Old 07-26-2019, 07:29 AM   #57
john94si
john94si's Avatar
Drives: 17 2ss vert
Originally Posted by lcd550 View Post
Not sure he said the TSB was new.. i will get details when i go to my appt
john94si is offline   Reply With Quote
Old 07-31-2019, 10:59 PM   #58
lcd550
lcd550's Avatar
Drives: '17 2LT/RS 2.0T M6 50th Anniv Vert
Originally Posted by JBLUES View Post
*raises hand*
Happened to me today.
Found this little beauty rolling around in the roof well.
Any idea what it is?
I searched for the part on gmpartscenter.net but no luck finding it! I believe it's part of another assembly. BTW, it happened to me today. Put the top down and I started to hear a rattle. Opened the top and found the same piece you did. It was on the passenger side.
lcd550 is offline   Reply With Quote
Old 08-02-2019, 01:21 PM   #59
john94si
john94si's Avatar
Drives: 17 2ss vert
Here is my TSB.. they fixed the top pieces according to a new TSB and also the new fluid for my transmission shudder.
NOVEMBER 13 2017
  • TSB #17NA259
    NHTSA ID #10139103
Summary: This technical bulletin provides repair information to correct a customer concern of noise or malfunction of trim door on broken quarter upper trim panel, possible convertible top inoperative.
Old 08-02-2019, 02:54 PM   #60
lcd550
lcd550's Avatar
NOVEMBER 13 2017
  • TSB #17NA259
    NHTSA ID #10139103
Thanks for confirming! That is the same bulletin as the link I found.
I just came back from the dealership (didn't see your post prior to visiting them). I showed the issue and the loose part to the dealer, he pulled on the panel and the part (cylinder fell out). He will be ordering the 4 parts and I'm scheduled for an appointment on Wed, 8/07.
Old 08-07-2019, 11:24 PM   #61
lcd550
lcd550's Avatar
Had the panels replaced today. They didn't change the window regulators claim it wasn't necessary, even though my build date is 10/16. BTW, I did see where the loose part goes and the new panels have them.
We'll see if anything goes wrong down the road (I still have 30monthss and 30K miles to go on my bumper to bumper warranty). BTW, the Service Tech claims the new regulators are noisier.
@john94si...do you notice any increased noise with the new regulators?
Old 08-08-2019, 08:26 AM   #62
john94si
john94si's Avatar
Drives: 17 2ss vert
Not sure if i notice any additional noise. But even if it is noisier i would rather have a working top
Old 08-11-2019, 10:22 AM   #63
Drew145022
Drives: 2017 Camaro 2SS Vert
Anyone attempt the repair themselves? Seem like it will be a issue we will all be faced with possibly more than once.
Drew145022 is offline   Reply With Quote
Old 03-09-2020, 03:01 PM   #64
2016CamaroGirl
2016CamaroGirl's Avatar
Drives: 2016 Camaro SS Convertible
I am so glad I found this thread. Unfortunately, this has happened to my top on both sides. I will be scheduling a service appointment immediately and showing them the TSB. I believe I still have some warranty left since I bought it used in 2018. Thank you all for posting your experiences here.
2016CamaroGirl is offline   Reply With Quote
Old 03-20-2020, 10:28 AM   #65
Nitefall17
Drives: Camaro 1SS A8 Vert
yes, Did mine last night. Very easy took about 10 minutes for one side.
One pin by the top of the back seat and 12 clips. Just pull up and all come right out.
Nitefall17 is offline   Reply With Quote
Old 04-15-2020, 02:40 PM   #66
CamaroSS50
Drives: 2017 Camaro Convertible SS Fifty
As luck would have it, top ripped up the panel again.
This is the 4th time in less than 2 years.
Oh well.
2017 Camaro SS FIFTY Convertible
CamaroSS50 is offline   Reply With Quote
Old 04-15-2020, 05:46 PM   #67
lcd550
lcd550's Avatar
Oh well.
Sorry to hear about it...that sucks!
Old 05-07-2020, 04:18 PM   #68
kennyo
kennyo's Avatar
Drives: 2017 2SS Hyper Blue
Bought a used 2017 last year
Just happenned to me on passenger side with 23000 miles on car
Mods-Corsa Extreme Axleback
kennyo is offline   Reply With Quote
Old 03-20-2021, 06:42 PM   #69
Drew145022
Is this the right part? happened to mine again and I’m not under warranty this time.
Old 03-21-2021, 07:55 AM   #70
17rsvert
17rsvert's Avatar
Drives: 2017 HBM 2LT RS Convertible V6 A8
By the assembly view shown that is the correct part, but I don't think it's that simple.
When the dealership replaced mine under warranty, they also replaced the window regulator underneath. A redesign to the top trim piece includes an extra clip that goes into an added slot in a redesigned window regulator bracket. This change reduced the flexing of the top trim piece plastic, making it less likely that the sliding cover will pop out of its tracks (which results in the coil spring popping loose.) I only found out this detail of the parts involved after my rear window was behaving strangely after the dealer fixed the cover. It was explained to me by a service tech during an additional trip there to get the window problem fixed.
So there are 2 parts involved in the fix, top trim piece and window regulator, and 2 versions of those parts, with and without the extra clip / slot. I have no idea if the new version of the trim piece with the additional clip will fit into the old window regulator bracket or not.
Sorry I could not be more complete with my info, but I just wanted you to be aware that the part swap may not be straightforward. You said this happened again, can you find out if the window regulator was replaced during the previous repair? You may want to check the return policy of wherever you purchase before you buy just in case.
Please post again if you find out anything more. My covers have been fine for the past 2+ years after both sides were replaced with the new parts, but this most likely will be an issue for all of us convertible owners down the road.
17rsvert is offline   Reply With Quote
