Vararam
Old 09-01-2021, 11:50 PM   #1
C@mero
Drives: Camaro 1LE
Which Displacement would be better?
I have my D1x ordered and I’m going to build a new long block. Want to be at the 1000whp mark. Contemplating on either staying stock cubes or go bigger.
My question is… If ALL things are equal (CR/boost/fuel etc etc), which engine would net more power? Fully forged 376 or fully forged 408/416?
Track car only. Maybe some weekend fun runs.
C@mero is offline   Reply With Quote
Old 09-02-2021, 02:22 AM   #2
ttshovel
ttshovel's Avatar
Drives: 12 camaro ss, 72 chevelle, 91camaro
Cubic inches is power, all else being equal. But I will say that for a longevity standpoint I'd stick with a stock to 3.75 stroke to keep a better compression height.
Don't be afraid of compression, and run e85 if possible. That's the only 2 other things I've got for you
12 camaro ss 427lsx, th400, f310 heads, crower shaft mounts, gpi specd solid roller, shearerfab 2k hp a/w, twin bullseye 88mm turbos, hughes pro ssx bolt together converter, holley dominator, 8.50 cert, backhalf, Ford 9", 33x17x16 tires, c16 fuel
ttshovel is offline   Reply With Quote
Old 09-02-2021, 06:58 AM   #3
Greenhornet2
Greenhornet2's Avatar
Drives: 2011 Camaro 2SS LS3 Whipple
more cubes make more power as long as you have the supporting mods to supply it. You will need to upgrade your cooling system though.
Whipple 2.9 CAI ID1050x injectors ZL1 Pump JRE FPCM JMS Voltage booster JRE Rough Idle blower cam BTR .660 springs CHE trunnion kit 1 7/8 Speed Engineering Borla Atak JRE scoop 1.5" lowering springs BMR trailing arms and toe links Cradle inserts 704WHP 603WTQ 93 octane
Greenhornet2 is offline   Reply With Quote
Old 09-02-2021, 07:08 AM   #4
C@mero
Drives: Camaro 1LE
It’ll be on Flex for sure. Got the Fore ordered and ID 1700s. I was thinking around 10.5:1. Not planning on going too crazy with boost. Maybe around 15lbs.
Old 09-02-2021, 10:08 AM   #5
C@mero
Drives: Camaro 1LE
I have 1 7/8 LTs right now, maybe bump up to 2”. I’ll have the obvious cam/heads (Frankenstein).
Cooling as far as radiator upgrade? OR better intercooler?
Old 09-02-2021, 10:34 AM   #6
Greenhornet2
Radiator at least maybe different fan setup. I'm not sure what everyone is running but have read that the bigger CI the stock system can't maintain temps. 1 7/8th headers aren't much of a restriction until I believe around 800whp. That is not to say you wouldn't still benefit from them if you are lower than that. Even I would see some gain with 2" but it breathes fine where I'm at.
Old 09-02-2021, 01:10 PM   #7
ttshovel
ttshovel's Avatar
For what it's worth I've always ran a half sized radiator when I was on e85 and now on m1. Cooling temps were perfectly fine.
Old 09-02-2021, 03:50 PM   #8
C@mero
Drives: Camaro 1LE
Definitely something to consider since the engine will be out of the car anyway.
Do you drive the car on the street, or strictly track? Your 1/2 size is maybe more efficient… maybe?
Old 09-02-2021, 04:29 PM   #9
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Drives: Bone Stock LS3
Send a message via AIM to SSE 4 2SS Send a message via Yahoo to SSE 4 2SS
I run a 417 cubic inch motor at 10.5/1 compression on C-16. With a half filled block, and a dual pass radiator, I run cooler temps than stock by a substantial amount…
Coolant temps at the end of a one mile WOT pass are in the 190 degree range max depending on ambient temps….
Yes I drive it on the street…. Though it isn’t a blower car…
While the old adage there’s no replacement for displacement, don’t forget to consider rpms….
Build a long block for higher rpms….
If the car feels like it is on rails, you are probably driving too slow. -Ross Bentley
Horsepower is how fast you hit the wall.
Torque is how far you take the wall with you.
“If everything seems under control, you're just not going fast enough.” Mario Andretti
If you can turn, you ain't going fast enough...
SSE 4 2SS is offline   Reply With Quote
Old 09-02-2021, 04:31 PM   #10
eLeSthree
Drives: 2011 Camaro SS 6sp
I was about to say, I live in FL and never had an issue with the stock radiator on an iron 427. I upgraded to a $167 ebay radiator (physically broke the plastic one) and my temps are solid 196-201 stock fans, stock thermo, modified tune.
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT
1158whp 1017wtq.
2010 CTS-V A6 - "Stock" SOLD
630whp 658wtq
2024 F-150 RCSB 5.0 4x4
waiting for tunes...
eLeSthree is offline   Reply With Quote
Old 09-02-2021, 06:20 PM   #11
C@mero
Drives: Camaro 1LE
When I meant track, I meant drag strip. No road course near me.
Any recommendations that won’t break the bank, or would the oem suffice? When I do drive on the street, it’s mostly highways.
I was thinking of going up to 6800rpms
Saw your old comment with the fan
“ Exactly what I was going to say. Adjusting the tune to make the fans run at %50 power under 192 degrees, then %70 up to 196, then %91+ made a bigger difference than upgrading my radiator.”
Old 09-02-2021, 07:45 PM   #12
ttshovel
ttshovel's Avatar
When I ran it on e85 I street drove the car. Iron, 3/4 filled block and a cheap dual pass, 22" wide griffin with a spal fan. Nothing exotic. Stock water pump and accessories to boot
Old 09-03-2021, 06:32 AM   #13
Greenhornet2
Ok, maybe i'm wrong then. I did read a thread of an over 400 CI person having an overheating issue and everyone chimed in with what they did to combat the issue. Most was new radiator. I can probably find the thread. Now I Don't know exactly what his setup was, or if he was running E85.
Old 09-03-2021, 08:37 AM   #14
RealQuick
Drives: 2010 Camaro 2SS M6 - Intake/Exhaust
Anyone else think a D1X is a little small for the bigger cubed motors? Especially if you want 1000rwhp @ 15psi.
RealQuick is offline   Reply With Quote
