05-06-2013, 09:26 PM | #29 |
Drives: Red 1SS Join Date: Oct 2010
Amsoil user here. Never had a problem.
Kooks LT Headers/catback exhaust, E-force supercharger, JRE fuel line upgrade, JRE differential, 3.91 LPE gears, Roto-fab intake, JRE tune, DSS Carbon Fiber driveshaft, MGW shifter, Hotchkis chassis braces |
05-09-2013, 08:43 PM | #30 |
Drives: 2012 Camaro SS 45th Anniversary Edi Join Date: Nov 2011
05-09-2013, 09:04 PM | #31 |
by Odeon
Drives: '12 SS/RS A6 IOM SOLD, '13 1LE IOM Join Date: Nov 2011
"It works 60% of the time, every time."
"Some say it's a waste of time, others say it's an incredible waste of time." "The ultimate measure of a man is not where he stands in moments of comfort and convenience, but where he stands at times of challenge and controversy." 2013 IOM SS/RS - 1LE. Born 5/6/2013 (1 of 32 1SS IOM 1LE's) |
05-09-2013, 10:44 PM | #32 |
Drives: 2012 RS/SS LS3 Join Date: Jun 2012
05-10-2013, 08:58 AM | #33 |
Drives: 2013 2SS/RS M6 NPP Join Date: Dec 2012
It is good to see a discussion on engine lubricants and it being sensible and not a flame war.
I became an AMSOIL dealer in 2000. It is in everything I own and has served me well. I have sent in some UOA's that I thought the oil would have been toast and they came back fine and then some that were not. It does make a difference in application and driving style. Everyone is different and each brand of lubricant will show different results in each case. We had a 2008 Acadia with the 3.6. No matter what brand oil I used, it was shot at 5k miles. Each UOA came back with the same result. Now we have a 2011 Acadia and this engine is a little better on the oil but I still can't go past 5k. It isn't as hard on the oil but the high fuel dilution is one of the major factors on the oil taking a hit. What is interesting is the 2011 is direct injected and the 08 was not, but they both had high fuel dilutions. I have noticed that the transmission temp runs cooler since I switched it over to AMSOIL's Torgue Drive fluid. It use to run at 180 and now runs about two needle thickness below that. |
05-10-2013, 12:23 PM | #34 |
USAF retired! Thank God!
Drives: 2011 1SS, 1LT red,1LT/RS SGM 98Z28 Join Date: Jul 2011
Im using Amsoil Dominator 15w50 in mine
HKE LSX427(Mast blk lbl 305 6bolt LS7heads, PatG231/246 blower cam, RWHP/TQ: 1281/1133 SNL Performance Custom Twin PT6766 BB turbos 4 to 25psi selectable on the Boost Leash controller, Squash dual 400LPH/ID2000s, ALKY 4 gal meth, Autometer AFR/Bst/oilpres/oiltemp/fuelpress gauges, Pedders Justice road crs pkg: All HD bushes, supercar 12kg coil overs, supercar ZL1 sways, camber plates all setup by JusticePete! :Gforce 9" 35spline S-Trac, 1500hp Outlaw axles, 3.5"alum DS, Monster Triple disc; 4xForgeline 19x10.5 4xBridgestone 305/30R19 RE-11, CTS-v calipers/rotors/Cobalt friction XR1/3 pads
05-11-2013, 01:33 PM | #35 |
Drives: pleather and Chiclets Join Date: Mar 2012
50? can i have your setup? you dry sump too? i really liked the amsoil z rod... 1.5 thousand miles and a hundred or two on a road course and it came out looking nice and clean with no metal on my magnets.
with that said i just put dominator in my car cuz i didnt want to wait till monday for z rod haha. dominator has less zinc but higher shear rating than z rod
05-13-2013, 10:40 PM | #36 | |
Car will see the road course eventually so may go with an accusump to help a bit. Lots of guys run the accusump with success.
05-14-2013, 12:06 AM | #37 |
the only thing i didnt like about dominator was the red dye
05-16-2013, 10:56 AM | #38 |
Red dye....interesting. I havent added the dominator yet but have a case in my garage. I have been using JoeGibbs HR3 15w50 but figured i'd give amsoil a try since a shop in town sells it to me at cost. $120 a case.
How often do you change these boutique oils. I have been changing at 3000 miles. Haven't tracked it yet since im still finalizing everything. Camber plates, 12kg coils ZL1 rear sway from Pedders this next friday. Then CTS-v brakes conversion with ZL1 rotors(later Racing Brake rotors) from JDP
05-16-2013, 11:13 AM | #39 | |
05-16-2013, 11:17 AM | #40 |
Drives: ss camaro Join Date: Jul 2012
I think everyone is getting off topic from the ops question, mobil 1 would not be good for racing, I agree with that. But the op has a v6 camaro, it is a daily driver, there is no reason for her to waste money on the amsoil.
05-16-2013, 04:10 PM | #41 | |
Agree, standard Valvoline would work well at 5k drain intervals. Since it is a V6 anything past that I would do a UOA. There is also AMSOIL's OE, it runs $4.49 a Qt if you buy it by the case and are a Preferred Customer. |
05-17-2013, 12:14 AM | #42 |
better oil with better wear properties and additives means longer lasting everything. except cats.
how is that not relative for someone who wants to keep her car a good while?
