/how-to-buil...transmissions/
So IMO, the Muncie is just a great trans to actually drive...
2016 to 2017 Stage 1, FBO, ported MSD, 103 TB, E85
2018 Stage 2, P1C, 4.0 pulley, Pray ported heads, Pray stage 1 blower cam, TxSpeed valvetrain, Katech ported 87mm TB, ported MSD, 1 and 7/8 headers
2019 stage 3: Forged short block, huge duration sub .600 lift Cam Motion cam, 7300 RPM fuel cut, Pray Ported Heads, 3.85 pulley D1X, stage II intercooler, 2 BOVs, DSX secondary low side, DSX E85 sensor, Lingenfelter big bore 2.0 pump, ported front cats, 60608 Borla, Lingenfelter injectors, ZL1 1LE driveshaft and DSS half shafts, Katech ported TB, MSD intake, BTR valvetrain.
Old 02-24-2020, 06:32 PM   #6
oldman
This is true and not true, most guys put headers on day one and then you are dealing with 450+ HP engines with 500 ft -lbs and it is torque that breaks transmissions. Don't get me wrong I love my M6, especially with my Hurst shifter (best mod ever). But to drive a M22 behind a 396 was pure lust, that trans was butter. I also own a Integra Type R , know to be the best trans / engine combo kown to man, the M22 behind a LT1 or 396 is a close second..with good shifter of course.
Old 02-24-2020, 06:57 PM   #7
Petrol Head
The 375 horse L78 was really closer to 325 horse by today’s SAE net version 2.0 rating calc. Remember, those engines were rated in SAE gross until 1974, then SAE net version 1.0 from 1974-2003. In ‘04 the SAE revised their rating system again. The 455 horse in modern Camaros is a realistic number. Those old muscle cars felt fast but realistically they were slower than a modern V6 Camaro.
That 450 hp header mod must be with unicorn dust.
If you connect an old M22 to a modern LT1 the LT1 would shred it to pieces.
2019 2SS 6 speed
Old 02-25-2020, 06:29 AM   #8
oldman
There are many dyno out with the numbers I listed and long tubes, the gen v LT1 BHP is found here: 518 HP.
Here is a 396 dyno at 458 HP with headers (which I said at the get go) And yes 454, 455, 400 Ram Air, 427 could either dyno at the 450 HP with LT or 500 ft-lbs (which is what breaks the trans).
https://www.hotrod.com/articles/chev...actory-rating/
https://www.hotrod.com/articles/518-...traight-crate/
I don't know why you are going with SAE net, I clearly stated headers.
Let's be clear tens of thousands of GM BB engines with headers were raced for decades with Muncie transmissions. Did they fail, yes, can you get new cases, shafts syncros etc to have a Muncie live a long life at say 500 HP... probably so. What is the rating of the TR6060 installed in the LT1 Camaro 560 ft - lbs. Stronger than a Muncie out of the box, and there is not much that separates the TR6060 from a T56 mag at 700 ft-lbs. The Muncie's claim to fame is not strength anyway, as I've stated it was the ability to shift. The aluminum Muncie was also light.
All you ever wanted to know:
https://oppositelock.kinja.com/so-yo...mis-1823051016
Old 02-25-2020, 01:40 PM   #9
MackSteelPrivateEye
Drives: pontiac
He lost me with the Integra comment.
Old 02-25-2020, 01:57 PM   #10
MackSteelPrivateEye
Drives: pontiac
My 69 383 RoadRunner had more lowdown grunt that my old V6 11 Camaro. But my Camaro was geared lower and had more top end than my RR. I' m pretty sure my 383 was more powerful than my V6 Camaro but my Camaro had 3 more gears than my RR too. Coming out the Hole I think my RR would win but after 65 or so the camaro would walk it. But if that RR had an equivalent modern 6 speed close ratio manual trans, I'm pretty sure the RR would lay waist at least to 100mph.
Old 02-25-2020, 02:16 PM   #11
Abubaca
Abubaca's Avatar
Drives: 2016 SS
Integra Type R's lose a LOT of people.
In my experience, a modern transmission helps, but doesn't change the nature of an engine, whether it be new or old.
Old 02-25-2020, 02:44 PM   #12
L78toLT1
L78toLT1's Avatar
I can assure that you that a modern LT1 would not immediately destroy a M22, you may break it eventually, but you certainly wouldn’t shell it the first time you dumped the clutch. In fact, you would have a hard time hurting it on street tires. A toploader would likely live forever behind an LT1.
Baby Blue
Old 02-25-2020, 04:04 PM   #13
Wyzz Kydd
Wyzz Kydd's Avatar
Drives: 2018 Camaro SS1 1LE
Right, 195 HP, 140 or so lbs of torque at about 2400 lbs curb weight. 1/4 mile at 14.7 and a top speed of 125 mph.
It was a beast (not). My 1993 RX-7 ran circles around Integra Rs.
2018 Camaro 1SS 1LE Red Hot.
Wyzz Kydd is offline   Reply With Quote
Old 02-25-2020, 08:30 PM   #14
oldman
If you have never owned driven and raced an Integra Type R, then you have missed out on something special. My sleeved 2.1 liter NA engine puts out 275 HP at 2400 lbs... you can work the math out yourself I have also built turbo B engines at 450 HP and 2400 lbs...
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
