01-12-2020, 12:38 AM | #1 |
Drives: 2017 Red Hot ZL1 M6 Join Date: Jan 2017
Flashing Hi Beams
It is impossible to rapid flash your hi beams with this car. Sometimes you want to get another driver's attention by flicking your hi beams on and off over and over rapidly but this switchgear will not allow it. I've never had any car that works this way.
I'm assuming everyone's car is the same as mine. This takes away what could be considered a safety feature when you're warning someone they're about to cut into your path of travel. |
01-12-2020, 12:48 AM | #2 |
Drives: 2017 Camaro SS 50th Join Date: Jun 2017
Camaro has bi-xenon headlights. That means, the same projector operates as your low and hi-beam. There is a mechanical shutter inside each projector that actuates this function. Unfortunately there is a slight delay the operation, compared to a vehicle with two independent light bulbs and/or filaments.
So the answer is no. |
01-12-2020, 01:26 AM | #3 |
Drives: 08 Tiburon GS, 2018 Camaro 2.0T Join Date: Sep 2017
If you don't pull completely on the lever, you can activate the high beam without "locking" it on the high beam. You are then able to flash it kinda quickly. But know that these lights, as mentioned above, are not made to do that, so it might not be good to do it too much.
2018 Camaro LS | 6 spd | 2.0L turbo | Nightfall Grey | RS package | Technology Package.
--------------------- Order WDGHKX 1100 - 5/08/2018 | 3800 - 6/18/2018 2000 - 5/09/2018 | 4200 - 6/21/2018 3000 - 5/28/2018 | 5000 - 6/27/2018 6000 - 6/29/2018 |
01-12-2020, 02:51 AM | #4 |
Drives: 19’ Camaro SS 1LE Join Date: Nov 2016
One or two clicks of flashing the high beams should be sufficient.
If you weren’t able to grab their attention by doing that, I highly doubt that having the ability to click it slightly faster is going to make a difference.
2019 Camaro SS 1LE
01-12-2020, 08:48 AM | #5 |
I agree, most people don't even look anywhere else than their phone while driving.
01-12-2020, 11:06 AM | #6 |
Drives: 2016 2SS M6 Mosaic Blk Met-SOLD Join Date: Jun 2016
I often get "bright lighted" by approaching cars, who evidently think I have on my brights, when I do not. I flick on my brights to show them, and they turn their brights off.
Does anyone else have this problem? Maybe my lamps are not angled properly?
Official Detailer of CamaroFest 8 & 9
https://www.autogeekonline.net/forum...st-8-pics.html https://www.camaro6.com/forums/showt...=521655&page=1 https://www.camaro6.com/forums/showt...=547470&page=1 https://www.camaro6.com/forums/showthread.php?t=527474 No one on Earth has detailed more Camaros. http://KirkTheDetailer.com |
01-12-2020, 11:12 AM | #7 |
01-12-2020, 11:18 AM | #8 |
Retired from Car mfrs....
Yes..your headlights need an adjustment.
01-12-2020, 07:44 PM | #9 | |
01-13-2020, 03:35 AM | #10 |
Long hauler
01-13-2020, 09:15 AM | #11 |
Drives: '17 Red Hot 2SS 6MT Join Date: Mar 2018
This doesn't work? Pull the lever instead of push.
Flash-to-Pass The flash-to-pass feature works with the low beams or Daytime Running Lamps (DRL) on or off. To flash the high beams, pull the turn signal lever all the way toward you, then release it. |
01-13-2020, 09:25 AM | #12 |
What speed limit?
Drives: 2017 SS 1LE Join Date: Jul 2019
Strange because I never had a problem flashing the high beams either
01-13-2020, 11:06 AM | #13 |
Drives: Chevy Camaro Join Date: Jul 2019
In most states it's illegal to flash your brights at cars anyway. Unless it on track.
01-14-2020, 05:57 PM | #14 | |
