Old 02-24-2020, 10:03 AM   #1
Mark jones
Drives: Camaro
Headliner falling
My 18' ss headliner is falling in the front. Is this covered by a warranty?
Mark jones is offline   Reply With Quote
Old 02-24-2020, 10:11 AM   #2
2017Darkness
2017Darkness's Avatar
Drives: 2019 2SS 1LE
As long as you have less than 36,000 miles it is covered.
2017Darkness is offline   Reply With Quote
Old 02-24-2020, 10:49 AM   #3
jb_camaro_2ss
jb_camaro_2ss's Avatar
Drives: 2017 2SS M6 Arctic Blue
Yep, it should be covered as long as you are still within the factory bumper-to-bumper warranty. If you did any mods related to or close to the headliner (i.e. hard wire a radar detector), you might want to temporarily take it down before letting the dealer take a look. It shouldn't void your warranty and prevent them from fixing the headliner, but it wouldn't hurt as a precaution.
jb_camaro_2ss is offline   Reply With Quote
Old 02-24-2020, 10:57 AM   #4
HCI2000SS
HCI2000SS's Avatar
Drives: 2018 Camaro V6/RS
Mine was doing the same thing. It was covered under warranty, but the dealership said they would have to remove the windshield and entire headliner to do it. So I just ran some fitted type weather stripping across the front, and it looks fine in my opinion
HCI2000SS is offline   Reply With Quote
Old 02-24-2020, 11:07 AM   #5
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
Yeah they have to take the windshield out to replace the headliner! Maybe an upholstery shop can repair it for you. I would give that a try before going the dealership route!
Old 02-24-2020, 11:07 AM   #6
Yellow Beast
TD
Yellow Beast's Avatar
Drives: 2017 2SS, 2014 Mercedes C300
There is a technical bulletin on headliners up to 2017. I would have thought they had fixed the issue by 2018. I guess not. There is no recall. I took my 2017 to the stealership regarding the headliner. The service manager told me theyre all like that, I asked him if i could look at the headliner on a few other gen 6 camaros. One was good, some were worse than mine. I feel bad for the people that dont have a clue. When their headliners get worse and start falling off the warranty will probably be expired. Anyways i knew about the issue from doing some research and i printed the bulletin and showed him. They ended up doing a new headliner and a couple harnesses under the headliner. The correct way to remove the headliner is to remove the windshield. Some stealerships force it out of one of the windows scratching everything. You have to be blunt(not loud and disrespectful) and show them proof in writing even though they already know.
Yellow Beast is offline   Reply With Quote
Old 02-24-2020, 01:26 PM   #7
Mark jones
Drives: Camaro
What held it in from the factory? Dealer needs to pull the windshield work on the headliner
Old 02-24-2020, 06:30 PM   #8
Yellow Beast
TD
They told me the headliner was manufactured too short and the fit wasn't correct causing the headliner to come off. Did they tell me the truth, who knows.
Old 02-24-2020, 07:06 PM   #9
Whocares05050
Drives: 2018 Camaro SS 1LE
My 2018 is starting to droop on the passenfer side. I also have the issue with the windshield fogging up due to the crappy seal around the vent. Both TSBs and voth require the front windshield to be removed. I am waiting till march/april before returning.
Whocares05050 is offline   Reply With Quote
Old 02-24-2020, 08:31 PM   #10
JGiovando
Drives: 2018 1SS 1LE HBM
Had mine done a few weeks back. Noticed it sagging front passenger side, then looked harder and noticed sagging in the back as well. They pulled the windshield, replaced curtain air bags. Headliner looked good replaced. They deeply gouged the dash during removal and scratched my hood wrap. Had to replace the dash and the wrap. Had to rework the wrap as the installer they contracted did a shit job on the under side. After 3 or 4 weeks and multiple trips it's finally all square. Man I hate taking her to the dealer but luckily my service manager made it right.
Hope it works out for you with minimal headaches.
JGiovando is offline   Reply With Quote
Old 02-25-2020, 09:08 PM   #11
Mark jones
Drives: Camaro
If the mirror holds the center and a pillar covers hold the edges, how does it fall?
Old 02-26-2020, 03:12 PM   #12
MackSteelPrivateEye
Mine is a 17' where does it sag. I never noticed a sag but will check today.
Old 02-26-2020, 08:37 PM   #13
JGiovando
Check right where it meets the front windshield. Look at the fabric edge. Seen a lot of posts where it started on passenger side but mine was both sides and also in the rear windshield.
Old 02-26-2020, 08:39 PM   #14
JGiovando
The material is a bit short and with time and heat starts to fall with gravity right along the glass margin.
