10-18-2020, 06:26 PM | #57 | |
Drives: 2019 Camaro 1LE Shock Candy Join Date: Mar 2016
Clear selection $39.95 https://gwatneyperformance.com/produ...old-126977114/
103 Katech TB, KATECH Custom Heads, DSX In-line fuel TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM Diamond Piston & Manley Rods, Roto Fab Big Gulp BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane. 2014 Mini Cooper countryman S All4 M6 daily driver |
10-18-2020, 06:59 PM | #58 | |
Drives: 2021 LT1 10 speed auto Join Date: May 2013
10-20-2020, 01:47 PM | #59 |
Revised #3
Didn’t like the Camaro covers on there, going back to no covers on side. I really think the coil relocation kit and different valve covers is the way to go.
10-21-2020, 07:56 AM | #60 |
Drives: 2018 Camaro SS Join Date: May 2019
BlackbeastSS
Took mine to the strip this weekend. Used several methods to launch this baby. With the Nitto G2 it was impossible. Finally just left all nannies on and left off idle and the CPU still pulled it back noticably while trying to break loose at run a horrid 60ft at 1.95 and a 7.74.@ 96 MPH. With just a little traction she will be a 7.3 car. Very impressed with the ported LT2 intake and headers , GPI tune. You gonna need at least a good drag radial. Have fun !!!
GPI ported LT2 intake
Kooks 1 7/8 long tubes high flow cats Mamo ported 87mm TB CAI cold air box Vellosa ram air MBRP axle back E85 Flex fuel sensor Tuned by GPI |
10-21-2020, 08:11 AM | #61 | |
10-23-2020, 12:33 PM | #62 |
Drives: 2018 SS 1LE Join Date: Jan 2020
10-23-2020, 01:15 PM | #63 | |
Now with the extra intake volume and 95 TB I am bouncing around anywhere from above 15 to into the 17. It’s not correcting it’s self and I have triple checked for any vacuum leaks. So a tune is needed in my case.
10-27-2020, 08:12 PM | #64 |
Drives: 2017 1SS cruiser/ 1985 Z28 racecar Join Date: Nov 2018
Maybe I missed it in skimming the post but how is everyone sealing the 95mm TB to the IM once the snout is ported for the 95? Just black RTV?
17 SS 2” ARH headers, high flow cats, and 3”X pipe into NPP, Katech ported 95 mm TB, LT2 IM, roto fab, DSX FF, Katech 160* BMR motor mounts, ATI damper, 493 RWHP
https://youtu.be/E-MDIyLtV48 |
10-28-2020, 03:49 PM | #65 |
You can grab one at Nitrous Outlet that’s where I got mine. . They seem to be hard to find.
10-28-2020, 07:24 PM | #66 |
Drives: 2019 Camaro 2SS Join Date: Aug 2020
10-28-2020, 08:34 PM | #67 |
Thank you.
10-29-2020, 12:18 AM | #68 |
Drives: like an old lady Join Date: Jun 2012
the adapter i bought came with a gasket. ict i believe.
10-29-2020, 03:36 AM | #69 |
The adapter plate I got just came with the O ring gasket for the adapter plate. I think that they think you have a 95 mm gasket already. The new LT5 throttle body I got did not come with one and the same with the new LT2 intake manifold did not come with a 87 mm gasket. Its always something to hunt down when one is trying something new.
10-29-2020, 05:32 AM | #70 | |
