Old 03-18-2019, 11:11 AM   #1
Lithias
Lithias's Avatar
Drives: 2019 2SS Riverside Blue Metallic
NPP Valve Squeak
So over the weekend my NPP exhaust valves started squeaking when switching from tour to sport/track and when accelerating in certain gears at certain RPMs. It is a very loud squeaking noise and can be intermittent.
I found an old TSB for this on 2016s that has a procedure to lubricate the valves, so I made an appointment with my dealer to have it looked at and the procedure done.
Has this happened to anyone else with a 2018 or 2019 NPP car?
Does anyone have an updated version of the TSB? I dont know how to search for them but the one I have is #16-NA-003.
Order # WKXN0F 2SS Riverside Blue Metallic, A10, NPP, 56V
Ordered 9/15/18
1100......9/17/18
3000......9/19/18 TPW: 11/26/18
3300......11/9/18 TPW: 11/26/18
3400......11/12/18 TPW: 11/26/18
4300......11/22/18 BUILT! VIN: 1G1FH1R72K0123562
4B00......11/27/18 Waiting for Dispatch! Tentative delivery date of 12/11!
4300......11/28/18 Waiting for the train to Florida!
4200......12/5/18 SHIPPED!
4800......12/14/18
5000/6000......12/18/18 SHE'S HOME BOYS!
Follow me on Instagram! @the_3ngin33r
Lithias is offline   Reply With Quote
Old 03-18-2019, 09:40 PM   #2
speedup
speedup's Avatar
Drives: 2017 2SS Convertible
i had the "repair procedure" done, it was the epoxy fix. it made mine worse. so much so they ended up replacing the exhaust system. that was 6 months ago, its starting to make the noise again now.... love it
2017 2SS, Hyper Blue, 8sp, NPP, MRC
speedup is offline   Reply With Quote
Old 03-19-2019, 11:47 AM   #3
Lithias
Lithias's Avatar
This is NOT the rattle. This is completely different from the rattle.
The squeak seems to be fixing itself, becoming less apparent. Not sure why it started happening, but did manage to show my dealer, so they will be lubricating the valves under warranty.
Ordered 9/15/18
1100......9/17/18
4800......12/14/18
Old 03-23-2019, 02:01 PM   #4
Lithias
Lithias's Avatar
Just wanted to update incase anyone else ever has this problem.
Went to the dealer, they performed the service listed in the TSB even though it had nothing to do with my model year, and it fixed everything right up. No more squeaking valves when changing modes, accelerating, or decelerating.
Ordered 9/15/18
1100......9/17/18
4800......12/14/18
Old 04-11-2019, 02:23 PM   #5
Lithias
Lithias's Avatar
Another update, the squeak has returned.....going to have the dealer lubricate the valves again. If it returns a third time, I'll push to have the exhaust replaced.
Ordered 9/15/18
1100......9/17/18
4800......12/14/18
Old 04-11-2019, 05:11 PM   #6
CanyonCarver
Finding New Roads
CanyonCarver's Avatar
Drives: 2016 Camaro 1SS
My car started doing this in the past month. Exactly as you described.
it's definitely annoying
I sprayed some lube around where I thought it was coming from and it stopped for approx 2 days
I'm WAY out of warranty so I might just live with it. It goes away for me in track mode
CanyonCarver is offline   Reply With Quote
Old 04-16-2019, 07:14 AM   #7
Lithias
Lithias's Avatar
So the squeak returned after only two days. I have started the process with my dealer to have the exhaust replaced. Will update after replacement and a few hundred miles.
Ordered 9/15/18
1100......9/17/18
4800......12/14/18
Old 04-25-2019, 07:29 PM   #8
Lithias
Lithias's Avatar
Quick update to this. GM approved to have the exhaust replaced, dealer ordered the exhaust, and now we wait. My next update will be after install.
Ordered 9/15/18
1100......9/17/18
4800......12/14/18
Old 04-29-2019, 06:45 PM   #9
Riverside2SS
Let's try this again...
Riverside2SS's Avatar
Drives: 2023 Blazer RS AWD Nitro Yellow
Good to hear. At least they are replacing it under warranty.
Round 2:
Ordered 12-19-18 #WRMW0G GKK,MXO,H13,56V,BO4,NPP,F55,BRD,VRV,SFZ,IOT.
1-12-19- 3100 status- TPW 2-11-19
1-18-19- 3300 status
1-21-19- 3400 status
2-18-19- 4300 status- #0134644
3-01-19- 4200 status
3-04-19- 5000 status
3-12-19- 6000 Status
Riverside2SS is offline   Reply With Quote
Old 05-06-2019, 10:12 AM   #10
Lithias
Lithias's Avatar
Well after a weekend, the exhaust replacement seems to have fixed all issues. One thing to note, before the squeak started I could always hear the valves open and close. On the new exhaust I can't even tell, just the engine sound getting quieter. It's dead silent switching open to close and close to open.
Ordered 9/15/18
1100......9/17/18
4800......12/14/18
Old 08-22-2019, 08:31 AM   #11
zla43
Drives: 2018 Camaro 2SS
I just started having the same issue on my 2108 2ss Camaro. I was just wondering if yours hasn’t made the sound since the exhaust was replaced? Also was all of the work covered under warranty? Just curious because I would like to get this fixed under warranty. Thanks.
zla43 is offline   Reply With Quote
Old 08-22-2019, 06:45 PM   #12
cskipgo
cskipgo's Avatar
Drives: 2019 2SS A10 Shadow Gray
I have the same issue. Dealer told me that GM didn't have a bulletin on it and they would wait until GM says what to do?
cskipgo is offline   Reply With Quote
Old 09-12-2019, 05:35 PM   #13
Lithias
Lithias's Avatar
Well unfortunately I return to update.
I am now having a similar problem with the new exhaust except the opposite, it squeaks when the valves close, it's not as bad as last time, but it also still sometimes squeaks on opening. I am going to clean out the exhaust where the actuators are tomorrow with some IronX during my wash and see if it helps, because there is significant build up.
All my repairs were warrantied at no cost to me on the original exhaust.
If it still persists after a thorough cleaning I'll update again.
EDIT: Quick note that I only noticed this new squeak while parked and messing with the switch, could be a heat thing too, as the car was hot after my drive home. Didn't hear it at all when driving where as the previous exhaust the first squeak was while driving with the windows up with radio on.
Ordered 9/15/18
1100......9/17/18
4800......12/14/18
Old 09-12-2019, 09:30 PM   #14
cmitchell17
Drives: 17 2SS, 8L90, Cam, Heads, E85
I had the rattle and had the epoxy fix, then I cut out the AFM valves and still had it, then I finally seemed to mostly stop it with the epoxy fix. Then I did the new fix for the rattle where you grind off the ear, I havent heard the rattle since, but I still feel like there may be some kind of rattle at WOT but the engine is so loud its hard to hear it over that.
Anyway I have also always had the squeak also, its bad right before startup when the engine is still off, it also does it when your idling around in sport mode like when you said the valves start to close.
cmitchell17 is offline   Reply With Quote
