02-03-2020, 03:09 PM | #1 |
Drives: 2016 2SS Camaro Join Date: Mar 2010
Can't restart after 10 minute drive "dead battery"
This is an ongoing issue since day one of owning the car. Starter has always been slow to restart shortly after a drive. Like going into a store for 5 minutes then returning to car for restart.
Replaced battery after 2 years. Now the newer battery (from dealer) has needed jumps after short stops. It seems fine if I leave it for >3 hours. I read about a lot of issues here with batteries on the camaro 6 ss, but this is very specific. Starts fine after sitting overnight. My car is out of warranty with 34K miles (2016 2ss) |
02-03-2020, 04:43 PM | #2 |
Drives: 2017 2SS / 2003 S10 Crew Cab Join Date: Oct 2019
If it starts every time after sitting over 3 hours to cool down that would suggest a starter drawing too much current when the engine is hot. It would be worth the investment to have a competent shop test the charging system and battery. Aftermarket exhaust such as headers can cause starter issues when warm.
Never say never! |
02-03-2020, 08:15 PM | #3 |
Drives: 2016 2SS M6 Mosaic Blk Met-SOLD Join Date: Jun 2016
This starter heat soak issue has been discussed many times in the forum. Do a search and you will get lots of ideas: heat shield, new starter, new battery, new battery ground, etc.
Also the starter is under warranty up to 60,000 miles.
Official Detailer of CamaroFest 8 & 9
https://www.autogeekonline.net/forum...st-8-pics.html https://www.camaro6.com/forums/showt...=521655&page=1 https://www.camaro6.com/forums/showt...=547470&page=1 https://www.camaro6.com/forums/showthread.php?t=527474 No one on Earth has detailed more Camaros. http://KirkTheDetailer.com |
02-04-2020, 07:14 AM | #4 |
Drives: 2016 Camaro 2SS Join Date: Jan 2015
I notice you are in Miami where its usually very warm. I've had the same problem with mine when its hot out. I had the starter wraped in a heatshield but it didnt help. I got stranded for a while down when I went to Miami for xmas. Had to wait for it to cool off before it would crank back up so the heatshield isn't the answer.
I just had a 2nd ground installed last week when I took it in for regular maintenance. Read this... https://www.camaro5.com/forums/showthread.php?t=504199 |
02-10-2020, 12:17 PM | #5 |
Camaro Fan
Actually the starter is not covered the powertrain warranty.
Ordered: Garnet Red Tint coat 2016 Chevrolet Camaro 1SS, Auto, NPP
1100 Status: 8/6/15 3800 Status: 10/13/15 VIN #116519 4200 Status: 12/19/15 Delivered : 12/28/15 |
02-10-2020, 01:10 PM | #6 |
Old school tech
Drives: Ruby 1LE - 2024 2SS 1LE Join Date: Mar 2014
Starter is possible, I'd also look at battery cable junctions. Excessive resistance at junctions can cause poor charging and starting.
02-11-2020, 01:08 PM | #7 |
Drives: 2019 ZL-1 Join Date: Feb 2009
You need a new starter. Some of these come from the factory "weak" and just dont swing a 11-1 CR engine...
2012 Yukon XL Denali w/ 6.2 AWD |
02-11-2020, 02:09 PM | #8 |
Drives: 2017 Camaro SS 1LE (F1A-94 FBO H/C) Join Date: Jun 2017
do you get warnings on your screen stating you have hit battery saver mode or charging activated? something of that sort?
Performance Mods: F1A-94, DSX Flex Fuel Kit, MSD Spark Plug Wires, KOOK 2" off road headers, MBRP Race catback exhaust, Pray Performance Custom Boost Cam, Rocker Arm Trunion Upgrade Kit, 7.850" Hardened Chromemoly Length Pushrods and Johnson Racing 2110R Lifters, TSP CNC'd Heads, Ported MSD intake manifold, 103mm Katech Throttle body, Forged Pistons/Rods, RPM Meth kit, DSX Aux Fuel system, AEM Failsafe and banks gauge, LT4 HPFP, LT4 injectors, BMR motor mounts, Hurst Short Throw, Manley SS exhaust valves
Videos of my car? Check here: https://www.youtube.com/channel/UCNi...Qy1OL4NVGlPogw |
