Vararam
Old 02-20-2023, 07:25 AM   #15
camguynj
camguynj's Avatar
Drives: '13 SS/RS LS3 BRM Cammed NPP
Originally Posted by rabbs88 View Post
Literally just did a retrofit with the Morimoto Micro D2s 5.0's a few weeks ago but made my own brackets. Went pretty smooth and the fitment came out perfect with the factory projector shroud. Only hard part was splitting the headlight with the factory perma-seal. What's the name of the company?
What shape were the reflectors in any fading, burnt spots? What Kelvin did you go with?
camguynj is online now   Reply With Quote
Old 02-20-2023, 08:38 AM   #16
Leo72793
Drives: 2011 2SS/RS
I just put the Morimoto XB fogs on my car with the DRL always on harness. Once i adjust hem it will help some.
•2011 Camaro SS 2SS/RS A6
•MRR M017 1le Replica Wheels
•Vararam Ram Air Intake
•Speed Engineering Longtube Headers w/ Magnaflow HF Cats
•Bo White PnP Stage 2 TB
•GPI SS2 VVT Cam w Cometic thin gaskets 10.69 compression
•Xpipe w/ Res Delete and NPP Exhaust
•Tuned By Anonymous Calibrations
•Gen5DIY Mylink Conversion W/ Backup Cam
•Morel 3 way custom speakers, Infinity 860w Subwoofers in trunk baffle
•Helix P6 6ch amp w/ 8ch DSP and P1 Sub amp
Leo72793 is offline   Reply With Quote
Old 02-25-2023, 10:33 AM   #17
camguynj
camguynj's Avatar
Bump for more subscribers Here’s a one time chance (see posts 1&2) to save hundreds of $$$ when the time comes to replace aging/dimming eom HID headlights with Morimoto projectors (with NO modification!!!) instead of the VERY costly entire headlight assembly.
Old 02-25-2023, 04:33 PM   #18
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Put me in for a set.
Orange Krush II
1LE Front sway bar, Splitter, shocks and struts, Z28 dual mode mufflers, Intake, UCA Bushings, and Toresen 3.91 Diff. 1 piece DSS Drive Shaft, ZL1/C7 Calipers, and 32mm JPSS Rear Bar. ASC race spec splitter and wicker. 6th Gen M017 Wheels. Stainless Works 1 7/8 LTs. DSE and PAFDT Suspension components.
olblue75 is offline   Reply With Quote
Old 02-26-2023, 08:04 AM   #19
Leo72793
Drives: 2011 2SS/RS
Slot reserved! Share this around. Will be so worth it.
Old 03-03-2023, 08:01 PM   #20
rsrsrs
rsrsrs's Avatar
Drives: '11 2SS/RS M6
This sounds very interesting. I'm assuming these headlights are amazing if this being attempted? Just wondering before I say yes. I do want a brighter looking light like these newer cars, granted Im pretty sure their all 5k but their definitely brighter than my car, 11SS HID.
rsrsrs is offline   Reply With Quote
Old 03-04-2023, 08:30 AM   #21
camguynj
camguynj's Avatar
The eom HIDs are that good (not so much with after market) except for the plastic projector bowl witch fades over time which causes dimming. Replacing the bulbs with new HIDs or LEDs “may help some for a while depending on the condition of the projector bowl but replacing the projectors with Morimito projectors IS a longer lasting and much cheaper solution (especially if you DIY) to dimming headlights compared to the cost of buying replacement HID headlights
Mine aren’t dim yet but it’s only a matter of time so I want to get the customized Morimoto bracket now while they’re willing to make it for when the time does comes to make it a plug n play fit rather than to have to hack the eom bracket. You may want to get them for the same reason.
Old 03-04-2023, 08:53 AM   #22
rsrsrs
rsrsrs's Avatar
Interesting. I have a 2011 SS so I'd guess it's about time? Looking at the lights from the front they look white, but sitting in the driver seat, the road has a yellowish tint. I'd really like that bright white that my wife's 2019 Chevy Equinox has. Would these Morimotos achieve that?
Old 03-04-2023, 09:44 AM   #23
Leo72793
Drives: 2011 2SS/RS
I have cars passing me with their "halo lights" or accent lighting brighter than my stock HIDS. I have Diode Dynamics bulbs, i tried phillips osram, nightbreaker and all and it doesnt help. The reflector bowls just suck. The Morimotos are metal i believe which will hold up much better to the heat. even if not this would be a retrofit that would last another 10+ years vs new bulbs that dont do much for us.
Old 03-04-2023, 11:40 AM   #24
rsrsrs
rsrsrs's Avatar
Lol yes I do notice halos and accents brighter than mine. Reminds me, i wouldn't mind switching out that LED for the Halos 🤔. Put me down on the list.
Old 03-04-2023, 03:38 PM   #25
Leo72793
Drives: 2011 2SS/RS
Slot reserved! I have a diode dynamics LED RGBW kit i need to put in. I have had it for 4 years never used it.
Old 03-05-2023, 07:13 AM   #26
rsrsrs
rsrsrs's Avatar
Never been interested in those kits. Always wanted to just replace the LED but finding a part number for it has been a pain. One day....
Old 03-05-2023, 05:08 PM   #27
Leo72793
Drives: 2011 2SS/RS
Even if you get it, it can be left to run in white. thats the glory of it.
Old 03-11-2023, 12:08 AM   #28
camguynj
camguynj's Avatar
Bump for more subscribers. Here’s a one time chance (see posts 1&2) to save hundreds of $$$ when the time comes to replace aging/dimming eom HID headlights with Morimoto projectors (with NO modification!!!) instead of the VERY costly entire headlight assembly.
