Old 10-24-2021, 10:14 AM   #1
BLACK Z
Drives: 2014 2SS
Race Ramps? Which ones?
Hi, I am looking to get ramps, I started looking at ones around $50 and some how I am now up in the 4 to 5 hundred range.
https://www.raceramps.com/ramps/p/rr-xt-2/ Are these decent? Strong enough? I see they make a HD version of these for $100 more just not sure it is needed. Any other choices? I want to be able to change fluids easily and be able to time bushings if needed.
https://www.raceramps.com/c/ramps/
Thanks
BLACK Z is offline   Reply With Quote
Old 10-24-2021, 10:25 AM   #2
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
Those are the ones I bought from Summit Racing back last year for my ZL1 and they work great. No issues using them and well worth the money I spent.��
Old 10-24-2021, 10:28 AM   #3
Village Idiot
Drives: 2019 Camaro SS
I have the 56" version of those, lowered on BMR and with a ZL1 style splitter it touches but doesn't scrape. I'm sure the 67" would give more clearance and there's plenty of room for oil changes and stuff.
Village Idiot is offline   Reply With Quote
Old 10-24-2021, 10:30 AM   #4
cthulhucaller
Drives: 2022 1SS Team Joe and Becky
Thanks
Regular ramps and 2 chunks of 2x10 wood have worked well for me on a lot of low cars. The fancy ones are nice, but personally, I have other tool areas I like spending money on as of now.
cthulhucaller is offline   Reply With Quote
Old 10-24-2021, 10:39 AM   #5
metros11
Drives: 2018 SS 1LE
I use the ones from Harbor Freight for $40 and they clear just fine.
metros11 is offline   Reply With Quote
Old 10-24-2021, 11:41 AM   #6
Chutzpah
Chutzpah's Avatar
Drives: Wild Cherry LT1
Wow, everybody’s jumping on the the inflation bandwagon. I have the 2 piece 67” ramps. I paid ~ $300 maybe 5 or 6 years ago. I love them. Easy to store, light, gets the car nice and high.
Old 10-24-2021, 11:53 AM   #7
Camaro fanboy
Camaro fanboy's Avatar
Drives: 2017 2SS Arctic blue fully loaded
Camaro fanboy is offline   Reply With Quote
Old 10-24-2021, 12:07 PM   #8
Trochoidal
Drives: 2017 Camaro 2SS A8
I also have the 67” 2 piece and they’ve been great for getting the car high enough in the air to work underneath. It’s nice to remove the “ramp” portion without crawling around too much because it’s in the way. Did I mention they’re light too?
Old 10-24-2021, 12:17 PM   #9
s346k
s346k's Avatar
Drives: like an old lady
if the ramps really are in the $4-500 range, i see them foolish to buy. at that point why not buy a quick jack? one can easily mitigate the cheap ramps with some 2x4s. i've been using pieces of wood + my 15 year old rhino ramps since i bought the car.
edit: i have used race ramps. they work well but they are still just ramps.
s346k is online now   Reply With Quote
Old 10-24-2021, 03:44 PM   #10
BLACK Z
Drives: 2014 2SS
I don't mind spending the money ion an item I will or should at least have for life, If I buy a cheaper item and fight with it every time I use it is not worth it to me.
Old 10-24-2021, 04:13 PM   #11
Old 10-24-2021, 10:19 PM   #12
cdrptrks
cdrptrks's Avatar
If you have a front splitter it may not clear Rhino ramps. For the SS 1LE I use RV leveling blocks in front for a lightweight option instead of boards...no need to spend hundreds of dollars on race ramps.
https://www.camaro6.com/forums/showp...9&postcount=22
Old 10-25-2021, 05:41 AM   #13
BLACK Z
Drives: 2014 2SS
I am open to other suggestions, i just want them to be safe and not turn into a project every time I use them. I thought about building my own as well, but to do it right they will be heavy and with lumber still up not to cheap as well.
Old 10-25-2021, 06:30 AM   #14
10mm
Drives: My wife nuts...
I bought four of these, plenty of room under there for me.
10mm is offline   Reply With Quote
