09-11-2021, 09:34 PM | #71 |
Drives: 2017 ZL1 A10 & 2021 BMW M340i x Dr Join Date: Mar 2009
So, if he left it at 14.1 and is commanding .82 isn't that 11.5 afr and isn't that on the rich side? Or am I misunderstanding?
Sold 1967 Camaro Pro Street. Ran 10's mild BB on NOS. 2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17 2020 Build: Mag2650, BTR Stage2, NW103, BG, 14% lower, 90mm upper, ARH 2" Long system w/no cats, SW Legend mufflers. **807hp/762tq on 93 gas** and **848hp/792tq on e47** Sold 2018 (Go Mango) Dodge Charger Daytona 392 Daily Driver Daily Driver 2021 BMW M340i Xdrive |
09-11-2021, 09:47 PM | #72 |
Drives: 2019 ZL1 Join Date: Mar 2019
.82 is 11.9AFR using stoich 14.1
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90 |
09-11-2021, 10:13 PM | #73 |
Then I must be using wrong formula. Thought it is afr/stoich..11.9/14.1 = .84
09-12-2021, 08:24 AM | #74 | ||||
AFR to achieve Lambda is based on the fuel composition. Lambda is the same across all fuels. Set your wideband to read lambda and avoid all confusion. All AFR gauges use a Lambda sensor and the gauge converts it to AFR based on a user input for the fuel they are running, Default is 14.7 for Pure Gasoline but you can go in the gauge settings and change Stoich value to match your fuel. Since AFR changes with Ethanol content it is far too confusing to keep track of what normal readings are. Lambda 1 is cruise and .82 is WOT. The stock sensors are also lambda sensors but Narrow band which means they are only accurate at Lambda 1. Any variation from Lambda 1 results in STFT which then transfers over to LTFT which ultimately is your Error from perfect calibration. Ted.
www.jannettyracing.com
09-12-2021, 08:52 AM | #75 |
Stoich AFR on a GAS scale is 14.7. E10 is 14.1.
.82 Lambda converted to a gas scale reading is 12.2 AFR. .82 Lambda converted to a E10 scale is 11.9 AFR. Look up the unit conversion in your VCM scanner. The options are Lambda(best), AFR for Methanol(6.4), Ethanol(9.0), Diesel(14.6), Gasoline(14.7). There is no E10 scale. And for this reason, Unless you are running 100% gasoline, Lambda should be used as a reference for AFR... then if you want to see a reading on a gas scale you convert it using 14.7 not 14.1. Now the confusion here is how WOT(PE) enrichment is calculated. The ECU uses the stoich value of the fuel you are running and divides it by the PE multiplier and that is the target AFR. So if you are running E10 fuel then the ECU is taking the stoich value of 14.1 and dividing by PE numbers populated in the power enrichment table. For example, 14.1 / 1.205 = 11.7 afr for E10 but that isn't gasoline AFR scale. You have to use Lambda then convert it back to AFR scale using 14.7. And this is why Lambda is used to avoid all the confusion between different AFR's for different fuels. Lambda is 1 regardless of the fuel used.
2016 NFG 1SS A8
09-12-2021, 09:59 AM | #76 |
Also want to add I really appreciate the feedback. Just trying to fully understand it and hopefully it helps others too.
Also, what PE is being used to achieve the .82? Is it based on the 14.1 or 14.7 ? For example..my pe table is at 1.150 and my stoich set to 14.1, what is my Lambda then? .833?
Sold 1967 Camaro Pro Street. Ran 10's mild BB on NOS. 2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17 2020 Build: Mag2650, BTR Stage2, NW103, BG, 14% lower, 90mm upper, ARH 2" Long system w/no cats, SW Legend mufflers. **807hp/762tq on 93 gas** and **848hp/792tq on e47** Sold 2018 (Go Mango) Dodge Charger Daytona 392 Daily Driver Daily Driver 2021 BMW M340i Xdrive Last edited by IneedAZ; 09-12-2021 at 11:52 AM. |
09-13-2021, 07:36 AM | #77 | |
I can't say it enough stop with the AFR. Set the Stoich value for the fuel you are burning, then use LAMBDA I see this alot, Some how, some way, Tuners just don't understand how this works, you would think everyone who tunes would know this but they don't. Quite honestly I have seen these discussions for many years and have tried to help but it continues. I tune N/A DI cars at PE 1.16 Or .86 Lambda, and Boosted DI cars at PE 1.22 or .82 Lambda PI cars are PE 1.18 or .85 Lambda and boosted PI cars PE 1.28 or .78 Lambda 1.15 on a boosted application PI or DI is insane. Just because you command 1.15 does not mean you will achieve it that comes in the way of the MAF calibration. Which means that if you are achieving .82 and PE is set to 1.15 then the MAF cal is a train wreck. At the same time If Stoich value is not set correctly for the fuel you are burning another train wreck occurs. Here is something to think about. There is no such thing as an AFR sensor, but there are AFR gauges. Ted.
09-13-2021, 11:29 AM | #78 | |
Either way, that is a big difference from what you have at 1.22 PE vs my 1.15. Odd that 2 different local shops want to run the car that much leaner than you. As mentioned original tune was 1.155 which is close to the 1.150 i have now. Also this makes me wonder if i should NOT try adding the e30 or e40 as suggested. I was hoping to move away from the Boostane by running e30 or e40.
Sold 1967 Camaro Pro Street. Ran 10's mild BB on NOS. 2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17 2020 Build: Mag2650, BTR Stage2, NW103, BG, 14% lower, 90mm upper, ARH 2" Long system w/no cats, SW Legend mufflers. **807hp/762tq on 93 gas** and **848hp/792tq on e47** Sold 2018 (Go Mango) Dodge Charger Daytona 392 Daily Driver Daily Driver 2021 BMW M340i Xdrive Last edited by IneedAZ; 09-13-2021 at 11:39 AM. |
09-13-2021, 12:48 PM | #79 |
Just because they are using 1.15 as a PE multiplier doesn't mean it's running lean.
If 14.1 is the number populated in the 0% column of the stoich table, then your ECU is using the Formula 14.1 / 1.15 = 12.26 target AFR. Ted is using 1.22 because the 0% column of the stoich table is probably set to 14.7. 14.7 / 1.22 = 12.05 Either way, You should go out and log a pull... make sure you are logging your Wideband in Lambda and Maf vs EQ error in histogram. It's the only way to know instead of sit here on the forum and guess at it.
2016 NFG 1SS A8
Options-2SS Leather/NPP Perf. mods-Whipple 2.9/Fuel System/Flex Fuel/103mm TB/Rotofab Big Gulp/Cat Deletes/Corsa NPP Per. times- 10.5 @ 137 w/ 1.8 60ft Full weight on 20's 1200DA Last edited by KingLT1; 09-13-2021 at 12:59 PM. |
09-13-2021, 01:42 PM | #80 | |
Again, appreciate everybody posting
09-13-2021, 01:50 PM | #81 | |
09-13-2021, 04:17 PM | #82 | |
My PE table is 1.22 regardless of fuel burned, Lambda 1/1.22 = .82 I don't really care what the AFR is. My stoich table is set to the appropriate AFR for the fuel burned or Flex fuel sensor. My VE and MAF are tune to achieve commanded Lambda both in closed and open loop. You have to stop trying to use formulas to convert AFR to Lambda. We use Lambda, as it is the same across all stoich values. You only need to know the Stoich value of the fuel at the beginning of creation of the tune and should obtain that from the fuel manufacturer. After that its all Lambda. Like I said just because your commanding .90 lambda does not mean your running .90 the end result is derived from the MAF calibration and will show up on your gauge. If your car is showing .90 lambda at WOT STOP IMMEDIATELY.
09-13-2021, 04:18 PM | #83 | |
09-13-2021, 04:35 PM | #84 |
I believe it is but will double check. It is an Aeroforce intercepter gauge and wideband setup.
