TireRack
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics
Old 02-24-2020, 05:57 PM   #1
BAXZL1
Drives: 2013 ZL1
13 zl1 1/4 time
For first time ever i took my 5th gen Z to the track this past friday, mods on the car are, headers, intake and tune and tires. car put down 499WHP.
i ran against a 392 charger same mods with same tire, here is the run, whats the best way to drop time of the 60 foot?
ran 11.305 at 122.79
BAXZL1 is offline   Reply With Quote
Old 02-24-2020, 06:38 PM   #2
StreetRage320
Those who need me got me
StreetRage320's Avatar
Drives: 2022 ZL1 A10
nice run! Thanks for sharing the video. Reaction time, torque, and traction are key to the 60'. Your R/T looks good, tough to tell, but I did not see much traction loss, so maybe it's time for more boost? Have you considered a pulley swap?
StreetRage320 is offline   Reply With Quote
Old 02-24-2020, 06:58 PM   #3
Vegas Bound
Drives: 2013 Sparkly Red One
Same way you get to Carnegie Hall, practice practice practice.
Vegas Bound is offline   Reply With Quote
Old 02-24-2020, 07:27 PM   #4
Joe M 2012 2SS
Joe M 2012 2SS's Avatar
Drives: 2012 2SS
A charger 392 (6.4L) is not a hellcat, it's a scat-pack. Mods may be same but scat-pack is n/a, not supercharged like a Zl1.
For faster 60 ft. times a stalled converter should get you to low 1.5 60'.
If I were you I'd concentrate on that .623 reaction time, a car running 11.8 cutting a decent light is beating you.
Leave on the third yellow, not the green.
Reaction time has NOTHING to do with 60' time and will not improve it AT ALL.
You can also shallow stage for a better 60' time.
Roto-Fab intake, SW 1 7/8" LT w/hi flow cats, Flowmaster outlaw exhaust, UDP, 160* stat, Circle D 3200, Moroso catch can, TCI line lock, Zex Nitrous 125 shot, 3.91 gear, Eaton True-trac, DSS 1000hp axles.
Joe M 2012 2SS is offline   Reply With Quote
Old 02-24-2020, 07:44 PM   #5
BAXZL1
Drives: 2013 ZL1
Not worried about reaction, just trying to get my ET down
Old 02-24-2020, 07:55 PM   #6
Silveradoss573
Drives: Camaro 1LE
Reaction time has nothing to do with your 60 ft time. The little trick for better 60 ft time without changing a thing is to just "tickle" that bottom stage light. As for not caring about r/t, how do you expect to go rounds with that?
Silveradoss573 is offline   Reply With Quote
Old 02-24-2020, 07:57 PM   #7
Joe M 2012 2SS
Drives: 2012 2SS
Footbrake it as far as it will go with the stock converter just before it overrides the brakes, you can sit at the green light till you get it right. Then at the same time, release the brake and push gas pedal to the floor & hold.
ET's are nice, reaction times win races.
You can also improve your ET's without any mods or spending any money. Remove passenger seat, 2 bolts t-50, remove rear seat, 5 bolts, 1-18mm and 4-14mm. Remove floor mats, trunk carpet, lid over battery, air compressor.
Also run as much air as possible in rear tires, if you hook at 18psi, go up to 20, if you still hook go up to 22. The more air you can run in the rears, the faster you will go. Track prep has a lot to do with this, the better the prep the more you can run.
Run front tires 5 psi shy of max allowable, this creates less rolling resistance, making you faster.
Old 02-25-2020, 09:01 AM   #8
Juiced1
Drives: 2012 2SS CAMARO 45th
That's a fair 60ft time. What did you do at the launch? Straight punch? It looks like it can take a little more power out of the hole. Either harder on the gas or we can help adding some power. We have plenty of pulley options, ported blowers and more. It's easy to make power with an LSA
Juiced1 is offline   Reply With Quote
Old 02-25-2020, 09:28 AM   #9
Vegas Bound
Tip #1, don't double bulb.
Old 02-25-2020, 09:50 AM   #10
13_SS_RS
Drives: White 2013 SS/RS l99
That was an awesome video! How many car lengths did you have him by? I couldn’t tell from the angle of the camera.
Current: 2013 summit white Camaro 2SS l99
CAI, long tubes, ported tb, tune
Previous: 2008 jet stream blue Corvette Z06
Airraid, Corsa, MGW shifter SOLD
13_SS_RS is offline   Reply With Quote
Old 02-25-2020, 11:41 AM   #11
Little Walter
Drives: ZL1
What menu did you go into to display your 0 to 60 time on the dash display?
Little Walter is offline   Reply With Quote
Old 02-25-2020, 12:37 PM   #12
Vegas Bound
He won by 0.43 seconds. 1 second at 130 mph is 146 ft. Do the math.
Old 02-25-2020, 01:15 PM   #13
13_SS_RS
Id rather do your mom but she’s packed on a few too many pounds for my liking
Old 02-25-2020, 01:27 PM   #14
Vegas Bound
She's dead, cremated and poured in the ocean. Next time you go swimming, you can drink some of her.
