08-24-2020, 06:44 PM | #1 |
Drives: 2010 1SS LS3 Join Date: Aug 2019
IAT’s, How high is too high?
I have looked high and low for an answer. Nothing solid. I know some N/A cars can run high iat’s but cool off during a run. What about boosted cars? Mine will hit 150* from 100* in the 1/8th mile. I’m E85 with a wastegate to limit top end boost.
2010 CGM 1SS
408/4L80E/ZL1 ESS G4 Last edited by Big Biscuits; 08-26-2020 at 09:42 PM. |
08-24-2020, 11:25 PM | #2 |
Served USN - Atomic Chimp
Drives: 13 Camaro LSX434 TT M6, 21 ZLE A10 Join Date: Jul 2012
I've been told numerous values, one being not to worry until you're over 200*F (when running E85). I eased up my IAT timing tables quite a bit with no observable negative effects. I have been testing a 100% distilled water injection system (because cheaper and non-corrosive) and have had pretty good results. For instance, w/o H2O injection and a 11.5psi run-out, I went from 102*F to 140*F (38*F increase). Turn on the H2O injection and I had a 82*F to 91*F (9*F increase). I also think it adds 3-4% fueling, the widebands say I'm slightly richer. I guess H2O adds some octane.
In excess of 1,000WHP LSX434 | AGP 65/65 TT | BTR Equalizer Intake | Trickflow 245cc cathedral | BTR custom cam | Cortex EBC | n2mb WOT | ID-1700x | Brisk GR12S | RPM Lv 7 TR6060 | AGP's Triple 525LPH Fore Fuel | Monster LT1-S Triple | 4.11 DSS Proform 9", CF driveshaft, 1400hp axles | Hurst Line Lock | MGW Retro Short Throw w/old skool Hurst T-handle | ADM solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Moreno camber/caster plates |
08-25-2020, 05:17 AM | #3 | |
Drives: 2011 Camaro SS 6sp Join Date: Nov 2016
In Florida, in about 92 degree (wet) heat, I've never seen over 137*f. And thats after a few 60-140 pulls. Normal iat's are 100-125ish for short street pulls. I have definitely noticed over my progression with this blower, moving down in pulley sizes, the faster you spin it, the hotter it gets. However when comparing to other superchargers, my temps are fairly low. Sorry I dont have the answer for you. Just watch the KR. I can say that from talking to a local tuner, he has seen some ProChargers in the 170 range, and highly suggested they add meth.
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT 1158whp 1017wtq. 2010 CTS-V A6 - "Stock" SOLD 630whp 658wtq 2024 F-150 RCSB 5.0 4x4 waiting for tunes... |
08-25-2020, 06:49 AM | #4 |
Drives: 12 camaro ss, 72 chevelle, 91camaro Join Date: Dec 2013
Its apples to oranges but I'm non intercooled on m1. My iats were over 400 degrees before making some changes. It still went mid 5s on 25psi like that. I dont have knock sensors either, I don't need that kind of negativity in my life.
But for e85 as stated over about 200-250 id start pulling some timing
12 camaro ss 427lsx, th400, f310 heads, crower shaft mounts, gpi specd solid roller, shearerfab 2k hp a/w, twin bullseye 88mm turbos, hughes pro ssx bolt together converter, holley dominator, 8.50 cert, backhalf, Ford 9", 33x17x16 tires, c16 fuel
08-25-2020, 06:53 AM | #5 | |
08-25-2020, 08:22 AM | #6 | |
Yeah, I am too chicken spit to go full tilt like you. I will say it is a blast to drive wastegated to 15 psi. I just need to ease my mind.
2010 CGM 1SS
408/4L80E/ZL1 ESS G4 |
08-25-2020, 08:28 AM | #7 | ||
One day I will be wide open too. Thanks for the input. Makes me feel better about letting her rip.
2010 CGM 1SS
08-25-2020, 09:23 AM | #8 | |
Thanks
08-25-2020, 06:49 PM | #9 | |
I believe adding water acts has a flame inhibitor. Isn't that what octane is? Have seen a few write-ups about it. Might try the Google thing.
08-25-2020, 09:42 PM | #10 |
Drives: 2011 Camaro 2LT Join Date: Oct 2018
Or look into the Alky meth kits. A member has once for sale right now in the classified for a good price. A meth kit would lower your IATs dramatically and add horses (35-40?) if you want to run one.
08-25-2020, 09:43 PM | #11 |
Drives: 2014 Camaro SS 1Le Join Date: Feb 2016
What pump do you use? Any pics? I’m assuming same setup as meth?
2014 SS 1LE Money Pit/ Forged 402
CAM 22X/24X, .619/.617, 113 LSA/ LS9 Heads FIC 1200cc/DSX Aux Pump//McLeod RXT Clutch 730whp: 630Trq |
08-26-2020, 07:22 AM | #12 | |
You may also look in to moving your air intake, Filter to a cooler location. Are your headers coated, look for ways to reduce underhood temps. I would expect to see 50 degrees over a 1/4 mile on a good set up. But there are many factors that effect this number and you need to take all things in to consideration. There is no denying cooler is better, Cooler Denser air can burn more fuel on each combustion cycle. Pissing on the fire is a bandaid for the real problem. Ted.
www.jannettyracing.com
08-26-2020, 11:56 AM | #13 | |
So, now that it works as I hoped except the 1340 nozzle is a little big for my application, going to install something like the flush with carpet mounted PNR Weld tank in the battery well, put the pump back there, and clean everything up. Can be pretty and fast!
08-26-2020, 12:07 PM | #14 | |
Would you always need to run the spray for street application? I’m assuming you do.
