Old 03-14-2022, 08:15 AM   #1
IntegraR0064
Drives: 2019 Camaro SS 1LE
Anybody try 325/30/19 tires on 19x11 square on SS 1LE?
Hey guys,
I drive a SS 1LE and the main class I care about is SCCA time trials S2 class. So I have maxed out camber and 19x11 square wheels and otherwise totally stock. We're not allowed fender mods or camber plates. The wheels are the Apex ones with the perfect offset - ET11 front ET43 in rear. I've been running 305 square supercar 3 tires (200TW minimum tires for SCCA TT) and they've worked great even though it pokes out in the front a bit. Now we have a tire shortage and I'm thinking about my options since I can't get 305's. I noticed 325 supercar3 is in stock so I was considering that. I know some have run that in the rear, but have no idea if it'll work in the front.
I'm thinking I might need to run a small spacer in front for inner clearance, and on the outer clearance side even when I had tire poking out in the past it seemed to be fine.
Technically at the moment my alignment isn't totally maxed out yet, only close, so once I do that then I can try to take some measurements but was curious if anybody had thoughts or experience.
-Jon
2019 SS 1LE doing work as a SCCA S2 Time Trials car and FS autocross car
IntegraR0064 is offline   Reply With Quote
Old 03-14-2022, 10:47 AM   #2
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
325 square is going to have alot of poke in the front and may not even fit especially if you have no camber mods
Old 03-14-2022, 10:49 AM   #3
DaveC113
DaveC113's Avatar
Drives: 2018 Camaro 1SS 1LE
It's possible. One guy I know has run 335 square on 12s for autox. You may have some clearance issues up front but a little strut grind and/or spacer should work...
DaveC113 is online now   Reply With Quote
Old 03-14-2022, 11:13 AM   #4
VR Baron
SoCal Camaro5 Race Team
VR Baron's Avatar
Drives: 2021 Shadow Grey Camaro 2SS 1LE
Yeah clearance will be a issue. I have 19x 10.75” wheels with 15 offset, about same as your 11” with 11 offset . I run 305 re71s that don’t run quite as wide as Goodyear’s. I have the strut mod and run -2.5 front camber. With that combo I need to run a 3mm spacer just to get about 4-5 mm clearance. If you max out camber with strut mod, which will be about -2.7 depending, you will need a bigger spacer. Say about 15 mm. Another thing, 325s are most likely to big for a 11” rim. Tire people may not want to or be able to mount them, and when you squish a big tire on narrow wheel, the actual amount of tread on the ground maybe no more then a 305. Maybe.
VR Baron is offline   Reply With Quote
Old 03-14-2022, 12:23 PM   #5
IntegraR0064
Thanks. And he didn't mod fenders or do camber plates?
Thanks, when you say "strut mod" you mean grinding a notch in the strut for clearance, right?
I ran 335 hoosier A7 on my viper on the front 18x11, and grip was better than 315s, so it's not the end of the world pinch wise but those things were pretty pinched so you're right. That was an autocross car, not sure how I'd feel about that on track.
I think for now I'll keep running the tires I have, i used them a decent amount below freezing so they're probably a little hard but they have tread, hopefully the 305s become available again by the time the first actual time trial comes up.
-Jon
Old 03-14-2022, 12:49 PM   #6
DaveC113
DaveC113's Avatar
I believe 325s are listed as acceptable for 11s, I have 315s on my 11s right now and it's about perfect. I think it'll be fine.
Right now I have 305/30/19 RE71s up front on 19x11 et 35, 26mm spacer, 2.5 camber, strut ground for about 5mm more clearance only because it takes 2 min with a grinder, lol... There's plenty of clearance. In fact one time I forgot the spacer, put a wheel on and it barely even touched the strut so I'd guess I have a bit over 20mm clearance which would allow 325s.
The guy running 335s does have camber plates but he runs 18x12 et 41 with 28mm spacers up front. Must be pretty tight but it works!
Old 03-14-2022, 12:59 PM   #7
VR Baron
VR Baron's Avatar
And there you go. Though what I posted up on my clearance is where the rim lip area was closer then the tire side near the top half of the tire sidewall. More clearance there. But got worn off paint at top of strut where you can’t grind anymore off. So interesting you got that much clearance.
Old 03-16-2022, 10:40 PM   #8
Mountain
Mountain's Avatar
Originally Posted by IntegraR0064 View Post
Hey guys,
You can’t run 325’s in S2. Limit is 315’s.
https://timetrials.scca.com/pages/sp...ory-full-rules
Old 03-17-2022, 07:58 AM   #9
Msquared
Msquared's Avatar
Drives: Chevrolet SS 1LE
A word of caution on comparing 325/30/19 tires to 335/30/18: the former is 0.8" taller than the latter, so any diameter-related interference is likely to be worse for the 325 even though it's nominally skinnier. I think you'd most likely find this at the top of the fender edge and where the corner of the sidewall/tread meets the strut.
To the OP, why not consider a 315/30/19? That size is available in both the Falken RT660 or the Conti EC Force. Of those, I would expect the Conti to be similar in performance and longevity to the Goodyear SC3 and the Falken would provide faster laps unless/until it overheated.
Matt Miller
2020 SS 1LE
Msquared is offline   Reply With Quote
Old 03-18-2022, 12:34 PM   #10
IntegraR0064
Oh wow, i either totally missed that limit or it's a recent addition. Either way, that's the nail in the coffin for 325's. Thanks!
My understanding is the Conti's are slower for sure. The Falkens are probably what I'll do if 305 SC3 isn't available in time. Really like the SC3 though.
So yeah my plan is clear now, try to hold off as long as possible for 305 SC3 and if that doesn't work get some Falkens. Thanks for all the input.
Old 03-19-2022, 11:19 PM   #11
DaveC113
DaveC113's Avatar
Ok, I double checked this yesterday and I have to admit I was off by a little bit, clearance with 2.5 deg camber + mild strut grind is closer to 10mm than 20 with my setup, but I could grind more off, maybe 5mm or a little more. I think 325s would work but camber plates would be ideal to get more clearance. For reference I have 19x11 et35 + 26mm spacers.
Also, my friend who ran 335 square on 12s did not have magride and did have camber plates. Magride has less clearance. 335s on 12s with magride might not work out that well!
Old 03-20-2022, 10:14 AM   #12
VR Baron
VR Baron's Avatar
Dave, good you got that much even. My 19x 10.75” wheels with 15 offset and 3 mm spacer is like a 11” with 9 mm offset if my math is right. It’s hard to measure back there, but All I can get near the ground off strut area is about 5mm. Stock wheels and tires is about 6-7mm, the 20” tire sidewall being closer vs the 19” wheel rim area.
Old 03-28-2022, 08:18 PM   #13
Sephx1
Sephx1's Avatar
Drives: 18 ZLE, 18 SS1LE, 16 SS, 23 ZL1
I have the Apex 19x11/305 setup with negative 2 degrees camber up front and the car clearly needs more. Does yours have Magride? Mine does. Looking to find out how much more I can get without plates.
Sephx1 is offline   Reply With Quote
Old 03-28-2022, 08:42 PM   #14
Heartbreaker
Heartbreaker's Avatar
Drives: 2020 Camaro ZL-1 1LE
Arc-8
Hey guys,
I run 325/30/19 Apex Arc-8 (11 “) on the rear no problem
Home Track: NCM Motorsports Park
Heartbreaker is offline   Reply With Quote
