08-26-2020, 12:53 PM | #15 |
Served USN - Atomic Chimp
Drives: 13 Camaro LSX434 TT M6, 21 ZLE A10 Join Date: Jul 2012
Turn the boost controller off and the H2O injection is paused. With the EBC on a working profile for boost, rpm and spray pump duty cycle, why not have it spray while in the street?
In excess of 1,000WHP LSX434 | AGP 65/65 TT | BTR Equalizer Intake | Trickflow 245cc cathedral | BTR custom cam | Cortex EBC | n2mb WOT | ID-1700x | Brisk GR12S | RPM Lv 7 TR6060 | AGP's Triple 525LPH Fore Fuel | Monster LT1-S Triple | 4.11 DSS Proform 9", CF driveshaft, 1400hp axles | Hurst Line Lock | MGW Retro Short Throw w/old skool Hurst T-handle | ADM solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Moreno camber/caster plates |
08-26-2020, 02:10 PM | #16 |
Drives: All things Turbocharged Join Date: Dec 2010
Could be better but if ambient is 100 and you're running 15psi, then 150f is fine. If you were getting that IAT in the winter at 10psi, then you really have a problem.
Indy cars endurance race at 22psi and no intercooler, IAT's over 300 the whole race. Just E85. |
08-26-2020, 02:45 PM | #17 |
Drives: 2014 Camaro SS 1Le Join Date: Feb 2016
I was thinking how it runs similar to meth. Just in case the water runs out and the car will run too lean..
2014 SS 1LE Money Pit/ Forged 402
CAM 22X/24X, .619/.617, 113 LSA/ LS9 Heads FIC 1200cc/DSX Aux Pump//McLeod RXT Clutch 730whp: 630Trq |
08-26-2020, 02:57 PM | #18 |
I will dial in the tune for street without injection. With the injection, fueling should still be fine, maybe a little more fuel than I'd normally run but okay. I'm not going to max tune with injection as that could be unhealthy lean for the motor if empty water tank. I'm not looking for more power - I'm looking for cooler IAT's so timing doesn't get pulled.
08-26-2020, 04:13 PM | #19 |
Drives: 2015 Camaro SS commemorative Join Date: May 2015
Only to brag
104 degrees IAT in the middle of the day, 98 degrees ambient at the top of a 6 second pass. No methanol, just built right.
2015 Camaro SS, LS3 Stroker, PRC heads,CUSTOM CAM. AGP 68/68 with custom Hot and Cold side. Fore triple pumps, Holley terminator X. BMR drag suspension with carlyle brake kit. 15" ET drags and 17" skinnies. ZL1 3.73 gears , aluminum driveshaft. TH400 with circle D converter.
08-26-2020, 05:34 PM | #20 | |
Drives: it changes Join Date: Nov 2010
Depends on fuel, CR, the environment, boost....and how you're reading it. Lots of so called fast IAT sensors...are not fast, so the lag will actually mean the temp can be worse. And of course what you use it for. Simply running 1/8th mile will never be as risky as say a full mile. And most typical IAT thermistors don't really read accurately above around 200degF either although you'd hope you're never up there. Always strive for the coolest air you can. Too high is simply when detonation or engine health poses a problem from it and the tuning you are using for it. But is hot air alone a problem ? No, sure people run no IC and get away with it. Just ensure anything is built/tuned around how it does run. |
08-26-2020, 05:39 PM | #21 | |
Would also love to see some actual flow/pressure testing on the pump at those various duties. |
08-26-2020, 05:43 PM | #22 | |
So intake temps never really rose, but it was only because the sensors was barely responding even by the end of a run when things were cooling down again lol. |
08-26-2020, 08:04 PM | #23 |
Well, even on the street and a single 3rd gear pull, I hit high enough IATs to where I'd like to pull timing (see 3rd plot IAT Retard of -4.4*). This is without WI.
08-26-2020, 09:29 PM | #24 | |
Drives: 2010 1SS LS3 Join Date: Aug 2019
2010 CGM 1SS
408/4L80E/ZL1 ESS G4 |
08-26-2020, 09:37 PM | #25 | |||
200* would worry me enough To do the WI setup too.
2010 CGM 1SS
08-27-2020, 12:00 PM | #26 | |
Also, why so many differing boost readings ? You've one at 225kpa, 20psi and 32psi ? |
08-27-2020, 12:15 PM | #27 | |
This is just a GM sensor and a holley terminator. Same sensor I have always ran. I have checked it and it shows ambient when the car is cold. who knows though, I would like to verify it again.
08-27-2020, 12:21 PM | #28 | |
The really slow crappy one I used years ago was a totally different design, why Bosch even call it an air temp sensor is beyond me, although I guess it would probably have been ok for ambients. A local Motec guy recently posted some testing of a sensor he uses, against the likes of what most would use ( ie yours and mine ) and his was actually impressively fast by comparison.. Although in my case, my charge temps are never much of a concern, so probably doesn't justify an expensive sensor. If they were a lot hotter, I'd probably invest in one though |
