10-24-2020, 09:30 PM | #71 | |
Drives: 2017 Camaro ZL1 A10 Join Date: May 2012
Again, comparing it with other Frods and from a bone stock standpoint, if you wanted the newest and fastest semi-affordable Mustnag then that is what you are stuck with. |
10-24-2020, 10:29 PM | #72 | |
Drives: 2021 Camaro ZL1 A10 Join Date: Nov 2018
That said, the ported GT350 IM and ported Bullitt TB would have been around $1,500 + tune + tuning hardware, totaling probably $2,200, give or take. Vs. $410 for my OEM ported stuff. That combo would have yielded more hp (due to the porting work), and higher average hp, making the car quicker. But I didn't want to spend an additional $1,800 for those items, plus a tune potentially causing issues w/ future warranty work.
2021 Camaro ZL1 A10
2022 GR Supra 3.0 Past: 2018 Mustang GT Premium w/ PP1, MR, and A10 2007 MazdaSpeed3 1995 Pontiac Trans Am 1987 Camaro Z28 |
10-24-2020, 10:58 PM | #73 | |
Mach 1 + A10 = $54.5k w/ destination 2SS 1LE + A10 = $53.1k w/ destination Subtract $1.6k from both for the manual versions. You get 25 more hp for the extra cost; whether or not that shows up very well in tests - we'll see - it didn't seem to help the Bullitt, which went 12.6 @ 115 mph like every other '18+ GT PP1 M6 test due to the MT82 gear ratio choices Ford made. Maybe the Tremec will remedy that issue. I'd say the differences are somewhat marginal. Pick your poison.
2021 Camaro ZL1 A10
10-25-2020, 09:40 AM | #74 | |
For the record, running a ported IM on a stock tune is not recommended. I never even considered that because it is just a waste of money. At least with the GT350 IM you can increase to RPM limit to 7800 provided you have upgraded OPGs. I ran mine to 7500 easily. |
10-25-2020, 09:49 AM | #75 | |
The Mach1 offers nothing over the GT that would merit such a price hike. I could see in the New Edge days when the Mach1 was far and away a superior car over the GT. There was no comparing the two. Not by looks, features, performance, anything. These days if you went with a Manual trans GT Premium vs a manual trans Mach1 all you'd get out of the Mach is a color scheme, emblems, a vanishing 20 extra hp, the same ET down the quarter, and remarkably even less features. In fact, yet again here is another Mustang in the $60K range that is gonna get walked by the standard base model $30K GT in the quarter. LOL!! $28K for a slower car that has 20 more HP. Throw the Premium at the GT and the Mach will be more expensive, more HP, slower, and have less features. |
10-25-2020, 11:30 AM | #76 | |
Anyway, my car is at least 10% quicker, if not more, than a stock A10 GT PP1 now from a roll, and saving that much weight has helped responsiveness and handling as well. I really like having the MagneRide so I can change the damper firmess if I happen to be on a bumpy road. As a side note - I live at an elev. of about 2,700 feet; I saw the DA in my City was 500' this morning, so I just took the 'Stang out for a spin by myself - holy smokes. The last time I drove it I had a passenger and DA of 4000'. What a difference the low DA makes. Anyway, enjoy your Sunday...
2021 Camaro ZL1 A10
10-25-2020, 12:06 PM | #77 | |
Drives: E92 BMW M3 Join Date: Oct 2012
Its great to see the Tremec, or anything worth rowing, finally go in a 5.0 Mustang too, and the coolers!! I will test drive one of these before I buy for sure, it's damn nice and checks boxes Ford has left unchecked(for me) this entire generation until now. Would have to be a very aggressive negotiation to get me in one, anything above $50K and I'm just buying a used ZL1. It is close enough to try it out though, if nothing else it will be a nice test drive.
J-Rod Built and Matt@FSP Tuned |
10-25-2020, 12:07 PM | #78 | |
10-25-2020, 12:54 PM | #79 | |
Drives: 2021 Camaro LT1 Conv Join Date: Oct 2016
I don’t think there’s ever been a 2018-2020 GT owner that’s gone with the GT350 manifold? 2015-2017 Mustangs owners with the Gen 2 Coyote, going with the GT350 manifold has became rare since the 18 GT manifold became readily available. As most came to the conclusion the GT350 IM doesn’t provide any benefit over the 18 GT IM while costing 5 times more. |
10-25-2020, 01:47 PM | #80 | |
With the K&N intake only, I did 20-70 mph in 3.53 seconds. I never ran that test bone stock, but the MAF readings showed a pretty substantial pickup in mass airflow rate with the K&N intake. With the K&N intake, Ported TB, ported IM, and Borla S type w/ Borla H pipe I did 20-70 mph in 3.28 seconds in a head wind (the previous one was with a side wind). The only changes being the ported TB, ported IM, and Borla catback. I have other acceleration runs where the data was similar. These are all on the same stretch of flat road. Those tests were before the following additional changes I've done since then: Lightweight wheels (saves 36 lbs rotational weight) Other weight reduction mods totaling an additional 35ish lbs. Lightweight aluminum water pump pulley On the list for the future for wear items are lightweight front brake rotors (saves 19 lbs) and a lightweight battery (saves 23 lbs). I have a full interior so I've saved weight where I can that's reasonable. Things like removing the engine cover (4.5 lbs), replacing the stock GT strut tower brace with a GT350R aluminum Ford Performance one (saves almost 3 lbs), removing the sound tube (1 lbs), etc.
2021 Camaro ZL1 A10
10-25-2020, 02:14 PM | #81 | |
Drives: 2020 SS1LE Shadow Gray Metallic Join Date: Feb 2018
10-25-2020, 02:15 PM | #82 | ||
10-25-2020, 02:51 PM | #83 | |
Compared to stock, the few engine mods I've done combined with the weight loss is probably good for at least 4 tenths from 20-70 mph. Unfortunately, I didn't do stock weight and stock engine 20-70 mph tests to get a comparison. For what it's worth, the mass airflow readings were 48.5 lbs/min bone stock, average from four separate WOT runs, and negating a few higher outliers. With the bolt ons MAF readings are ~53 lbs/min. average from several separate WOT runs. A general rule of thumb is 10 crank hp per lbs/min MAF for NA engines (supercharged engines are less due to the hp required to run the supercharger); assuming that rule of thumb, the car was about 485 crank hp stock, and 530 crank hp now. That may seem a little high but those are the MAF values from the computer. I have roll raced a friend's '19 GT350 and put several cars on him 40-85 mph short shifting at only 7k rpm (500 rpm short of redline). I pulled away pretty steadily from 40+, but by 65+ mph I was pulling away hard. He and I generally just drive together on curvy mountain back roads and don't normally roll race. I joke with him I'll try to keep up in the turns, and for him to try to keep up in the straights. I know one guy locally with an M6 ZL1, but not very well. If I get the chance I'll roll with him to see where my car is at compared to an M6 ZL1.
2021 Camaro ZL1 A10
10-26-2020, 09:21 AM | #84 | |
G@M30v3RgT
Drives: 2016 Mustang GT 5.0 DIB Join Date: Apr 2010
2016 Ford Mustang Base 5.0 GT DIBM/Black Accent Package(AUTO) (STOCK).
