Roto-Fab
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics
Old 02-26-2020, 09:40 PM   #29
ZMEnow
Drives: ZL1, 2013, tri-coat-red, manual
Not really, I just can’t go back there again.
ZMEnow is offline   Reply With Quote
Old 02-26-2020, 09:57 PM   #30
Vegas Bound
Drives: 2013 Sparkly Red One
Better?
No
Vegas Bound is offline   Reply With Quote
Old 02-28-2020, 08:53 AM   #31
Little Walter
Drives: ZL1
What menu do you go into to display your 0 to 60 time on the dash display?
Little Walter is offline   Reply With Quote
Old 02-29-2020, 07:57 AM   #32
Joe M 2012 2SS
Joe M 2012 2SS's Avatar
Drives: 2012 2SS
Originally Posted by StreetRage320 View Post
OP posted a good question in the ZL1 forum, but he ended up with a bunch of SS guys telling him not to mod his car, remove his floor mats, and insulting mothers, and a weird explanation of a hellcat vs. a scat pack.
Reaction time, torque, and traction are key to the 60'. Your R/T looks good
And the ZL1 guy tells him to improve his 60', he needs to improve his reaction time , and that a .6 reaction time is good.
I never told him to remove ONLY the floormats, I suggested removing SEVERAL things to reduce weight, along with getting the air pressure right. All of which are things that are 100% proven to reduce ET's.
Originally Posted by Joe M 2012 2SS View Post
You can also improve your ET's without any mods or spending any money. Remove passenger seat, 2 bolts t-50, remove rear seat, 5 bolts, 1-18mm and 4-14mm. Remove floor mats, trunk carpet, lid over battery, air compressor.
Also run as much air as possible in rear tires, if you hook at 18psi, go up to 20, if you still hook go up to 22. The more air you can run in the rears, the faster you will go. Track prep has a lot to do with this, the better the prep the more you can run.
Run front tires 5 psi shy of max allowable, this creates less rolling resistance, making you faster.
What is bad about this explanation of a scat-pak vs. a hellcat? The OP originally stated in his post, that this run was against a charger 6.4 hellcat. That car does not exist.
Hellcats have 6.2 engines, Hellcats are supercharged, scat-packs are not, scat-paks have 6.4 engines. The OP changed his description of the car he ran to the proper one after I posted this, he understood, evidently your the one who still doesn't know the difference between the two.
A charger 392 (6.4L) is not a hellcat, it's a scat-pack. Mods may be same but scat-pack is n/a, not supercharged like a Zl1.
Where is the post where he was told not to mod his car? There isn't one!
Roto-Fab intake, SW 1 7/8" LT w/hi flow cats, Flowmaster outlaw exhaust, UDP, 160* stat, Circle D 3200, Moroso catch can, TCI line lock, Zex Nitrous 125 shot, 3.91 gear, Eaton True-trac, DSS 1000hp axles.
Joe M 2012 2SS is offline   Reply With Quote
Old 02-29-2020, 08:08 AM   #33
StreetRage320
Those who need me got me
StreetRage320's Avatar
Drives: 2022 ZL1 A10
StreetRage320 is offline   Reply With Quote
Old 02-29-2020, 08:13 AM   #34
Joe M 2012 2SS
Drives: 2012 2SS
Are you absolutely kidding me? I prove every statement you made is absolute , and you call me a troll? YOU ARE THE TROLL.
Old 02-29-2020, 08:38 AM   #35
Bigdumogre
Bigdumogre's Avatar
Drives: 2012 Camaro SS
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
Bigdumogre is offline   Reply With Quote
Old 02-29-2020, 10:08 AM   #36
StreetRage320
Originally Posted by Bigdumogre View Post
yeah you are right - I should not have engaged, that's not why I am on this forum. Deleted my post.
maybe your not such a dum ogre..
Old 02-29-2020, 10:37 AM   #37
mh_vegas
mh_vegas's Avatar
Drives: '15 ZL1
I was wondering this also..?
mh_vegas is offline   Reply With Quote
Old 02-29-2020, 11:19 AM   #38
StreetRage320
My performance menu does not offer that from GM. My guess is he used a OBDII recorders.
https://www.autometer.com/dashcontro...B&gclsrc=aw.ds
Old 02-29-2020, 01:18 PM   #39
Vegas Bound
OK, you want a better 60'.
Better tires
Better clutch or converter, we still don't know what trans you have.
Better cam w/springs
Better wheels
Better suspension
Better driveshaft
Better tune
Better fuel
Better driver.
Old 02-29-2020, 02:43 PM   #40
Joe M 2012 2SS
Drives: 2012 2SS
Better tires
Better wheels
Better suspension
Better driveshaft
Better tune
Better fuel
Better driver.
It's an automatic. The screen shot in the original post shows M2 in the bottom left corner. This only comes up on automatic cars, to show what gear the car is in.
