01-07-2018, 12:19 PM | #169 | |
Drives: 15 RH Z/28, 23 RB2SS1LE, 23LT1VOM Join Date: Dec 2012
01-08-2018, 09:40 AM | #170 | |
Drives: 21 Bronco Join Date: Jun 2012
01-08-2018, 10:22 AM | #171 | ||
01-08-2018, 10:31 AM | #172 | |
The Z/28 IMO would be better suited to like others have said ZL1 1LE aero/go fast goodies with slight bump in power. That would make it the ideal N/A track choice which IMO is what the Z/28 should be. Continue to improve the ZL1 1LE if you want a engineering experiment because I just don't see any way they can make an NA camaro outperform the Z1LE |
01-08-2018, 12:27 PM | #173 | |
Z/28: start with a better Aero, active wing in the rear most of the ZL1LE suspension and drive line, less the M6, go with the new TR-9070 DCT 7-Speed Dual Clutch Transmission, Dont forget the horse power for that the new Z/28 needs and old GM friend ( they used this company in the past, one of the guys they had work on that old LT5 is now high up at camaro team) Mercury Racing Reveals SB4 7.0 Automotive Crate Engine. Can we see this in the car, if they detune it at say only 700HP its still less then the new ZR1, best part is it fits in all the dots, N.A. high rev limit 8000 RPM and it will work in the 6th gen TQ numbers are good, or they may have there own motor wink wink. Car will need great brakes, and carbon ceramic rimes, you know it where its going so GM needs to try there luck at it. This may be wising But i hope they Hear this. |
01-08-2018, 01:31 PM | #174 |
01-08-2018, 01:39 PM | #175 | |
Drives: 2017 1SS 1LE Join Date: Sep 2014
01-08-2018, 01:40 PM | #176 |
Whatever it is.. those rear brakes are HUGE
01-08-2018, 02:30 PM | #177 | |
Drives: 2015 SS 1LE Red Hot, 1970 Chevelle Join Date: Apr 2012
01-08-2018, 04:16 PM | #178 |
Maybe NA is dead, how bout a ZL1 w LW Z/28 option ,LT5 and CCB's?
I mean ,how many saw the ZL1/1LE coming?. Those rear brakes look straight off the Gen 5 Z. Daytona is six weeks away.. |
01-08-2018, 04:35 PM | #179 |
If it’s not n/a, leave the Z/28 badge off it, especially if it’s just a package on the ZL1.
01-08-2018, 06:05 PM | #180 |
i'm with you,but for them to make a specific NA motor just for a limited production model would not fly economically. They go LT5, CCB's,take some weight off, comes in low eighties and does a sub seven minute ring time it will sell. Plug and play on the ZL1 Platform. They will need to answer the GT500, and this would fit the bill. Everyone wanted a gen 5 1LE with an LS7 option, we got the Z. Just can't see them making a mid level Z at this point.
01-08-2018, 06:08 PM | #181 | |
The GT500 will go unanswered, just like the last one.
01-08-2018, 06:26 PM | #182 |
Drives: '20 ZL1/'97 SS LT4 Join Date: Feb 2009
With the ZL1 1LE out there...I don't really understand the point of the Z/28 coming out in this generation. Why buy something this expensive (and you know it will be) when a ZL1 1LE would be quicker/faster? If it is true and they are bringing it back for the 6th gen...I pray it stays N/A, and like someone said above...does sub-seven minute ring times.
