10-01-2012, 11:55 AM | #29 |
Track > 1/4 Mile
If that was the case then traction shouldn't be an issue
10-01-2012, 11:56 AM | #30 |
Drives: 2011 1LT "Chakita". 04 Yota Join Date: Jun 2011
Lol. That's my thought!
Hi, my name is Chakita. I have cams!!!!
Build thread: http://www.camaro5.com/forums/showthread.php?p=3847083 |
10-01-2012, 12:30 PM | #31 |
Drives: 2015 Camaro 1SS Join Date: Dec 2011
my very first time down the track, I actually did better with the nannies on while I got used to the whole experience. With some more runs in, I turned TC off. It was hard to control the wheel spin at first (BF tires, not Perelli's), but I eventually got a 14.7 in a horrible DA. I would recommend it on if its your first time dragging, but then turn it off and have fun trying to perfect your launch
10-01-2012, 12:48 PM | #32 |
Owning SSes for 50 Years
I am guessing his traction control is cutting power when it begins to spin since he's leaving everything on. I would try everything turned off and lower the pressure in the Pirrellis to around 25 lbs. I'm surprised that this engine/trans combo is having any problems with traction.
The new ride: 2023 Camaro, LT1, Sharkskin Grey
Previous Performance Cars: 1966 Chevelle SS 4M, 2010 Corvette 6M 1968 Dodge Charger R/T Auto 2012 1SS 6M 1982 Corvette Auto 2010 1SS 6A 1984 Corvette Auto 2016 2SS 8A 1999 Camaro Auto 2017 HBM 1SS 1le 2002 C5 Corvette 6M 2018 2SS 2006 Corvette Auto 2023 Camaro LT1 |
10-01-2012, 01:03 PM | #33 |
Drives: 2010 Chevy Camaro 1LT Synergy Green Join Date: Jun 2012
I Went out to the track yesterday, and I was having the same issue - just terrible 60' times 2.5sec +. Only difference I knew I was spinning - Best time I got was 15.13 @ 93mph - My traps were in the 92-95mph area each time. I had traction control off, I brought my RPMs up to about 2000 and feathered it out to get where I did, and I pulled a 2.2sec 60' which was considerably better, but I still had a lot of wheelspin. Live and learn -- I'll be getting some DRs for next outing.
Tires: Pirelli P-Zero All-Weather Tire pressure: 26 lbs Transmission: Manual
10-01-2012, 01:03 PM | #34 |
Drives: 2012 Camaro RS, RX supercharged Join Date: Dec 2009
May have missed it, but are you a manual trans or auto? The nannies on will close the throttle and pull timing as your tires begin to spin so that will slow your ET & MPH the entire run.
Good reaction time, but reaction time has zero effect on ET, but will win races all day long so keep it up! Manual trans your just overpowering those tires and with the nannies off you wont get much improvement either. Get some DR's and watch how well you do. |
10-01-2012, 01:23 PM | #35 | ||||
They see me trollin'...
Drives: 217 ci of fury; Chauffeured by SS Join Date: Jul 2011
"Never race anything you can't afford to light on fire and push off a cliff." -CamaroSpike
2011 Custom LT/RS: Bella's Build Thread |
10-01-2012, 01:33 PM | #36 |
Drives: 2011 V6 Premium Mustang Join Date: Jan 2012
I think the key here is turn off all of your electronic babysitters. The track should be prepped enough that you wont slip and slide all over the place down the track. You probably dont make enough power for that anyways. practice your launch rpm to reduce wheel spin and let her rip. Get that 60' down and your cpu shouldnt get in the way of you getting a good run in.
I had asked the question about you guys cars a while ago about why some people suggest leaving TC on when you're at the drag strip. Cant remember what the outcome was. But we disable EVERYTHING when we run. It may be a SRA vs IRS thing. But I know both our engines kill power when it detects wheel spin. you might have a lot of that going on with part of your TC still activated.
Mods: MPT 93 Tune, FRPP 3.73 Gears, Airaid CAI, Boss 302 STB, J&M LCA, Whiteline Relocation Brackets, Eibach Sportlines, 18x9/10 2010 GT500 rims 255/45, 285/40/18 Nitto555, BBK Longtube Headers O/R X-pipe Up next: BBK 73mm TB, Ported Intake Manifold, DSS Aluminum Driveshaft, Mustang GT 2.75" Overaxle pipe.
2011 Ford Mustang V6: 13.258 @ 107.45 MPH Uncorrected |
10-01-2012, 02:29 PM | #37 | |
Drives: 16 Camaro SS, 15 Colorado Join Date: May 2009
Two...since she has an auto, the car has an open diff which makes it even more difficult to get traction. As far as the TC....TC on doesn't seem to kill the power so much as it seems to regulate it...but I could be wrong there. I've done enough 0 - 60 runs to know what it feels like, and the car doesn't seem to fall on its face...rather the rpms seem to just stay consistent until traction kicks back in. Anyone feel free to correct me on this one. I know some members here (scrming comes to mind) was pulling 2.0 60's on his stock 20s launching with TC from an rpm just over idle. Something else I've heard is to reach down and turn off TC once you've hit 2nd gear. I'm not sure if it really helps, but I'd guess that if the nannies are doing anything after the launch this would help remove that.
2010 Camaro 1LT V6 (Sold. I will miss her!) |
10-01-2012, 02:32 PM | #38 |
Also,
Sure seems very strange that your BF's SS only ran into the mid 14s. Did you see any other stock or near stock times for other cars? If no SS or GTs are getting much into the 13s then something else is at play here (track prep, weather.....track gremlins)
10-01-2012, 02:52 PM | #39 | |
That's really all I saw of other cars.
10-01-2012, 02:59 PM | #40 |
Drives: 11 F150 EB/13 Sonic RS/15 Z06 Join Date: Sep 2010
Where were you running? Sounds like track prep may have played a role. A turbo GTO should run much better than that.
New Ride -- 2015 Z06 2LZ (stock) -- Journal
Old Ride -- 2012 Camaro 2LT/RS (647 RWHP & 726 RWTQ) -- Build Thread |
10-01-2012, 03:01 PM | #41 |
Tulsa. And there was a ridiculous amount of rubber on the track now that I think about it; it was solid black at the tree.
10-01-2012, 03:14 PM | #42 |
Drives: 2011 SS/RS Join Date: May 2011
Frustrated with my quarter times.. suggestions?
2 more cylinders!!! I you..... You know I had to. From what your saying about the other cars it sounds as if track prep sucked or there are a bunch of non driving fools in Tulsa |
