11-18-2023, 05:21 AM | #1 |
Life's just a Ride
Drives: 2011 Synergy Camaro 2SS/RS LS3 Join Date: Oct 2013
To Tint or not to Tint?
Everyone I work with tells me I need to Tint the windows dark.
My Q is yes or no? and how dark? Windshield too? |
11-18-2023, 06:40 AM | #2 | |
Drives: 2011 Camaro ss Join Date: Sep 2021
I went 20% all the way all windows but windshield and its enough for me. it basically the same dark as most cars factory tint but with the 5 windows done it appears a little darker, just not dark enough to get pulled over.
2011 Camaro 2SS Victory Red
Rotofab CAI, 160 Thermostat, Stainless Works Headers, Livernois Motorsports Thunderstorm Exhaust, GPI SS1, rodmod intake, ported tb by GPI, Remote Tune by GPI, Elite Engineering Catch Can, Rotofab washer relocation, JRE scoop, JRE Trans dipstick, BMR Toe Rods, BMR Trailing Arms, BMR subframe connectors, Polyurethane diff bushing and rear cradle mount's, RSM front crash bar |
11-18-2023, 06:56 AM | #3 | |
Older Than Dirt
Drives: 2010 & 2013 Camaros Join Date: Apr 2010
If you do, I would suggest those newer, slightly more expensive, ceramic tints from a quality manufacturer. They cut down on the UV rays and I got it done on my truck and it cuts way down on the heat the vehicle picks up inside. Even had the windshield clear-tinted with the ceramic tint for the UV protection factor.
In SC, you're allowed to go to 27% visible light transmission (VLT) on sides/back for SUV, van, or car. You can also use non-reflective tint on the windshield above the AS-1 line. If no AS-1 line is visible, unfortunately no front tint is legal. Also, no red, yellow, or yellow tints, either. No problem for Camaro, but any back window tinting requires dual outside mirrors as well. Up to you if you want to break the law and pay $200 (or 30 days in jail) on the first offense. Most of your good tint shops won't go darker because they have to certify their installations, and can be fined $1000 and/or jail time on the first offense. With a truck, trailer, motorhome or bus, you can't go darker on the front door windows, windshield, but you can basically go as dark as you want on any rear side windows or rear window. If done by a professional tint shop, they should also have a tag placed in the lower RH corner of each tinted window, visible, showing who installed it, date of installation, and VLT %. Even if you do it yourself, you're supposed to install the certification tag. It's usually a tiny square almost unnoticable. From SC Title 56. SECTION 56-5-5015. Sunscreen devices. Quote:
2010 2SS TE, 1 of 822/2013 Camaro ZL1 vert, 1 of 54
11-18-2023, 09:39 AM | #4 | |
Life's just a Ride
Thing is that my rearview mirror is self darkening and so are my Outside Mirrors. |
11-18-2023, 10:05 AM | #5 | |
It don’t come easy.
11-18-2023, 11:43 AM | #6 |
^^^^ Same here with me. All the Camaro windows done and it's plenty. Bought the Camaro brand new from the dealership with the tint on it already. 12 years and no issues. And yeah, leave the windshield alone, just the very top portion if you do.
11-18-2023, 02:16 PM | #7 |
Drives: ZL1 Join Date: Oct 2012
I've always done 5% on the very back window and 15% on the side windows, which gives an illusion of making the tint look darker than it actually is when viewing from the outside in.
11-18-2023, 03:50 PM | #8 |
It don’t come easy.
Plenty dark, at 20%.
11-18-2023, 06:41 PM | #9 |
11-18-2023, 06:46 PM | #10 |
20% on mine..
11-18-2023, 09:09 PM | #11 |
Older Than Dirt
One is a convertible, so the windows are hidden anyway on nice days. No tint.
The 2010 has no tint either. It spends its life in the garage when not driving around. No need to tint it. Around here, 20% will get you a ticket. They're serious about that stuff here. Only excpetion is if the car was built and windows have original tint from PRIOR to Jan 1, 1993, or medical necessity with a doctor's prescription. The grandfathered cars can have 20%. Any repair tints on those cars would fall under the new tint law, however.
11-19-2023, 09:02 AM | #12 |
It don’t come easy.
11-19-2023, 09:05 AM | #13 | |
It don’t come easy.
11-19-2023, 05:48 PM | #14 |
Drives: ZL1 Join Date: Dec 2016
I like 15% to 20% percent, but tinting like the color of a car so subjective from one individual to the other.
Tags |
tint |
