Roto-Fab
Old 07-09-2016, 10:13 AM   #1
MAXRS
MAXRS's Avatar
Drives: Camaro RS
Please help need info on camaro side marker socket with wiring
Good morning, I need help identifying where I can find the side marker socket with some wiring for my 2010 camaro pasanger front side Thank you.
2010 CAMARO RS CGM 2LT
MAXRS is offline   Reply With Quote
Old 07-09-2016, 04:50 PM   #2
MAXRS
MAXRS's Avatar
Drives: Camaro RS
Anyone? :(
Old 07-09-2016, 04:52 PM   #3
MAXRS
MAXRS's Avatar
Drives: Camaro RS
Basically need the sidemarker harness
Old 07-09-2016, 07:16 PM   #4
13coupe
13coupe's Avatar
Drives: Crystal Red 1SS Coupe 6spd manual
Here is a socket. Rock auto only showing used.
If the dealer can't get it may have to go used on the wiring too.
13coupe is offline   Reply With Quote
Old 07-09-2016, 08:25 PM   #5
Low Saturn
Low Saturn's Avatar
Drives: 2011 Camaro 2SS/RS
Try visiting your local junkyards if there are any. I'm sure that socket is shared among several other GM vehicles. It's just a socket for a 194 bulb. I think my old Saturn used the same socket.
Low Saturn is offline   Reply With Quote
Old 07-11-2016, 05:01 PM   #6
William.23
William.23's Avatar
Drives: 2011 Summit White.
What seems to be the issue?
William.23 is offline   Reply With Quote
Old 07-13-2016, 01:27 PM   #7
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Drives: 2014 Z/28 #82+#192, 18ZLE 66Nova
If its for the front the harness get the front harness from GM its only $50+
2SSRS@Gen5diy is offline   Reply With Quote
Old 07-17-2016, 07:39 PM   #8
lawman007
Panama-Gulf War Vet
lawman007's Avatar
Drives: '11 SW 1LT/RS 6M
Ever try getting that bitch out? What a hassle. I took it to a local mechanic and he did it for practically nothing. A dealer wanted $150. The instructions say to remove the front tire the lining and you should be able to stick your hand in there. Some of us with big hands have to remove the bumper assembly to get at it. I was able to get it out and change out the bulb, but I could never get it back in the plastic socket holder so I put everything else back together and drove it like that. It's good now.
lawman007 is offline   Reply With Quote
Old 01-10-2024, 12:08 PM   #9
Shibaridecari
Drives: Chevy Camaro 2SS
I think what the OP is saying is that his Side markers do not have power. I have an early 2011 2SS that also has no wiring to the side markers. This past weekend I confirmed this when I had the front bumper off to mount a fog light bar under the grill.
As I understand it he is asking if there is an easy way to harness this into his current lighting scheme. I have the same question.
What do know is that you can but the wiring harness that does have the side marker harness built in. There are OEM and after market. The PITA part is that you do have tp pull the bumper t swap this out.
The other option is to buy a GM light pig tail for about $10. Connect this to the LED wiring and then wire it to anything with power like the running our head lights.
I guress where my question come in is, if I am going to run with the pig tail can I just run the power to the turn signal and have it light up and blink?
Shibaridecari is offline   Reply With Quote
