Old 11-11-2010, 07:07 PM   #1
BackinBlackSS/RS
Go Blue!!!!!
BackinBlackSS/RS's Avatar
Drives: 2012 Cruze LT
Thumbs up Vararam installed!!!
Ok, just finished installing the Vararam no tune intake. Overall it was pretty easy to install. The hardest part was getting the intake into the throttlebody rubber hose, but it wasn't too bad. I was a little apprehensive at getting this intake due to all the past problems. However, after getting it installed, firing up the LS3 it purred like a kitten. I let it idle for about 10 minutes per the instructions and then took her out for a ride. Now I did not get on it as the instructions say don't do that for a few miles, but I will tell you she drove smooth as glass. No idling problem whatsoever. My Cherrybomb Extreme exhaust is even a little bit louder. I am 100% satisfied with with this intake. The one thing I would suggest though is to NOT install the MAF sensor until AFTER you have the intake all in place. You have to use a screwdriver to pry the intake into the throttlebody hose and I scratched up the metal plate on my MAF while doing that. It was only cosmetic damage, but had I not removed it, I could have done some real damage. If you have any questions let me know. Here are some pics.
BackinBlackSS/RS is offline   Reply With Quote
Old 11-11-2010, 07:10 PM   #2
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Drives: 2014 Z/28 #82+#192, 18ZLE 66Nova
You will like it a lot.
2SSRS@Gen5diy is offline   Reply With Quote
Old 11-11-2010, 07:19 PM   #3
steeleshark2
steeleshark2's Avatar
Drives: 2010 Transformer 1SS Camaro
Yes you will!! Very nice looking!!
steeleshark2 is offline   Reply With Quote
Old 11-11-2010, 07:22 PM   #4
SlowSS
SlowSS's Avatar
Drives: 2013 Camaro 2SS/RS 1LE
I think one day I will be getting one of these! They look so nice
SlowSS is offline   Reply With Quote
Old 11-11-2010, 07:25 PM   #5
BackinBlackSS/RS
Go Blue!!!!!
It cleans up the engine bay so much. It looks amazing in person.
Old 11-11-2010, 07:31 PM   #6
BackinBlackSS/RS
Go Blue!!!!!
Thanks!
Old 11-11-2010, 07:32 PM   #7
IndeedSS1
IndeedSS1's Avatar
Drives: 2010 Camaro SS LS3
Looks good.
How easy is it to remove the filter for cleaning?
Do you have a scanner? If you do, after a few days and the fuel trims have settle in, can you let us know how what they are?
IndeedSS1 is offline   Reply With Quote
Old 11-11-2010, 07:37 PM   #8
BackinBlackSS/RS
Go Blue!!!!!
Originally Posted by IndeedSS1 View Post
Looks good.
Yep, I have a dashhawk and will be monitoring this. I will let you know. Not sure about the cleaning. Looking at it though, there are two screws on either side that house the filter. Does not look too difficult to do.
Old 11-11-2010, 08:02 PM   #9
nyny69
Drives: 2010 IOM SS
Very nice
nyny69 is offline   Reply With Quote
Old 11-11-2010, 08:10 PM   #10
IndeedSS1
IndeedSS1's Avatar
Cool on the fuel trims.
I've been looking at the pictures of the intake for a while and just wondered what you'd have to remove to gain access to the filter. The install looks easy enough, that even if once a year you had to completely remove the intake to clean the filter it wouldn't be a big deal.
I assume you have the good MAF? I checked mine last night and it is one of the good ones.
Old 11-11-2010, 08:11 PM   #11
Allen English
Every day is a happy day
Allen English's Avatar
Drives: 2011 2SS/RS BLK/BLK
That looks nice. Looking forward to hearing what you think of it.
2011 Camaro 2SS/RS A6 Black on Black
2002 S10 PickUp
2007 Victory Red SS Cobalt "For Sale, My wife wants a Chevrolet Volt"
Allen English is offline   Reply With Quote
Old 11-11-2010, 08:12 PM   #12
xxlbeerz
xxlbeerz's Avatar
Drives: 2010 Black on Black
Looks odd (is it sitting on plastic or some sort of flap?)... but the dyno don't lie!
xxlbeerz is offline   Reply With Quote
Old 11-11-2010, 08:16 PM   #13
steeleshark2
The only thing I haven't figured out what to do with the open space where the stock filter assembly sat.
Old 11-11-2010, 08:18 PM   #14
BackinBlackSS/RS
Go Blue!!!!!
There are two screws on either side of the intake. I believe if you undo those screws you will be able to pull apart the intake and gain access to the filter. Yep, I checked my MAF before I ordered and I had the good one. I tell you it runs great!
Camaro Dove Tail Spoilers Compilation daphatgrant Cosmetics and Lighting Modification Discussions 470 10-28-2020 02:35 PM
Racing Brake 2 pc Rotors Installed mtcwby Suspension / Brakes / Chassis 36 11-13-2010 05:07 PM
Got A Vararam for $10! (Warning long read) shadow09 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 11 04-26-2010 10:44 PM
Check Engine light on after ARH and Pipeline CAI installed se7en Tuning / Diagnostics -- engine and transmission 17 03-10-2010 08:06 AM
Another Dealer Installed Stripe Problem 69er Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 7 07-13-2009 03:32 PM
