12-10-2021, 05:18 PM | #1 |
Drives: 2018 Chevrolet Camaro ZL1 A10 Join Date: May 2019
First time on the drag strip tonight, tips?
Taking my lovely ‘18 ZL1 to the drag strip tonight. Any recommendations or tips since this is the first time I’m taking any vehicle. I know how to do the launch control in theory but haven’t done it in practice since there is just no good spots in the city to try it on - except the drag strip!
12-10-2021, 05:30 PM | #2 |
376 cubic inches of fun
I would advise against launch control for a newbie. Just put the car in track mode.
Once you have fully staged, put your left foot on the brake. When the 3rd yellow light goes on, release the brake and simultaneously apply the gas. Do NOT stab it. Count "one thousand and one" while gradually going from idle to wide open throttle. If you get wheel spin, try to slow down the throttle application next time around. If you just start with launch control, you won't learn much about your car. |
12-10-2021, 05:37 PM | #3 |
I also agree with Rock-it Man. First time down the track I’d get used to the car. Not knowing how well you’ll react to the car breaking loose, you might even want to leave the “nannies” on.
My first pass I turned off traction control and stabilitrac. As mentioned, I’ve never had any good launches in the SS except off from an idle. This was on street tires and not drag radials. With your ZL1 you may find a different technique works better for you.
12-10-2021, 06:29 PM | #4 |
Thanks for the advice everyone! I’ll lyk how I do!
12-10-2021, 06:35 PM | #5 |
Drives: 2022 ZL1 M6/Nissan Leaf Join Date: May 2016
If your car goes into limp mode, try not to call On-Star while the top fuelers are drag racing. Believe it or not, a buddy of mine did that once. I could almost see the On-Star rep flagging his warranty.
12-10-2021, 06:50 PM | #6 |
Drives: 2022 zl1 Join Date: Apr 2021
Lucky you i took mine home from the dealer two weeks ago and straight into storage until May. Montreal weather is not winter drag racing friendly to put it mildly.
12-10-2021, 07:02 PM | #7 |
If you're on street tires...do NOT do a big smokey burnout. Just spin the tires for a couple of secs to clean off any debris.
Leave off an idle. Don't manual shift, let the car shift.
12-10-2021, 07:22 PM | #8 |
Push the gas down like there’s an egg under it
12-10-2021, 07:26 PM | #9 |
Drives: 2018 Camaro ZL1 Join Date: Aug 2018
Put the suspension into tour and don't use launch control.
12-10-2021, 07:40 PM | #10 | |
I had to crank the A/C up here because we reached 80 F (26.66667 in Canuckistan). In Texas we don't call them "Summer only tires" we call them, "All year but those two weeks tires". |
12-10-2021, 10:43 PM | #11 |
Well I did abysmal! Lol But I got some practice under my belt. First time on track got 15.09 in tour mode. Awful…second time I improved at 13.347; much better but not what this car is capable of. On the second run I had it in track mode and at the start I spun too much, had it not been for the spin I would have had at least 12 or maybe high 11. Overall it was a lot of fun and I can’t wait to do it again!!
12-10-2021, 11:04 PM | #12 | |
aka BeastZL1
Drives: 2019 Camaro ZL1 1LE, 2004 Cobra Join Date: Dec 2017
I'm #4 on the ZL1 Stock 1/4 mile list.
ZL1 A10 Vehicle Settings: Suspension = Tour Track Mode PTM Race Launch Control 10% Slip, 1700 RPM 26 PSI in Rear Tires 3-5 Second Burn Out
12-10-2021, 11:53 PM | #13 | |
12-11-2021, 12:48 AM | #14 | |
Drives: 2023 Silverado LTZ, 2022 Camaro 2SS Join Date: Jul 2010
Instead of launch control you can just leave at 1,000rpm. If you don’t spin try 1250 and then 1500. 26 pounds is important.
Currenent rides: 2020 SW ZL1 A10 2019 SW 2SS A10 2017 SW Silverado LTZ |
